Question about Infinity KAPPA 60.5CS Car Component System
Placing the component crossovers in Yukon Denali
I have a 2001 GMC Yukon Denali. I've replaced the factory stereo and am about to replace the factory bose speakers. I am going to be doing a rewire. I just need to know where I should place the crossovers for these component speakers.
0 characters
1 Points
I have alpine sps600c & am installing them in a 2001 Nissan frontier w/ 6 disc 6 speaker (2 ea in each ront door, 2 in back (crew cab). Do I wire my tweeters to existing tweeter output, or...
Did you change out the factory deck? If not, wire the tweets to the existing wiring. If you already have tweets they have been crossedover already. However, if you replaced the deck, you may need to run new wire to the doors and use the crossover that came with your component set. Hope this helps
Sep 05, 2011 | Alpine SPS-600C Car Component System
My yukon xl denali 2001need a code to unlock factory cd player. please help.
You can get this from the local dealer. You will need your VIN #. It will cost a little, but is worth getting the right code. Hope this helps.
Aug 22, 2011 | Car Speakers & Subwoofers
I have a 99 GMC suburban. I just replaced the AC
Find a blue wire on the wire harness to the truck and connect from the blue white on the radio. this will turn on the factory amp that runs the rear door speakers
Feb 08, 2010 | Car Speakers & Subwoofers
I have a 04 silverado do i need to install my component speakers in series or can i hook up woofer to factory wing and tweeter seperate from factory
With component speakers it is imperative that both the speakers be hooked up to the supplied crossover. Wiring them in series or parallel will not yeild satisfactory results since the woofer requires lower freequency then the tweeter, which plays the high notes.
Now some cheaper speakers do not use crossovers and sound rather poor. What make and model of speaker are installing? Does you truck already have component speakers in it?
Jan 06, 2010 | Alpine SPS-600C Car Component System
Code for locked stereo
May 10, 2009 | Car Speakers & Subwoofers
2002 yukon gmc my speaker is out and I need to know what type of speaker I need.o is it square or round and installation process
Standard Yukon front and door speakers are 5-1/4". Most aftermarket speakers will require an adapter bracket.
Also, there are custom made kick panel enclosures for the Yukon.
Installing new speakers in the doors is a rather easy process. You just need to remove the door handles, door lock and window switches, and the door panel, remove the speaker, disconnect it, plug in the new speaker, and then reinstall everything you took off in reverse order.
One online aftermarket retailer, will send you an "install guide" tailored to your vehicle when you purchase from them. They will also include any brackets, adapters, or wiring harnesses needed, usually at no additional cost.
In order to be more specific, additional information on your vehicle would be required. Is it the Yukon, Yukon Denali, Yukon XL, or Yukon XL Denali and does it have the Bose system with or without OnStar, and does it have the OEM subwoofer?
With this information, Crutchfield or many other online retailers can help you select exactly what you want.
Mar 26, 2009 | Toshiba Car Speakers & Subwoofers
Car speaker installation
Yes... for sure you can use the woofers wiring, BUT if you are keeping the factory radio you might have reduced volume and or quality due to the inefficency of some newer model higher power needing components... let us know if you are amping or not, and if not.. try and do so..
May 19, 2008 | Audio Pro 15PLB76 15 Inch 800 Watt Woofer...
Infinity KAPPA 60.5CS Car Component System Logo
Top Infinity Car Speakers & Subwoofers Experts
Tygh Duval
Tygh Duval
Colin Stickland
Colin Stickland
Steve Sweetleaf
Steve Sweetleaf
Are you an Infinity Car Speaker and Subwoofer Expert? Answer questions, earn points and help others
