Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
My Door get stuck when opening and I have to use emergency release and start over.
My garage door sometimes only opens about a foot, then gets locked and goes back down. I have to use the red emergency release cord and start all over. If I am outside of the garage when it happens I have to bang on the garage door really hard at the right place to open. This happens mostly when it is cold or if I have been out of town. What is the problem? Can I fix it or should I have someone come out?
  • 2 more comments
  • Twodor Nov 09, 2008
    I am having the same exact problem!!!!!!!
    Help fast, My wife thinks I am a bum because I fit just about anything,
    Not this??????????
  • dbihn29 Nov 12, 2008
    First attempt to open on a cold morning the unit reverses and closes after lifting 18 inches. Second attempt and all seems normal.
    If it is open for a while, when I attempt to close it (on a cold day) the unit closes about 18 inches then reverses.
    If I turn up the load to close, when I hit the bottom the unit overloads and opens. It takes several attempts to open or close on a typical cold day.
  • Crunkmin Nov 18, 2008
    Same thing here. I'm scared the horizontal brace is going to completely buckle one of these times. Has anyone uncovered any solutions yet?
  • wasekh Jan 23, 2009
    Same issue... on cold days it will not open all the way. Either by doorpad or remote. It will open 8 inches or so and if I can manually provide some support, it will open all the way. Does not have a problem closing. We wondered if it was a battery (but we are not even sure if it has a battery, that is how clueless we are!)
Buy an new opener. Not one problem with a new craftsman, even when it was -15 F.
Posted on Jan 20, 2009
  • 118 Answers
You probably have broken springs on the door
Posted on Jan 18, 2009
Stuck in up position against unit protector bolt . . . will not move with either control . . . unit only clicks . . . appears to have opened too far compared to other doors?
Der Randy,
If you want to learn to be a garage-door-opener-mechanic, now is the time to start.
I have done a dozen of these like this.
You start by unhooking the garage door from the track, by pulling on the emergency cord that is hooked to the connector, which releases the door from the opener.
( Now, you can work it by hand, until the opener is fixed.
Remember not to let it latch again until the opener is fixed. You must watch it.)
Then carefully take the stopper bolt out of the track, and if it is highly pressurized, watch out that it does not fly out and hit you in the face.
Nope, you should be free to adjust the chain travel, electrically.
There are two adjusting screws on the opener motor that will change where the door stops and starts.
You should be able to adjust these now to get the door to open and close properly.
Once it is working properly, attach the door to the opener assembly. God bless your efforts.
May 13, 2016 | Building Materials
How to open the door if no electricity
Almost all garage door openers have a switch mechanism that will allow you to open the door manually. It is usually a pull cord on the motor or track. Pulling it down usually deactivates automatic mode. Just pull it up into position when the electricity comes back on.
Garage Door Repair in Jacksonville FL American Garage Doors LLC
Mar 17, 2015 | Building Materials
I have a Merlin 230T garage door opener and it has started to run in the opposite direction. ie; it is closed now and when I use the remote control it tries to close more
Pull the emergency release handle. Use remote to open door then close it again with the remote. Now re engage the emergency release. That should put the chain in the right position for proper operation.
Aug 28, 2014 | Building Materials
I lost power last night due to a storm, I have power however my garage door will not open or close. The motor runs, however it is not grabbing. any ideas on how to fix???
Did you have to pull the emergency release and not return this into position. Pull the cord and move it until it clicks into position. Run the door and it should lock into place. If it does not reach this point. run the door to the open position and push the door back until it locks into the release.
May 26, 2011 | Sears Craftsman LiftMaster Chamberlain...
Have a Craftsman 1/2 HP Garage Door Opener, been working fine. Now when you start it you hear the motor running as normal but the chain doesnt move?
You must ensure the drive chain is engaged to the door puller.
Sometimes the emergency release if pulled (red cord) the drive and the coupling come separated.
Make sure the pin is back in place (pull release cord and make sure pin springs back in).
The run an open close cycle, it should pick up the drive again.
Please dont forget to vote this answer was helpful and accept my answer.
Many thanks
Feb 22, 2011 | Sears Craftsman LiftMaster Chamberlain...
My garage door sometimes gets stuck and then goes
Don't tighten the chain. It sounds like you have either a broken door spring or the drive gear in the motor unit is going bad. Release the opener from the door and operate it by hand. It should be easy enough to raise that your wife can do it with no problems and it should stay put when released about waist to shoulder high.
Jul 27, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Garage Door Opener - Gears need to be fixed
Unplug the unit and remove the cover, usually eight screws, if you see a lot of white dust in the cover check the nylon drive/worm gear, they will need to be replaced.
Apr 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
Where is the emergency release on Sears Craftsman Garage Door?
You can find exploded views and parts lists of the opener at
I just checked.
Feb 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain garage door opener won't close
read manual, if you have, on trolley engagement
May 30, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
236 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Are you a Sears Building Material Expert? Answer questions, earn points and help others
