Question about HP iPAQ RZ1710 Pocket PC
How to change battery?
I have removed 4 screws, but the back is reluctant to come off
Hi there:
once the screws are out:
you just need to pop out the back case in order to see the mainboard of your pocket pc.
try first whit your nails, and if you can't, then use a plane screwdriver.... but try firs whit nails cause screwdrivers can harm or scratch your case.
and tata you´re ready to change the battery....
find a guide whit pictures here.....
http://www.ipaqrepair.co.uk/guides/HP%20iPAQ%20rz1700%20Battery%20Replacement%20Guide.pdf
Enjoy your PDA... i love mine.
Posted on Dec 28, 2008
DOES IPACK 1710 DOCKING STATION ALSO CHARGE THE BATTERY
Posted on May 12, 2010
There is a small screw under the warranty void sticker. Take that out and the cover should just pop out.
Posted on Apr 07, 2009
How to open an i phone 3gs 32GB
https://www.youtube.com/watch?v=FWAS5WmpM-4
Feb 24, 2015 | Apple iPhone 3GS Black (16 GB)
TomTom 0ne
There are 4 screws:
1. Remove front bezel
2. unscrew 4 small screws (1 hole has anti tamper tape over)
3. remove "dome" rear of unit.
4. Remove 2 screws holding speaker in
5. Carefully remove all metal tape covering electronics
6. Remove 4 small screws securing PCB to unit
7. Remove 2 screws holding black plastic battery clip
8. Unplug small battery connector from PCB board.
9. remove battery and insert new one
Nov 09, 2007 | Tomtom ONE GPS Receiver
Battery change on a stud finder
I need to know the brand/model#. My stud finder has a release tab on the underside and it's easy access. Can you snap a picture and repost?
Nov 21, 2013 | Vacuums
How to change the battery in my iphone
Is it a iPhone 4 or 5 If it's the 4 the two screws on the bottom need to be removed and the back panel you push up with your thumbs and pull it off (very easily removed) the batter is held in by a connector that is held in with a very tiny screw remove the screw very carefully pull up the connector and then you can pry the battery out it will be held in with a lot of glue
Oct 31, 2013 | Cell Phones
I have a Steinhausen TW524L Watch how do i change the battery or is this watch automatic it has stopped running.
It's not as easy as popping off the back like some watches to replace the battery. The 4 screws on the top bezel are not the ones to remove. Look at the back side of the watch and you'll see 4 really tiny pinholes. You'll need a jewelers screwdriver small enough to fit into the holes to remove the 4 screws. Once you do that, the two halves of the watch come apart with a little pressure. It takes a little prying to get the case to separate. Once you do that, you'll see the battery. Be careful with the waterproof gasket as you'll need to put that back in the same position to keep the case sealed. The gasket is really delicate. You might consider taking it to a watch maker to change out the battery if you don't have the tiny (and I mean really tiny) screwdriver to remove the 4 back screws.
Nov 12, 2011 | Watches
How do i change the battery on an hp 10s calculator
Steps
1.Remove the two screws on the back cover using watchmakers screw driver
2. Use a 4mm this flat screwdriver blade and remove the back cover by twisting it
3. Replace the battery [LR55] , put the cover back by pressing and replacing the two screws
4. Your calculator is ready to use
Aug 10, 2011 | HP 10s Scientific Calculator
Change batteries
1. Remove slide cover. Place calculator face down.
2. Using a small Phillips screwdriver, remove screws
from back case.
3. Remove back case.
4. Remove discharged batteries.
Caution: Avoid contact with other calculator
components while changing batteries.
5. Install new batteries positive side up, as shown on
diagram inside case.
6. Replace back case, and then replace screws.
7. Press OFF ON ON.
Caution: Dispose of old batteries properly. Do not
incinerate batteries or leave where a child can find
them.
Your calculator cannot hold data in memory when
batteries are removed or become discharged.
Feb 02, 2011 | Texas Instruments TI-30XA Calculator
Directions for changing battery
2. Using a small Phillips screwdriver, remove screws from back case.
Caution: Avoid contact with other calculator components while changing batteries.
5. Install new batteries positive side up, as shown on diagram inside case.
7. Press: [OFF] [ON] [ON].
Caution: Dispose of old batteries properly. Do not incinerate batteries or leave where a child can find them.
Your calculator cannot hold data in memory when batteries are removed or become discharged.
Nov 27, 2010 | Texas Instruments TI-30XA Calculator
How is the backup battery charged and or changed
Remove top (side thumbscrews)
remove main battery cover and battery
unscrew stylus holder from back (1 screw)
unscrew black plastic inner top (4 screws)
remove top gasket
unscrew back (6 screws)
carefully remove back
CAREFULLY NOTING THE POLARITY OF THE PLUG:
carefully unplug connector from back
unscrew plastic cover over the speaker & backup battery from inside of back cover (4 screws)
replace battery w/ Digikey #P084-ND
23x2mm 3volt 30mah lithium battery ~$6 USD in 2010. aka Panasonic #VL2320/VCN
this requires you to re-solder the ex. leads to new battery*
*WARNING ASSUMES YOU ARE ABLE TO CHECK THE POLARITY AND KNOW HOW TO SOLDER SMALL ELECTRICAL COMPONENTS.
YOU ARE ON YOUR OWN HERE AND ASSUME THE RISKS THAT THIS TYPE OF GADGET HACKING ENTAILS!
(Optional - find an original replacement battery from Panasonic with the correct leads attached and just plug it in. This is much safer.)
Reverse operations and you are back in business.
Jan 26, 2010 | Panasonic Toughbook CF-P1
Battery cover replacement for the Dimage Z2
to get to the battery door you must remove the back, to remove the back you must remove the top of the grip (shutter button and dial and WT lever). remove top of grip... 1) starting at the bottom of the plastic strip (along the front edge of the grip) that holds the shutter button, slide upward, the strip will bow outward and after about 3/16", the bottom's free. the only other thing holding it in place is a bit of double-stick tape and a similar clip at the top. CAREFUL! there's a spring under the button that's easy to lose. 2) Inside the battery case, front battery, all the way at the top, there's a tiny phillips screw, pull it. 3) peel away the right side rubber grip right by where your thumb meets the W on the W/T lever. 1st hole you'll see is a springy clip, keep going around to the right til you find a screw. pull that. 4) back to the springy clip hole, pushing inward on the finger, the top will come off straight up. leave it hanging, you just need it out of the way so the back can come loose. remove the back... 5) bottom of camera, remove 2 screws nearest the CE label and one outboard of the rearmost battery. 6) viewfinder cap: 4 screws, skinny on top, fatter on the bottom. the cap pops off. 7) lcd cover/frame: pull away from viewfinder(top) edge about 1/4 inch. the bottom's held by fingers; they need to slide to the left 1/8", then that's off. 8) remove screw @ lowerleft of lcd. now the whole back will slide rearward. 1st thing loose is memory door, remove it. slide the back off, out of the way. you'll now see that the battery door is held on by two hinge pins, not one continuous. the rearmost pin will slide left into the memory cover area, and the door will flex enough to remove it toward the front. trickiest part of reassembly is the spring under the shutter button. balance the spring on the camera, put the button into place. hold it in place with the screwdriver through eye of plastic strip, leaves plenty of room to seat the strip. lose a screw? I did, and the least-needed one is the one pulled at #3. NOW who needs to buy a battery door? I have a z3 with a fried power board.
Mar 20, 2008 | Konica Minolta DiMAGE Z2 Digital Camera
HP iPAQ RZ1710 Pocket PC Logo
440 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
