Question about Canon CanoScan LiDE 25 Flatbed Scanner
Canoscan does not work on vista 64-bit
Have a vista OS, 64-bit platform. my canoscan lide 20 does not work (twain error). need help
  • 2 more comments
  • Anonymous Nov 20, 2008
    same problen. different scanner. ive considered dual booting with my old xp just to run the scanner
  • suniltalakad Dec 15, 2008
     Yes in have the smae problem. Please solve this.
  • Anonymous Jan 08, 2009
    Ihave a vista OS, 64-bit platform. my canoscan lide 20 does not work .
  • ifeito Feb 28, 2009
    Canoscan 1250 U2F does not work on XP64
I'm not sure if this will work on the lide 20. I have an lide 35, and there are no 64 bit drivers for it. I downloaded and installed the drivers for the lide 60, told the computer to manually find the lide 60 drivers for my scanner, and installed the canoscan toolbox for vista 64 bit. Works like a champ.
Posted on Dec 21, 2008
I have windous vista 64 bit no work canon canoscan lide20
Posted on Jan 04, 2009
I have a HP Pavillion DV6 4000 series 64-bit notebook and am trying to load my canoscan lide 25 scanner. the only drivers I can find are 32 bit and won't install. Can you tell me where I can download the...
You need the TWAIN driver version 11.0.1.1a for Win7 or Vista 64-bit or the WIA 1.2.1.0 driver for Vista onlyand the CanoScan Toolbox version 4.9.3.2. This is from Canon support http://www.usa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_lide25?selectedName=DriversAndSoftware#ServiceAndSupport . The detail of the version was found in the support list after querying for Win7 support.
The both files are here: http://www.usa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_lide25?selectedName=DriversAndSoftware#DriversAndSoftware . Scroll all the way to the bottom of the OS list to the appropriate 64-bit OS (Vista or Windows 7). Vista (x64) is the fourth from the bottom and Win7 (x64) is the third from the bottom of the list.
I hope this helps.
Dec 09, 2010 | Office Equipment & Supplies
My cannon canoscan lide 20 lide 30 driver,dose not install with windows 7
Do you have the 32-bit OS or the 64-bit OS? The Canon drivers will work in 32-bit Win7. However, Canon doesn't support these scanners in the 64-bit OS. The only way to make the scanner work in the 64-bit OS is to run either a dual boot system or a virtual computer with a supported OS. The Vista x64 bit driver doesn't work even if you use the compatibility mode.
If you have Win7 Ultimate, you can download Microsoft's Virtual PC and the XP mode for free. All other virtualization software options (Virtual PC, Parallels, VMWare) require a paid (licensed) version of the OS. Then install the scanner in the virtual computer and transfer files to external media to share it with the main computer. Dual boot systems have the same restriction of needing a valid OS.
I'm not aware of any Canon drivers for this scanner under UNIX.
I wish that I could be of more help.
Sep 02, 2010 | Computers & Internet
No driver for Canoscan FB 630U Vista 64 bit
Unfortunately, it doesn't look like Canon supports this scanner under Vista. Check if the Windows generic TWAIN scanner driver will work. The Canon software won't work. If the generic driver can be installed, then you should be able to acquire scans in Paint (File > Import from Scanner or Camera), Windows Fax and Scan (New Scan) (some versions of Vista) or Windows Photo Gallery (IIRC it works like Paint).
I hope this helps.
(Canon wants you to upgrade. I have a different scanner that isn't officially supported past XP and the generic driver works fine. Unfortunately, you can't just use the XP driver in the compatibility mode due to the lack of signed drivers that are required in the 64-bit OS)
Jun 03, 2010 | Canon CanoScan FB630U Flatbed Scanner
Canoscan Toolbox returns a TWAIN error with
maybe the software that you download is a 32 bit O.S only that's way it cos you and error. because your O.S
is not compatible to the software that you use. download a 64 bit driver twain
Mar 05, 2010 | Canon CanoScan 4200F Flatbed Scanner
CanoScan LiDe 60 wont work on emachine with window 7. Error about being 32 bit.
Go to the following URL: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=235&modelid=11446#DownloadDetailAct
Then select your OS.The drivers and software for Win7 32 bit and Win7 64 bit different. The Win7 64 bit drivers are digitally signed; the 32 bit version doesn't need the same level of security certificates (a Microsoft issue).
I hope this helps.
Dec 18, 2009 | Canon CanoScan LiDE 60 Flatbed Scanner
Canon lide scanner vista 64 drivers
This is the link to the drivers and CanoScan Toolbox.
Click on the
Drivers & Downloads on this page then choose Vista(64) as your OS
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=235&modelid=6623#DownloadDetailAct
Apr 11, 2009 | Canon CanoScan LiDE 30 Flatbed Scanner
TWAIN ERROR AND CANOSCAN LIDE 20 SCANNER PROBLEMS
Select your operating system and download the driver "TWAIN Driver - LiDE 20 Scanner Driver Ver. 7.0.3.1a_xp" and then download the software "Canoscan toolbox" ...here is the link:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=6624
Aug 04, 2008 | Canon CanoScan LiDE 30 Flatbed Scanner
Unable to select TWAIN source
tried uninstallin and installin canon scanner drivers..nothing works..still seeing unable to select twian source..
so i tried an alternative..here we go..
on vista 64 os/vista any version..click Start>All programs>Windows fax and scan
next click new scan on top and that got me going.
some say there are issues with the way usb talks to old scanners with new operating systems like mine (vista 64). hope it helps until you find the actual cure.
Jun 24, 2008 | Canon LIDE20 Flatbed Scanner
Canon Scanner - Twain Pilot
QUICK ANSWER: use the original USB cable that came with the scanner.
LONG EXPLANATION:
Using Vista (32 bit version) and a Canon N670U scanner with the new drivers installed from the CanonUSA website. This driver is works for Canon scanners: LiDE 20, LiDE 30, N670U, N676U and N1240U, found at http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=235&modelid=6625
Canon says it doesn't support Vista 64 bit version. I couldn't get the scanner to work and kept getting the TWAIN error also, despite uninstalling / reinstalling the driver. Finally, decided to disconnect my 3rd party 16 foot USB cable and use the original cable. I swear, it WORKED! I can't explain why, but it did. Perhaps there is increased resistance, hence reduced power going to the scanner by using longer/different USB cable? Anyhow, it worked...go figure. If you have the 64 bit version of Vista, I guess it won't work(?).
Mar 24, 2008 | Canon CanoScan N656U Flatbed Scanner
Canon CanoScan LiDE 25 Flatbed Scanner Logo
5,609 people viewed this question
old marine
old marine
