I bought DM6 USB kit all the pads are working just fine except the hi hat controller is there any solution to this one. I try the same controller to my percussion pad it works fine. Did any experience the same problem here? Thanks in advance for your kind answers.
SOURCE: i own an Alesis dm6 mod. how to add cymbals.
I think your best solution is this> You can add 10 more triggers with it:http://www.alesis.com/triggerio
SOURCE: I had just recieved a brand new DM6. Upon setup
First thing to look at is the plug you are using a TRS, that is has three connections for the SNARE drum. If you partially put a TRS cable into the jack, the Tip will touch the Ring contact instead of the Tip contact. Now notice that the SNARE has a TRS plug while the kick has only a TS.plug. Could these be mis-labeled? The SNARE is the TRS and the kick is only a two conductor. If these are correct in your unit, then the jack in the kick drum itself must be broken and further that type of failure is really hard to visualize as it would require the tip contact of the jack to be drastically bent so that the plug has to be partially out to work.
So... first verify that the KICK cable has a two wire plug that is DIFFERENT from the three wire plug used on the SNARE (the snare has two pickups, one each for the head and rimshot) Should they possibly either mis-marked the cable plugs OR put the wrong plug on the Kick cable this would be the problem.
SOURCE: just got alesis dm6 usb
Hi Make sure to get any available drivers for the kit, because it's USB, it may not be recognized until you have appropriate drivers or upgraded software. Please get back to us if you have further query else please accept the suggestion. Thank you for contacting fixya.com
SOURCE: Alesis DM6 electronic drum kit module sound
It appears that you have to select a "Kit" of drums when using the external triggers. It appears that the volume level for the kit and that for each voice MAY all have to be set, especially after new firmware download. Read manual about KIT volume level and selecting voice and volume level for those. Manual is NOT very clear about these things and you have to try them as this is where the probllem is.
SOURCE: Alesis dm6 bass pedal
There's a tiny switch on the back of the module "kick type" try switching that
