Question about Sony Ericsson K700
K700i is restarting after 1 min.
My telephone is reloaded each minute, prompt me, in what the reason and as it to correct. I am engaged in repair, but the circuit for this telephone I can not find. Help me please, it is very a pity to me to throw out my telephone. Beforehand is grateful.
    Problem Solver:
  • 9 Answers
My friend you dont need to find circuit for the phone cause problem is not hardware, you will need to upgrade your software.
Posted on Oct 22, 2006
Toshiba Satellite L355-S7812 keeps restarting with AC Adapter plugged in
Your OS has a corrupt element in it that makes unit shut down every once in a while. Try repairing the OS. Or try a system restore. If nothing works and it still bugs you reload the unit.
Sep 06, 2017 | Computers & Internet
Error reading MBR
Restart your computer with the XP Setup disk in the CDROM drive. If you are prompted to press a key to start the computer from CDROM, do so quickly. Otherwise it may try to boot from the hard drive. After a few minutes, you'll see a prompt to press the R key to start the Recovery Console. When Recovery Console starts, it will prompt you to enter a number corresponding to the Windows XP installation that you need to repair. In most cases, you'll enter "1" (which will be the only choice). If you press ENTER without typing a number, Recovery Console will quit and restart your computer. Enter your Administrator password. If you don't enter the correct password, you cannot continue. At the Recovery Console command prompt, type fixmbr and then verify that you want to proceed. Your damaged MBR will be replaced with a shiny new one, and you should then be able to boot your system normally. In some cases, you may need to repair the boot sector in addition to the MBR. If your system still doesn't boot properly, repeat the steps above, but issue the fixboot command instead. Hope this helps
Mar 30, 2011 | Western Digital Elements powered by WD 320...
Hdd mbr is lost
Restart your computer with the Setup disk in the CDROM drive. If you are prompted to press a key to start the computer from CDROM, do so quickly. Otherwise it may try to boot from the hard drive. After a few minutes, you'll see a prompt to press the R key to start the Recovery Console. When Recovery Console starts, it will prompt you to enter a number corresponding to the Windows XP installation that you need to repair. In most cases, you'll enter "1" (which will be the only choice). If you press ENTER without typing a number, Recovery Console will quit and restart your computer. Enter your Administrator password. If you don't enter the correct password, you cannot continue. At the Recovery Console command prompt, type fixmbr and then verify that you want to proceed. Your damaged MBR will be replaced with a shiny new one, and you should then be able to boot your system normally. In some cases, you may need to repair the boot sector in addition to the MBR. If your system still doesn't boot properly, repeat the steps above, but issue the fixboot command instead. Hope this helps
Mar 29, 2011 | Seagate HDD 40GB 7200RPM ATA100 2MB...
Keyboard stops working after password has been entered in Vista
Please follow steps below to reset your Windows Vista Password in 10 minutes.
Steps :
1. Insert the Windows Vista DVD into the DVD drive and then restart the computer.
2. Change Boot Options 1st Priority to Optical Drive.
3. When system booting up, if the message “Press any key to boot from cd” appears, immediately press Enter.
4. On Language Settings, Time and Currency and Keyboard Layout screen, just choose the correct settings then click Next.
5. On Install Now screen, click Repair. Note: Click No just in case you get the message: Windows found problems with your computer’s startup options.
6. On the System Recovery Options screen, under Operating System, click Windows Vista then click Next. Then select Command Prompt.
7. At the command prompt windows, type the following command then press Enter after typing each command:
c:
cd windows\system32
echo ~takeown /f %1 /r /d y > TakeControlOf.cmd
echo ~icacls %1 /grant administrators:F /t
ren Magnify.exe Magnify.old
ren cmd.exe Magnify.exe
8. Restart the computer.
9. On the Welcome Screen, click the Ease button.
10. Check Make items on the screen larger then click OK.
11. At the prompt, type the command then press Enter.
net user Administrator /active:yes
exit
12. Restart the computer.
Sep 27, 2009 | HP Compaq Presario CQ50-110US Laptop
Repair Acer 4937 MBR failed !!
with MBR I assume you mean master boot record.
  1. Restart your computer with the Windows XP Setup disk in the CDROM drive.
  2. If you are prompted to press a key to start the computer from CDROM, do so quickly. Otherwise it may try to boot from the hard drive.
  3. after a few minutes, you'll see a prompt to press the R key to start the Recovery Console.
  4. When Recovery Console starts, it will prompt you to enter a number corresponding to the Windows XP installation that you need to repair. In most cases,
  5. you'll enter "1" (which will be the only choice). If you press ENTER without typing a number, Recovery Console will quit and restart your computer.
  6. Enter your Administrator password. If you don't enter the correct password, you cannot continue. You can leave it blank if you don't have one.
  7. At the Recovery Console command prompt, type fixmbr and then verify that you want to proceed.
Your MBR will be replaced with a new one, and you should then be able to start up normally. In some cases, you may need to repair the boot sector in addition to the MBR. If your system still doesn't boot properly, repeat the steps above, but issue the fixboot command instead.
Exit, quit, restart or reboot command should get you out from the console
If the problem is still not solved, use the windows xp setup disk to do a new installation of windows, if it finds your old windows version from the hard drive you may repair it with the repair option (not the same as above)
May 22, 2009 | Acer Aspire 5610-4648 Notebook
My computer boots up but restarts after
1.Restart your computer with the Windows XP Setup disk in the CDROM drive.
2.If you are prompted to press a key to start the computer from CDROM, do so quickly. Otherwise it may try to boot from the hard drive.
3.After a few minutes, you'll see a prompt to press the R key to start the Recovery Console.
4.When Recovery Console starts, it will prompt you to enter a number corresponding to the Windows XP installation that you need to repair. In most cases, you'll enter "1" (which will be the only choice). If you press ENTER without typing a number, Recovery Console will quit and restart your computer.
5.Enter your Administrator password. If you don't enter the correct password, you cannot continue.
6.At the Recovery Console command prompt, type fixmbr and then verify that you want to proceed.
May 06, 2009 | Acer Aspire 5100 Notebook
MBR record
boot from an original XP cd, 1st option select "r" for repair. Select OS... Normally "1", then type in your administrator password, normally blank. when the command prompt is ready, type in "fixmbr" follow prompts and then type "exit" to restart.
See if that helps
Apr 22, 2009 | Computers & Internet
K700i sim does not detect
i dont think that your sim is the problem... you could have some software problems... try updateing your software with SEUS update, (you can download it for free, in sonyerricsons official site... with all tutorails what to do...)
Mar 18, 2009 | Sony Ericsson K750i Cellular Phone
Toshiba Satellite P105-S6084 Laptop Boot Problems.
This happens sometimes due to faulty memory or faulty software that causes errors in filesystem. You need to obtain a Windows XP with the correct edition that is installed and boot into it. Then go into Recovery Console and wait for the c: prompt asking which windows you want to log into. Select 1 for C: windows. Then it will ask you for the administrator password. Enter it or press enter if there is no password. Type chkdsk c: /r at the c:\windows prompt and leave to run. It will take about 15 -30 mins. When finished, type exit and press enter. Press ctrl+alt+del to restart computer.
If problem is fixed, computer should start up fine now.
If you still have the problem, let me know so we can try something else.
Thanks,
Lolita
Jun 18, 2008 | Computers & Internet
Start up mode
I'd just do a factory disk reload for all your drivers and programs. Sounds like ddl are missing. Good luck.
Ed
NC Electronic
Mills, Wyoming
Jan 05, 2008 | E-Machines eMachines Desktop PC
Sony Ericsson K700 Logo
27 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
