Question about Sanyo DS27510 27" TV
How to test the voltage regulator
I need to test the voltage regulator which is a c4423. I would like to know what readings i should be getting.
    Sergeant:
  • 337 Answers
The only test you can do on this regulator is to see if is shorted or not,this is a switching regulator ,that means is design to be use in a switching power supply witch turns the transistor on and off constanly and uses feedback to stay regulated,the B+ they use in the collector is around 150 volts,an small square wave is applied to the base ,it gets amplifies and energizes the primary side of the transformer to generate all the supplies ,one of this supplies provides the feed back.I hope I have given you the more than the information you needed.
Posted on Oct 16, 2006
  • Omar Urrutia
    Omar Urrutia Oct 16, 2006
    Your rating response is also important.
  • Omar Urrutia
    If you need to measure the collector try using a different point with the correct ground.
My gilera seems to have voltage drop and cause my engine to cut off when i press my brake.
Hi, Herman the following is a comprehensive charging system test that is guaranteed to the find issue with your system.
1. Battery Test: The battery needs to be a fully charged and load tested to ensure proper readings, connections need to be clean and tight. If you are not working with a fully charged and functional battery, all other voltage tests will be incorrect. Standing battery Voltage should be 12.5-13.2 DCV.
2. Charging System Voltage Test: Start motorcycle, measure DC volts across the battery terminals you should have a reading of approximately 13.2-15 DC Volts.
3. Check Connections/Wires: Inspect the regulator/stator plug, and check the battery terminals for connection/corrosion. If everything seems to be in order, move on to number 4 below to determine if there's a failed component.
4. Stator Checks/Rotor Check: Each of the following tests isolates the Stator & Rotor. If AC Output test Fails and Resistance Check, and Stator IB Test Pass then Rotor is at fault (Pull Primary covers and inspect rotor for damage).
5. AC Output Check:
Unplug the regulator plug from the stator
Start motorcycle and change Voltmeter to AC volts.
Probe both stator wires with your meter lead.
The motorcycle should be putting out approximately 18-20 ACV per 1,000 rpm. Reading will vary depending on system, check service manual specification
Generic Specs:
22 amp system produces about 19-26 VAC per 1,000 rpm
32 amp system produces about 16-20 VAC per 1,000 rpm
45 amp system produces about 19-26 VAC per 1,000 rpm
Stator Resistance Check:
Switch your multimeter to Ohm x 1 scale.
Probe each stator wires with meter leads and check resistance on the meter.
Resistance should be in the range of 0.1-0.5 Ohms. Reading will vary depending on system, check service manual for specification
Generic Specs:
22 amp system produces about 0.2 to 0.4 ohms
32 amp system produces about 0.1 to 0.2 ohms
45 amp system produces about 0.1 to 0.2 ohms
Stator IB test or Ground Check:
Probe each stator wire with your positive lead on the multimeter and the negative to ground.
There should be no continuity to ground on either wire.
If there is continuity to ground your stator is shorted to ground.
5. Regulator Test: Each of the following tests isolates the regulator only, so if any of these tests fail, the regulator is at fault.
Identifying Wires:
Battery Charge Lead- Wire going from regulator to battery positive.
AC output leads- Wires coming from the Stator to the regulator.
Ground- Wire from Regulator to ground or regulator may be grounded via the physical bolting to chassis.
Regulator Ground Test: Ensure the regulator body is grounded or grounding wire is fastened tightly to a good ground (you should verify this by checking continuity from regulator body to chassis ground).
Fwd/Reverse Bias Test/Diode Test: This check is testing the Diode function to ensure it is regulating the AC current for the stator into DC Current.
Switch multimeter to Diode Scale.
Place your Multimeter positive lead on each AC output wire.
Place your multimeter negative lead on the battery Charge wire.
The meter should read voltage typically around .5 volts.
Next, switch your multimeter leads putting the negative lead on the AC output wires and the Positive lead on the Battery Charge Wire.
The reading should be Infinite.
With your meter on the same setting, place your multimeter positive lead on the regulator ground wire or to the regulator directly, and then place your meter negative lead on the AC output leads.
Next, switch your multimeter leads putting the negative lead on the regulator ground and the Positive lead on the AC output wires.
Note: Below is a table to show the readings:
Positive Lead Negative Lead Reading
AC output 1 Battery charge lead Voltage
AC output 2 Battery Charge Lead Voltage
Battery charge lead AC output 1 ?
Battery charge lead AC output 2 ?
Ground AC output 1 Voltage
Ground AC output 2 Voltage
AC output 1 Ground ?
AC output 2 Ground ?
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
http://www.jetav8r.com/Vision/Stator/fault_finding_by_www.electrosport.com.pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Feb 21, 2017 | Gilera Motorcycles
Alternator or Voltage Regulator or Other?
You will need to test the charging system. Try this simple test, hook a voltmeter to the battery and check the voltage with the key turned off. Should be 12 volts. Now start the engine and note the volt meter reading at idle, it should go up to about 13.8 - 14.2 volts. Rev the engine up and note what happens. If the voltage is low at low RPM 12V and then goes up with more RPM like you stated it could be the regulator or the alternator. Start by switching out or trying another voltage regulator. If this does not fix the problem you will need to test and repair the alternator. The alternator out put can be tested by bypassing the regulator. This requires special equipment and know how. I hope this gets you
Jun 30, 2015 | Honda GL 1500 SE Gold Wing Motorcycles
1987 Yamaha Virago XV 1000 not charging
Hi, Anonymous before testing any electrical component in the Charging System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead acid batteries.
