XP INSTALLATION HOW CAN I LOAD XP IN HP PAVILION LAPTOP WHEN I INSERT XP CD IT DISPLAY THAT HARD DISK IS NOT DETECTED
  • 928 Answers
All you have to do is to access the BIOS then set the option of first boot device as CD then the second boot device as HDD or hard disk. When you turn on your HP you should see the option to go to the BIOS Setup sometimes its F2 or F12 or Del Depending on the type of motherboard you have on your laptop. Once you set it to boot from CD , when you startup your computer you should see press any key to boot from CD just press any key and it will boot. After the installation change back the first boot device.
If you have any other questions do message me back.
Posted on Nov 07, 2008
SATA Drive not detected while installing XP
You have to insert sata drivers to the Xp installation CD...
To do this go to this thread.."http://maxeasyguide.blogspot.com/2008/04/preparations-for-winxp-installation-cd.html"
or click here
hope this will help..cheers:)
Sep 25, 2010 | HP Pavilion dv6000z Notebook
Safeboot corrupted (error 92h)
Check the BIOS setting to see if the hard disk is detected. If not either the hard disk controller or the hard disk is faulty.
First thing I would try is to remove the hard drive and connect it to an USB hard drive adapter and then plug this adapter into a working computer's USB port. If this computer sees this hard drive as an external hard drive and you can open the various folders and files, then I would backup your data.
If the hard drive is not detected then the hard drive is dead and data cannot be retrieved with this method.
Retrieving data from damaged hard disk is possible. There are companies that can remove the disk platters from the damaged hard drive and with special equipment may be able to recover your data, but it will cost you an arm and a leg for their services.
Jun 24, 2010 | HP EliteBook 2530p Notebook
I bought a HP Pavilion ze4300 laptop and it has Windows XP on it and it was working fine for the past three weeks. Yesterday I started it up and am getting a message: ''Operating System not found''. One of...
It could also be the conncetion came loose, which can happen with IDE hard drives if the laptop gets moved around a lot. Remove the hard drive and take it to an electronics store to have it tested, or if you have a friend with an external enclosure (2.5" IDE interface, they cost between$10-20) you can hook it up to another computer via the USB port
Sep 25, 2009 | HP Pavilion ze2000 Notebook
Bought HP Pavilion dv2910tx,not able to install Windows XP. Help
If the install cannot detect the hard disk then the hard disk is faulty and needs replacing or the disk controller is faulty.
You can check if the hard disk is faulty by :-
Go into the BIOS and check if there a hard disk diagnostic.
If not then remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port.
If this computer see it as an external hard drive and you can view the contents of the drive then it is OK and the fault is the disk controller on the laptop.
To setup XP.
You insert the Windows CD and boot up the laptop with the CD.
You have done this correctly to get the hard disk error message.
Apr 15, 2009 | HP Pavilion dv2000t Notebook
XP on HP Pavilion dv2000
yes
because it's using an AHCI  SATA driver
there 2 ways to install XP on your laptop
  1. If you own an external floppy disk. You can insert the driver before the installation begin. the setup will ask you to insert third party driver by pressing F6 at the first of installation. Press F6 then insert your SATA driver. choose it. then setup will detect your hdd. you can download the SATA driver form here:http://drivers.softpedia.com/get/Other-DRIVERS-TOOLS/Others/HP-Pavilion-dv2054ea-SATA-Driver-550.shtml
  2. It's very hard to find an external floppy drive today, unless if you are an OEM or retailler. second way is you can insert the driver to XP installation CD, but it's very complicated. Or you can download a XP installation CD with sata driver here:http://fenopy.com/torrent/Windows_xp_sp3_5512_cdr_october_2008_with__sata_raid_/MTU2MTEzMA==/index.html
  1.
Jan 24, 2009 | HP Pavilion dv2000t Notebook
Problem in XP installation in the HP presario Note book
Sata hard disk does not require driver, however the sata controller which belong to any manufacturer may require. You have to go to driver cdrom, browse for IDE OR SATA if you cannot find it the clue is "RAID" find the RAID driver, you will also find the sata controller driver
example only: si3112.cat, si3112.inf, siblabla.bla....
copy all the files in folder (do not copy folder!! only files). Then put floppy disk in drive, make sure you boot from cd-rom.
Start XP installation then follow:
Press F6 for third party SCSI or driver installation at the beginning of text mode installation. Press 's' when setup asks if you want to specify an additional device, and insert the diskette then press 'Enter'. From the menu presented next, select the controller installation process that corresponds to the version of Windows being installed and press 'Enter'.
4. Press 'Enter' again when prompted to continue on with text mode setup.
5. Follow the setup instructions to select your choice for partition and file system.
6. After setup examines your disks, it will copy files from the CD to the hard drive selected above and restart the system. After restart the setup process will resume to finish the installation.
Good Luck
Damak
Jan 07, 2009 | HP Pavilion dv6000z Notebook
i think you have a sata hard disk drive.so go to cmos setup and in the cmos setup and please disable the sata drive there
Jan 04, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
For the laptop with no hard drive detected, this is most likely because Windows XP does not recognize SATA drives by default, which the laptop most likely has. To solve this, you will need to enter the BIOS setup utility (most likely Delete or F1 on startup). From there, you will need to change the drive mode to Compatibility mode. I'm not sure where this would be, but if you check in your laptop manual, you can probably find this somewhere.
For the 2519TU, download and install this for the LAN driver: ftp://ftp.hp.com/pub/softpaq/sp30001-30500/sp30264.exe it should work just fine.
Dec 23, 2008 | HP Pavilion dv9000z Notebook
How to install xp on vista compatable laptop
you might try formating the hard drive first then installing xp. or you could fix it to where it boots directly from the cd
Sep 24, 2008 | HP Pavilion dv6000z Notebook
I wan to format my laptop (HP Pavilion Entertainment Pc), but i don't how ? could you please help me out ?
In order to format and install operating system again you need a dos bootable floppy or cd to format....
Best solution is that try windows xp or windows vista bootable cd ,it will format your hardd drive and also will install the operating system....
Good Luck.
Please let me know your feed-back.
Thanks
dilipbagdi
Technical Associate
Apr 29, 2008 | HP Compaq Presario SR1575CL (PX808AA) PC...
Computers & Internet Logo
163 people viewed this question
David Payne
David Payne
