Question about Canon PIXMA iP4300 InkJet Photo Printer
Ip4300 canon it does not feed the paper
  • 1 more comment
  • Gwyn Evans
    Gwyn Evans Dec 03, 2008
    My ip4300 no longer feeds itself paper. I think it is a cleanliness problem but the difficulty is identifying which bit to clean, and which screws to unscrew to get to it! Has anyone had the same problem?
  • fancyqhgal Mar 19, 2009
    My printer has the same problem, however I believe it is because I used paper too thick for specifications before. That was when it happened. Now it also prints liney sort of and also way too pink, which is funny because I heard someone else say theirs prints too yellow and turquoise! I want to deep clean mine as well, but cannot find instructions. My paper comes out with ink smudges on the edges.
  • Anonymous Mar 23, 2009
    printer  not recognising paper in feed,therefore it won't print.  what to do?
I had same problem this pm. Be sure you have not pressed the button to change paper source to the back feed. The green light on the paper feed button should be illuminated at the top of the printer icon. This solved my problem.
Posted on Apr 08, 2009
Canon PIXMA iP4300 InkJet Photo Printer driver
Posted on Nov 22, 2008
Canon ip4300 manual
hello,maybe the paper feed is jammed try to see if it has something that stops the paper to go in and if you are asking for the service manual for the ip4300 printer you can download it from the below link:
Good luck
May 25, 2013 | Canon PIXMA iP4300 InkJet Photo Printer
My Canon iP4300 printer is giving me a service error 6000 message. How do I fix this problem.
Sounds like you might have a paper jam. Sounds like there might be a piece
of paper, or a scrap torn from a piece of paper, stuck somewhere in the
paper path. The "peculiar sound" once you switch it on could be a clue that
there is a problem of that sort as parts that are not free to move properly
grind against one another.
Paper feed error [6000]
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 17, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Canon ip4300 printer says paper output tray is closed. wont prin
Its a defective printer you have that cant get out of paper output tray is close or that the paper output tray is not properly placed into the printer.
Try to reseat the output tray and let me know. If it does not work, you may need to send printer to repairs.
Mar 19, 2010 | Canon PIXMA™ iP4300 InkJet Photo Printer
Top paper feed does not feed 1 at a time, feeds multiple sheets or envelopes
Check for obstacles - top trays got biggest disadvantage: u may easily drop something into it. I`ve found 1GB memory card in mine
Dec 11, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Canon ip4300 Error code 1300
u have to reset ur printer try to hold ur finger on power button for more than 15 sec then turn it on again
Jun 09, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Paper will not feed into ip4300 canon printer
reseat the printer and even if it does not work then paper sensor has gone bad
Aug 12, 2008 | Canon Office Equipment & Supplies
Took a can of Blow Off (dust remover) and blew through paper track, and used a paper towel soaked in Isotope Alcohol and rubbed the tracking rails..
Everything seems to work fine for now except the canister paper holding is not feeding properly and the paper is getting jammed when you try to use it. This is not that important as long as paper can be fed the normal way and it doesn't jam..
Jul 12, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
'paper jam' error on canon pixma ip4300
ring canon support on 0844 369 0100
or try
they suggested i do a roller cleaning - but i cant find this option ?
Jun 24, 2008 | Office Equipment & Supplies
Canon ip 4300
Google "canon ip4300". The entry near the top has a support tab. and enter "paper skew", you'll get a roller cleaning procedure.
As a matter of fact, it didn't solve my problem. The alternative, of having the machine repaired, is, of course, silly vs. buying a new machine. But in the meantime, the lower paper feed still works, albeit slightly less convenient.
Apr 22, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
Canon PIXMA  iP4300 InkJet Photo Printer Logo
551 people viewed this question
old marine
old marine
