ASUS P4V8X-MX Motherboard
Problem for ASUS P4V8X-MX Motherboard
Pc restarting by itself.
By Danyto on Oct 16, 2006
I just swicht from an asus p4p800mx to a p4p8x- mx because the first one somebody in the house passed the vaccuum cleaner next to it and pulled a lot of cables from the computer and it was recognizing any of my periferial devices or my dvd rom or cd rom. So when I did the change the problem that i am having now is that when the computer tries to start windows it restart itself can you guys help me on this one, I checked all my cables and connections are alright I even did all the connections outside the case just in case that the case was causing the proble but is not. So what could it be?
Same Problem
Dec 28, 2007
-   I'M HAVING THE SAME PROBLEM LIKE YOU-   bemb
Nov 22, 2007
-   when i turn on the automatic voltage regulator (avr) the fan of my CPU will automatically run even if my computer not yet already push the power botton. But when i check my cdrom drive to connect in the ide it works but no any display on the screen. what shall i do?-   john paul
Best Solution
posted on Feb 03, 2007
Helpful)
MBall4701
Rank: Master
Rating: 74%, 18 votes
I would verify all the fans are spooling up does it POST can you get into the bios? try and get into the bios and verify the temperature of the CPU and or the video card.
Was this helpful?
Yes
No
Solution #2
posted on Oct 16, 2006
Somewhat Helpful)
habib_101
Rank: Wiz
Rating: 79%, 458 votes
Try reapplying thermal compound to the CPU and reseat it. It might just be heating up and restarting due to the heat.
Was this helpful?
Yes
No
Solution #3
posted on Apr 02, 2007
Not Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
i doubt that the board will last long because the mobo slowly bends in time due to the stress from the heatsink clip
Solution #4
Not Helpful)
asmary
Rank: Apprentice
Rating: 55%, 2 votes
it may be a ram problem , so ghane the ram and make it bigger
Comments:
Feb 03, 2007
- it may be a ram problem , so change the ram and make it bigger
Was this helpful?
Yes
No
Solution #5
posted on Jan 29, 2009
Not Rated)
thrazel
Rank: Guru
Rating: 85%, 54 votes
Try to change your RAM maybe your RAM is not compatible in your Motherboard
Was this helpful?
Yes
No
Solution #6
Not Rated)
dalogdennis
Rank: Master
Rating: 77%, 7 votes
the operating system is corrupted. restart, press F8 then restore it. If it won't work, reinstall the Operating system.
Was this helpful?
Yes
No
Solution #7
posted on Apr 28, 2008
Not Rated)
uday_r
Rank: Guru
Rating: 88%, 89 votes
I Think ram problem Do onething first remov system ram just clean and put in same Place. ok byy
Was this helpful?
Yes
No
Solution #8
posted on Dec 12, 2007
Not Rated)
benrussia
Rank: Apprentice
Rating: 97%, 5 votes
dsg
Was this helpful?
Yes
No
Solution #9
posted on Oct 06, 2007
Not Rated)
syed123
Rank: Master
Rating: 79%, 50 votes
plz install the operating system
Was this helpful?
Yes
No
Solution #10
posted on Apr 24, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Try restarting the system in safe mode by tapping on the F8 key as soon as the power button comes on. Then go to system properties, choose advanced and then click the settings button under start up and recovery. Then uncheck the option "automatic restart" under the system failure. Turn your system off and then restart, you should get a Blue screen with a hexidecimal number that starts with 0x, record that number and then give it to Tech support or look up possible solutions on the net.
Solution #11
posted on Feb 17, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
If your using windows XP then most likely windows needs to be reinstalled. Both motherboards are using slightly different chip sets, and windows XP installs itself specifically to the motherboard is set up. If the motherboard is changed it will ether BSOD or reboot without warning as it tries to treat the new board the same as the old one.
Solution #12
posted on Feb 14, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
first see the switch button is pussed .
second may power supply wold cause , because
some capacitor inside power supply will be
damaged due to that the computer will
restart again and again , or may be fan of
hit sink is not working as much requred parameters requred by cpu .
Popular Solutions for ASUS P4V8X-MX Motherboard
Questions and Unsolved Problems for ASUS P4V8X-MX Motherboard
Do you recommend ASUS P4V8X-MX Motherboard?
Answer
Answer
my dell laptop keeps to going to a blue screen
Answer
How do I find the latest error codes for my motherboard?
Answer
Replaced the photodeveloper cartridget last week and now I'm getting a grinding sound as it prepares... (More)
Answer
i need to know how to install the jetchip module on a 1993 Ford F-150 with the 4.9 inline 6 cyl.... (More)
Answer
trying to get the Medion M3 DIRECTOR 4000 specs,where can I find that? thanks
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Motherboards Experts
Top Computer & Laptop Repairmen
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
