Question about Zanussi FLA1001W Front Load Washer
How to fit drive belt to zanussi washing machine
Please can someone advise me how to fit the drive belt to my Zanussi FLa1001w front load washing machine. I have thread the belt around the motor then around the larger pulley, the tension in the belt seems to be tight but when I put washer onto spin the belt just seems to keep coming off. please help before my head explodes!!!!
  • 2 more comments
  • Anonymous Apr 02, 2008
    I have the same problem - but when I looked at the wheel and motor spindle they seemed to be misaligned by about 15mm, causing the belt to come off after 2 or 3 revs. I can't see how the the wheel and motor can be misaligned as they are all connected - but they are. The only thing I can think of - is if the drum has moved, causing the wheel to move out and cause the misalignment. I will be checking bearings etc tonight
  • clive e boy Sep 22, 2008
    Zanuzzi 1200 front load washing machine how do i fit a drive belt around the pullys it seems to tight but its the right belt
  • Anonymous Sep 26, 2008
    I had a similar problem - belt slips off the inside, and bought a new pulley belt and large wheel.
    However, this didn't help, and then I noticed that the machine was dripping brown rust on the floor.
    Major problem - the main bearing has gone.
    http://applianceguru.com/forum2/
  • wallysson Mar 16, 2009
    How can I fit a drive belt around the pullys on a Zanuzzi 1200 w front load washing machine. It APPEARS to tight but its the right belt
  • 641 Answers
Does it a new belt or the existing one ?
Posted on Sep 04, 2007
  • Steve Pritchard
    Steve Pritchard Nov 27, 2013
    new belt the old one came off and was badly worn the unit is 13 months old
Check wheel and motor alignment - a new belt won't stop this happening if the alignment is out - as I found.
Posted on Apr 02, 2008
What is the easy way to fit a drive belt to a zanussi washing machine fla1001w
Disconnect from the mains.
Remove the back, slacken the clamp bolts holding the tension on the old belt next to the motor.
Fit the new belt, tighten the tension on the belt and tighten the clamp bolts.
Feb 23, 2011 | Microwave Ovens
Zanussi FLA 1001W does NOT spin
You need to check the brushes in the motor first, replace if less than 3 or 4mm long.
If brushes o/k, then could be a module or motor problem, apart from the belt being broken or worn of course.
Hope this helps.
Jan 23, 2010 | Zanussi FLA1001W Front Load Washer
My Zanussi FLA1001W will wash but will not sin or
Check the impeller on the pump free to move. if ok check electrical connections. if ok either pump is faulty or it could be main pcb (or both)
Oct 17, 2009 | Zanussi FLA1001W Front Load Washer
Zanussi fl815
sent you an email direct - hope it helps
Jun 29, 2008 | Zanussi FLA1001W Front Load Washer
How to replace the belt on zanussi fla1101w
just struggle i'm afraid. put belt on motor pulley then start it on the drum pulley. turn the drum pulley and it will go on but very tight
May 22, 2008 | Zanussi FLA1001W Front Load Washer
Drum would not spin
Hiya Jazz08.... need to replace the drive belt!
Mar 21, 2008 | Zanussi FLA1001W Front Load Washer
FITTING NEW BELT ON ZANUSSI WASHUNG MACHINE F1045W
It is'nt any adjustment on those machines. They were fitted with eleastic belts. Is the belt not tight enough, you need a new belt.
Jan 23, 2008 | Zanussi F1045W Front Load Washer
Zanussi FX1465W aquacycle, beeps 5 times and end light flashes
I have the same trouble with my washing machine did you find a solution i have been told the PCB or motor drive system
May 19, 2007 | Zanussi FJS1225W Front Load Washer
Zanussi FLA1001W Front Load Washer Logo
2,069 people viewed this question
Top Zanussi Washing Machines Experts
shaun taylor
Marvin
Marvin
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
