Question about RCA D61W20 61" Rear Projection Television
RCA HDTV #D61W20, CHASSIS ITC222, Power button flashing 1, pause, 9. Possible error code 19, anyone know what this means
When power button is pressed, the power light comes on, I hear a small click in the back and then the light goes off again. It will repeat the same process 2 more times for a total of 3. After numerous attempts, TV finally comes on as I can hear the screen make that popping sounds before tvs come on. I've read through previous posts and have heard of 3 possible problems. Bad Power Supply, Bad Capacitors, and Bad Flyback. Is there anyway I can check to see which problem I am having? I have a background in computers but not tv's, but I do have basic soldering skills. Any help would be greatly appreciated, Also, If I hold down the power button i get what I believe is a series of Error Codes.. Mine I think is Error 19, as in I get 1 flash, pause, the 9 flashes. Does anyone know what this code is? Would make troubleshooting alot simpler!
  • 3 more comments
  • jmarshalls19 Dec 03, 2008
    RCA HDTV #D61W20, CHASSIS ITC222 I received this tv from a friend .he said a tube was out and needed to be replaced the tube is blue P16LXLOOBMB shouldn't be a problem.the tv light comes on for 3 seconds and turns off (you can here the sound of the tv starting up),it will do that three times then the light stays off for 1-2 minutes before I can attempt to get it to start the cycle again.I held the power button in and recieved a code 19 also whats this mean,any help would be nice. thank you Joshua S
  • stevencraig8 Dec 07, 2008
    same as the others got the tv from a friend said mayba some rats chewed the wires but no chewed wires power button comes on for a second the blinks a few times thats it
  • sunnysig1078 Dec 30, 2008
    I have the exact same problem with the same tv do you know how to fix it.. i hate to just toss it to the curb.
  • Johnny Blaze Apr 01, 2009
    Actually an easy fix.. Change the flyback (259296), and the 3 capacitors (CL114, CL120, CL150).. total of about 60 bucks. All you need is a Soldering/Desoldering gun, Torx bit, and about an hour. Works like new!!
  • Anonymous May 18, 2009
    i have the same problem but where can i buy the parts from thanks
    Problem Solver:
  • 8 Answers
This is not a friendly chasis, the only easy fix that you might check on the power supply board and the left side (looking from the back) 3 capacitor (220,330,and 2200uf 16V) have the top pop up. Other than that poping, arcing noise, burn smell when first start up is bad york, Flyback Transformer and even the cooling leak for those tubes you will need professional TV repair man. Those TV picture not very nice anyway.
Posted on Jan 06, 2009
4 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: Need Flyback Part Number
You need flyback number 259296 you can get a replacement at the following link for under 50.00 with free shipping
http://servicemanuals.vstore.ca/
Posted on May 20, 2008
Slinteriors
  • 8617 Answers
SOURCE: RCA HDTV #D61W20, CHASSIS ITT222
you will need a new flyback number 259296 and also a new cp150 which is a 2200uf 25V radial capacitor. You can get replacements at the following link and they provide free installation instructions.
Posted on Sep 19, 2008
SOURCE: RCA HDTV #D61W20, CHASSIS ITC222, PUSH & TWIST CAP ON HV CABLE
do you have the part number for the flyback ? I need it if you would please. send it to
swampbiker@hotmail.com
thank you
Posted on Jul 20, 2009
While watching tv, there was a faint "pop" and the tv went dead. it will not turn on by front buttons or remote.
Does the power indicating flash three times then go out when power is pressed? If so you may need a deflection board which is famous for problems with the ITC222 chassis.
May 02, 2011 | RCA HD52W59 HDTV Projection Television
My d52w20b rca tv will not turn on and if you hold down the power buton down the led flashes a code 19
All the ITC222 series will blink 19 if they have a no start situation regardless of the problem, Since the set wont power up the Main eprm cant communicate so it blinks 19 which means it cant identify the chassis. When you press the power to turn it on does the power light come on briefly then go out 3 times? Let me know and I will assist you with the problem. Also do you hear any sounds when the power is pressed?
Nov 27, 2009 | RCA D52W19 52" Rear Projection Television
Flashes/blinks 9 then 5 won't turn on.
Check the CRTs . That model was notorious for laser like cuts right around the neck by the yoke. I just had one today doing the same thing. The CRTs are no longer available so the set is scrap. I hope that's not your case. Let me know.
Oct 20, 2009 | RCA D52W23 52" HDTV CRT TV
D61w20 rca turns on and off
I have a RCA D61W20 chassis ITC222, I had the same problem and my repair guy found out the blue bulb was the main problem, along with replacing some transisters on one of the power boards, He also had to adjust the service convergence (not auto convergence). Works great now!
Aug 27, 2009 | RCA D61W20 61" Rear Projection Television
Who does in home TV repair have an RCA D61W20 or can it be done m
The most obvious item which is causing your problem are the 220K ohm 1/4 watt resistors on the convergence power supply board. There are four of them RP10, RP11, RP12 amd RP13
Jun 18, 2009 | RCA D61W20 61" Rear Projection Television
thank you
Apr 01, 2009 | RCA D61W20 61" Rear Projection Television
No power
Check the ribbon cable connections between the boards to insure they are correctly seated as a 19 code usually means
Chassis detection, which means its not detecting a valid chassis usally the ribbon connections are the cause of that.
Jul 31, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
19, signal 19, 19, what is it trying to tell me?????
The only error code 19 for the ITC222 chassis listed from RCA/Thomson for 19 is invalid chassis detected. Which doesnt make sense unless you have replaced a PCB with a wrong part number.
Jul 22, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Doesn't stay on
power supply is bad needs replaced
Apr 05, 2008 | RCA D61W20 61" Rear Projection Television
RCA D61W20 61" Rear Projection Television Logo
1,942 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
