Minolta Magicolor 2480MF error code Please power Cycle (17H) Caution Machine trouble
  • 2 more comments
  • Anonymous Dec 03, 2008
    Please power cycle(15H)
  • pleiter Dec 15, 2008
    I have the same problem. Please power Cycle 17H. I cannot figure out what to do.
  • gioulik Jan 01, 2009
    I have the same problem,
    17H,
    magicolor 2480 mf
  • cfamory Apr 04, 2009
    i have the same problème (caution machine trouble power cycle please)
5 Suggested Answers
  • 214 Answers
SOURCE: Errors
Rack rotation failure, I'm not 100% that this is that error, but does the rack, where the toner are move ? if not, move it with manually a little bit then restart printer.
Posted on Dec 07, 2007
  • 214 Answers
SOURCE: Minolta Magicolor Fatal Error
17H means, the toner cartridge does not rotate (Incorrect developing
rack rotation)
its very difficult to fix, first thing you can check is a sensor, if you remove a remove a side cover above the paper feed. and clean it.
there is nothing much you can do.
FATAL ERROR CODE 18H /SERVICE CALL 18 FUSER UNIT: Faulty warm-up
detected
probably something wrong with thermistor or fu lamp is proken.
there is no simple fix for those problems. sorry
Posted on Feb 29, 2008
SOURCE: Service Call 17H
Thank you! Worked great. In my case I only got it after reinstalling my black cartridge; I only needed to spin it and replace that one to get it to reset.
Posted on Apr 15, 2008
  • 9 Answers
SOURCE: changing toner in a konica minolta 2480MF
http://kmbs.konicaminolta.us/productsattachments/manuals/magicolor2480MFUserManual.pdf
check page 92-101 in pdf or 82-89
hope this works
Posted on Nov 20, 2008
SOURCE: how do i fix the error message MACHINE TROUBLE
1. Main switch is tuned ON.
2. Press the following keys in this order
2 -> 6 -> 2 -> 7 ->3
3. Main switch is tuned OFF/ON
Posted on May 11, 2010
Caution machine trouble call c2558
No such code in the service manual of 4690
Apr 25, 2014 | Konica Minolta Magicolor 4690MF...
I have a FATAL ERROR CODE: 17H on my printer. What do I do?
It has to do with the toner. Please follow these directions: (from Minolta support website)
http://onyxweb.mykonicaminolta.com/newKB/KBDocument.aspx?id=TAUS0900423EN01&ptid=
Dec 02, 2009 | Konica Minolta Magicolor 2530 DL Laser...
WILL NOT PRINT ANYTHING OR COPY. IT WILL SCAN THE DISPLAY STATES: CAUTION MACHINE TROUBLE PLEASE POWER CYCLE (18H)
Check fuser unit. Fuser does not reach the cpecified temperature within specified time, or will be low mains voltage...
Apr 23, 2009 | Konica Minolta magicolor 2480 MF...
Fatal Error 17H
If the machine is under warranty then take it back to where you purchased it, or contact konica minolta directly and push for machine replacement.
Nov 01, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Where are the toner cartridges in magicolor 2300 dl
FATAL ERROR CODE 17H / SERVICE CALL 17 TONER RACK: Incorrect developing
rack rotation
open door, remove waste toner box then you have to find a small switch in left side and push it wit screwdriver or something, then you can rotate the toner rack manually. then install the waste toner box again and power up printer.
Sep 01, 2008 | Konica Minolta magicolor 2300DL Laser...
Magicolor 2480 MF
My printer won't print after i had a paper jam
Jan 07, 2008 | Konica Minolta PagePro 1350W Laser Printer
Konica Minolta Magicolor 2300 DL - Fatal Error Code 0EH ????
I had the same problem one time, they told me to pull out all of the toner cartriges, power off, power on, power off, replace all cartridges and the problem went away.
Who knows why. If this doesn't work....
Call Konica Minolta tech support.
They were pretty helpful to me.
Dave
Nov 28, 2007 | Minolta magicolor 2300W Laser Printer
Errors
Nov 14, 2007 | Konica Minolta magicolor 2430 DL Laser...
447 people viewed this question
k24674
