Question about Metrologic Instruments 9520 Voyager
MS9520 serial connected to the terminal - does not send keys to the terminal server
MS9520 connected to COM1 is working properly at the workstation, using Softwedge. Keys sent are seen in Notepad. But when I login to the terminal server, keys are not sent. In the terminal connection configuration dialog "serial ports" is checked. In the session client port is seen as TS033 (MyPC:COM1). Please give me a hint, how should I configure the scanner.
Ok this is an old questions, but I had a similar problem recently. I found that I had to install Softwedge on the Remote computer.
I was trying to use the scanner over remote desktop. Remote dektop needs to have serial communication enabled. The computer that you are connecting to via RDP needs to have softwedge installed.
Posted on Oct 22, 2010
Port Forwarding On Linksys RV016
it's a rather lenghty explanation so please go to this site and follow the instructions...
http://portforward.com/english/routers/port_forwarding/Linksys/WRT54G/
Robert
Please rate this solution ... thanks
Sep 08, 2008 | Linksys RV016 Router
Communication port is not working properly
COM1 and COM2 refer to a computer's communications, or serial, ports. COM1 ports are often used on older PCs to connect network devices, digital cameras and mice. Faulty drivers software that enables the hardware to communicate with the operating system or incorrect hardware configuration can influence COM1 behavior. In rare cases, the expansion card that adds the serial ports to the PC can fail, rendering both COM1 and COM2 ports useless. To repair a COM1 port, you must determine what is preventing the port from working before attempting a solution.
Click "Start." Go to "Control Panel" and then click "Hardware & Sound." Select "Device Manager" from the submenu. Expand "Ports (COM & LPT)." Double-click "COM1." Review Device Status on the General tab to check for problems with the software driver. If the message "The Device Is Working Properly" appears, click "OK" to close the window; otherwise, look up the error message on Microsoft Support. Follow the directions in the Knowledge Base to correct the issue. Press "Alt" and "V" to open View. Scroll to "Resources by Type." Press "Enter." Double-click "Interrupt Request (IRQ)" to see a list of devices. Double-click "Communications Port (COM1)." Check the term to the left of COM1 to see if the card uses an ISA or PCI interface. If the card uses a PCI interface, it can use the same IRQ as another PCI device without producing a hardware conflict. If the device is ISA, it needs its own IRQ. Go to the "Resources" tab. If "No Conflicts" appears in the Conflicting Device List, close the window; otherwise, uncheck "Use Automatic Settings." Click the drop-down menu and select each configuration until the port no longer interferes with another device. If conflicts occur with each configuration, double-click "IRQ"; you may need to try different configurations before Windows gives you permission to edit the interrupt request. Click the up or down arrow to change the IRQ until the message "No Devices Are Conflicting" appears in the Conflict Information field. Click "OK" to close each window. Click "Yes" when prompted. Connect a device to the COM1 port to test the port. If the device doesn't respond, shut down the computer and then unplug the power cable. Disconnect all devices from the back of the PC. Remove the case cover and touch the computer's chassis. Set the computer on its side so that the PCI and ISA cards sit at a 90-degree angle to the floor. Find the serial ports on the back of the PC. Look on the opposite side of the case to find the associated card. Shine a flashlight onto the card and make sure that the copper contacts are not visible. If you can see the contacts, reseat the card in its slot so that it's fully installed to the motherboard. Reassemble the case and boot into Windows to test the COM1 port. If the port still fails to work, you may need to replace the serial port card.
Jan 16, 2013 | Computers & Internet
PLZ SEND ME THE IDM V6.05 SERIAL NO I HAVE A PROBLEM IN REGISTRATTION PLEASE SEND IT IMMITEATELY TO MY ID
you cant register IDM with a serial number as it is checked by the IDM servers every time you connect to the net. so i'm sending you a link to a patch file download it and copy that file to the directory where you installed and run it. click "patch server check" then use the provided serial number to register. (make sure you terminate IDM service before patching)
here's the link: http://hotfile.com/dl/121777755/e30deb8/SnDkp.exe.html
Jun 20, 2011 | Computers & Internet
Problem with serial connection with AMD motherboard
Software that accesses serial ports usually allow you to specify WHICH port you want to connect via.
Your new board should have COM1 and possibly COM2... but perhaps your old setup was running from COM3?
Connect the Casio to COM1, and check the software you are using... set that to "look" at COM1 also. That should work!
Apr 20, 2009 | Casio Serial RS-232 Cable (CELL-300)
100m cable lenght limit
Hi!
You acn always set up an access point in the midle, that will give you another 100m, and uf thets not enough set up another one.
Good luck
Nic
Feb 27, 2009 | Computers & Internet
How to limit remote access to a Termional Server
The best way to do this that I've found is to restrict the access via your firewall. Typically, Terminal server is listening on port 3389. So you would create rules in your firewall that will block any traffic to this port from IP addresses or subnets that you don't trust. While you're at it, you should shut down all other ports to everyone if you're not using them.
Mar 27, 2008 | Dell PowerEdge 1550 Server
Toshiba PA1390U-1NKP fails under Windows Terminal Services from XP to Svr 2003 R2
I don?t have the equipment to test your setup; however, I suspect your problem is in redirecting the device to the terminal server session. Check the terminal server system event log file to see if you are generating any messages when you connect. When my users have issues, typically with printers, they will be listed in the log as *Errors* and the source will be *TermServDevices*. If you?re using the latest Remote Desktop Client there is a tab in options called Local Resources which is used to deal with configuring your workstation sounds, keyboard, printer, and other local resources to redirect to the terminal server. Click on the More button at the bottom and you will be taken to the more generic section of resource redirection that deals with other items. Your device is probably USB so if it is going to work is would fall under the scope of the section labeled *Supported Plug and Play devices*. You would start by placing a check in that box, reconnect and see if you keypad works now or if anything shows up in the event log. Let us know how this turns out and if you have any other questions. As always please don?t forget to rate this post.
Apr 03, 2007 | Toshiba PA1390U1NKP Keypad
F505 serial connection is dead.
Had the serial port working before? If not, try this, disable the infered port and click start choose IBM Thinkpad 760 open it and locate the com1 (serial) and enable it. It should work fine. Goodluck.
Sep 11, 2005 | Sony Cyber-Shot DSC-F505 Digital Camera
Metrologic Instruments 9520 Voyager Logo
1,205 people viewed this question
Top Metrologic Instruments Computers & Internet Experts
Gareth Cockram
Gareth Cockram
xak_tay98
Level 1 Expert
Daniel Dollive
Daniel Dollive
Are you a Metrologic Instruments Computer and Internet Expert? Answer questions, earn points and help others
