Question about Epson AcuLaser C3000 Printer
Paper Jam at A but nothing there
I have an Epson C3000 which all it ever does is come up with Jam A however there is nothing there that I can see.I have tried taking the fuser and photoconductor out and reseating them but still makes no difference does anyone have any ideas
  • pdonald66 Jan 06, 2009
    Got same problem - after self test display shows Jam at A - have tried all the usual, checked sensors for damage but cannot clear Jam. Anyone have a solution? is this a stock fault?
  • Epson Master
  • 691 Answers
If you clear the jam and close the machine up again, does the print job eventually print OK. You may have to clear the jam several times before the machine prints it successfully. After the first successful print, does the machine then print ok, until the next time it is left idle for some time? If this is the case, I have a fix for you
Posted on Nov 18, 2008
Epson xp430 paper jam, but I can't find any jam!
They don't tell lies :>) Even the smallest piece of paper over the sensor will record a jam. This often happens when you have a jam and you pull the paper and it tears a piece off. Open all the doors, remove the paper tray, remove all the toner or cartridges and look with a flashlight. Always pull paper jam paper in the direction it was going, undo tensioner clips if present and pull paper evenly and slowly as not to tear the paper. If you do, keep the paper and find the piece that fits the piece that is missing.
Having said that, see the link
Paper Jam Problems - Epson XP-430 User Manual [Page 234]
https://www.manualslib.com > ... > Epson Manuals > Printer > XP-430 > User manual
Epson XP-430 Manual Online: Paper Jam Problems. If you have problems with paper jams, try these solutions: 1. Cancel the print job from your computer, if...
SOLVED: Error says paper jam, but there is not. What could cause this ...
https://www.ifixit.com/.../Error+says+paper+jam%2C+but+there+is+not.+What+could... Dec 18, 2013 - I have an Epson Artisan 837 all in one. It was working perfectly fine yesterday. Today it is telling me I have a paper jam. I went through the steps ...
How to solve paper jam or paper feed error DO IT YOURSELF ...
? 3:43
https://www.youtube.com/watch?v=kHHpVcSJvvA
Aug 16, 2016 - Uploaded by Easyprint-DZ Support
... of commons problem of printer . paper feed error or paper jam error. ... we gonna work on epson ...
Paper Does Not Feed Correctly - Epson
https://files.support.epson.com/htmldocs/pho22_/pho22_rf/trble_4.htm Paper does not feed. Multiple pages feed. The paper jams. Paper is not ejected fully or is wrinkled. Paper does not feed correctly when using the double-sided ...
Epson XP-430 ' XP Series ' All-In-Ones ' Printers ' Support ' Epson US
https://epson.com/faq/SPT_C11CE59201~faq-293729 Mar 24, 2016 - If paper jams when you load only one or two sheets, try loading more sheets at a time. Do not load more than the recommended number of ...
Epson xp430 paper jam Google Search
Oct 23, 2017 | Epson Office Equipment & Supplies
Why epson l130 printer shows paper jam message while there is no paper inside?
The sensors could be broken or there may be something else stuck inside, sticky labels, small bit of paper?
Have you opened up all areas you can without tools with the power off for your safety?
If there is nothing found it may need a repair.
Dec 08, 2015 | Epson Office Equipment & Supplies
Paper jams regularly on Epson Aculaser C3000. Had to update firmware a while ago. Now that problem has returned I tried to run the latest update (NVMUpdate_10106.exe) but get error message that dll...
I had the same problem. Update program is most likely not designed for Windows 7. I've launched it in Windows XP (SP3) compatibility mode and it did the work just fine.
Oct 14, 2010 | Epson AcuLaser C3000 Printer
Hi. Epson C3000 aculaser. It is ghosting on only on black at a pitch of +/-62mm and also printing horizontal black smudges across both side of the paper at a pitch of +/- 25mm. I have totally cleaned the...
Hi Colin.
I just have had the same problem with my Aculaser C4200.
I may have found a way to solve you problem.
Just print 10 blank (without anything), and after that i took all toner's, the fuser etc. and put it back again. Printed 10 more blank pages, and printed over 200 pages with lot of tekst and colour (think that 50 pages could do it).
After 2 days everything is still ok for me.
Sep 30, 2010 | Epson AcuLaser C3000 Printer
"Clear paper jam" error, but there is no jam!
Use flashlight to shine inside of all possible visible areas of printers. Especially to the very right or very left. I'm sure you will find something. Remove it
May 25, 2017 | Epson Stylus Photo RX620 All-In-One InkJet...
C3000
Hi Marko, the issue has been sorted fully by a fairly simple update to the firmware. There is a complete solution available from the address below. I spent ages messing around trying to find the correct fix for the firmware. I came across the solution below and found it 100% effective for the machines I have used it on.
http://www.tradebit.com/filedetail.php/4942713-epson-c3000-c4100-jam-at-fuser-rescue
It's not a free fix, but it is damn cheap, and I can vouch for the fact that it works.
Nov 24, 2008 | Office Equipment & Supplies
Papaer will not feed
High ITConsult And MarkoP
The high pitched whine and the paper stopping just before the fuser (the hot) unit is a known issue on the C3000 and C4100. If you are still searching for the solution to this issue, let me know, as I now have a working fix for the problem.
Reply to this post for further info.
Jul 10, 2008 | Epson AcuLaser C3000 Printer
How to fix paper jam Epson CX3650?
Please perform the below steps.
1. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
CREDITS: nanicool
IF YOU DONT GET FIXED WITH THIS THEN PLEASE REPLY BACK.
I SHALL BE GLAD TO HELP YOU WITH YOUR PROBLEMS.
THANK YOU
REGARDS
SWEET RASCAL
Jun 28, 2008 | Epson AcuLaser C3000 Printer
My EPSON Aculaser C3000 is ghosting
Could be any of the following:
* Bad toner - try a different toner
* Unsuitable paper - try a different paper
* wrong software drivers - download the latest drivers for your operating system from the manufacturer's site.
Jan 04, 2008 | Epson AcuLaser C3000 Printer
Epson AcuLaser C3000 Printer Logo
272 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