1. Battery Test:
3. Connections and wires:
Inspect the regulator stator plug, and check the battery terminals for connection corrosion. If everything seems to be in order, move on to number 4 below to determine if there's a failed component.
4. Stator Checks/Rotor Check: Each of the following tests isolates the Stator & Rotor. If AC output and resistance test fail and stator test passes then the rotor is at fault (Pull Primary covers and inspect rotor for damage).
5. AC Output Check:
Unplug the regulator plug from the stator start motorcycle and change Voltmeter to AC volts. Probe both stator wires with your meter lead. The motorcycle should be putting out approximately 18-20 ACV per 1,000 rpm. Reading will vary depending on system, check service manual specification
Generic Specs:
Switch your multimeter to Ohm x 1 scale. Probe each stator wires with meter leads and check resistance on the meter.
Resistance should be in the range of 0.1-0.5 Ohms. Reading will vary depending on the system, check the service manual for specifications.
Generic Specs:
5. Stator Ground Check:
If there is continuity your stator is shorted to ground and must be replaced.
6. Regulator Test:
Identifying Wires:
Battery Charge Lead- Wire going from the regulator to battery positive.
Regulator Ground Test: Ensure the regulator body is grounded or grounding wire is fastened tightly to a good ground (you should verify this by checking continuity from the regulator body to chassis ground).
Next, switch your multimeter leads putting the negative lead on the AC output wires and the Positive lead on the Battery Charge Wire. The reading should be Infinite. With your meter on the same setting, place your multimeter positive lead on the regulator ground wire or to the regulator directly, and then place your meter negative lead on the AC output leads.
Next, switch your multimeter leads putting the negative lead on the regulator ground and the Positive lead on the AC output wires. The reading should be Infinite.
For more information about your issue and valuable "FREE" downloads for viewing and printing that you will need please click on the blue links below. Good luck and have a wonderful day.
https://www.viragohelp.com/virago-charging-systems
http://racetechelectric.com/files/pdf/rte_troubleshooting_flow_chart.pdf
http://service.tanga-moteurs.ro/data/yamaha_virago_535_700_1100.pdf
OEM parts for Yamaha
Yamaha Virago XV1100L Owner Manual
Jul 17, 2017 | Yamaha Motorcycles
17 hp briggs stratton
Hello there. My name is George. In regards to your problem, there are a few things you need to know. Make sure both battery cables and post are clean and tight. Also check the two bolts holding the voltage regulator onto the side of the engine. A loose voltage regulator will not have the proper grounding to function. Underneath the flywheel is a device called an stator. This stator creates an alternating current or commonly called A/C Voltage. This voltage travels to another external device called an Voltage Regulator. The voltage regulator converts the A/C voltage from the stator to Direct Current or commonly called D/C Voltage to the units battery. Using the Model, Type and Code numbers found on the valve cover, you can call any parts store and they should be able to tell you what type of charging system you have, (i,e. 10 amp, 20 amp etc.) Ask them what the A/C voltage should be coming from the stator. I believe it will be at least 28 to 30 volts a/c. You can measure this voltage by using an ohm meter set to a/c~volts. You must have the engine running full throttle when you do this test. The ideal rpms for this test is 3600.
You would need an tachometer to get it perfect, but full throttle usually gives an a/c output around 28 vac Now with the stator and voltage regulator disconnected and the engine running at full throttle, use the red and black test leads from the ohm meter and put the tips into the wire connector, red on one wire and black on the other. No, it does not make a difference which wire. Read the meter. If it shows the voltage the parts store told you (around 28vac is my guess, then your stator is doing its job. If it is giving you anything less than that the stator is bad. If it is bad, you will need to remove the flywheel to inspect it and or replace it. If its good, Turn off the engine and reconnect the stator and voltage regulator. Now find the single wire coming from the voltage regulator (its normally red) and disconnect it. This wire is the d/c voltage connection going to your battery. Set your ohm meter to d/c volts. Start the engine and let it run full throttle while you put the red test lead into the red wire coming from the voltage regulator and the black to a good ground. If you cant find a good ground then use the negative -(Black) battery post. If you read around 13 to 14 volts d/c then your voltage regulator is good and you have a shorted wire from the voltage regulator to the battery, If its bad then it will read 0 and it will need to be replaced. Feel free to contact me at: flynow_1@hotmail.com if you have any other questions. Good Luck.
Aug 20, 2013 | Briggs & Stratton Garden
Charging voltage to high, cooking batteries and head lights
Hi, Anonymous you may need a new voltage regulator the following is a comprehensive charging system test that I found on a Rider Groups website 1. Battery Test: The battery needs to be a fully charged battery that has been load tested to ensure proper readings. If you are not working with a fully charged and functional battery, all other voltage tests will be incorrect. Most places like Auto Zone, Advance Auto, and Pep Boys will charge and test motorcycle batteries for free. Standing battery Voltage should be 12.5-13.2 DCV.
2. Charging System Voltage Test: Start motorcycle, Measure DC Volts across the battery terminals (you should have a reading of approximately 13.2-15 DC Volts).
4. Stator Checks/Rotor Check: Each of the following tests isolate the stator & Rotor, If AC Output test Fails and Resistance Check, and Stator IB Test Pass then Rotor is at fault (Pull Primary covers and inspect rotor for damage).
AC Output Check:
Probe both stator wires with your meter leads.
The motorcycle should be putting out approximately 18-20 ACV per 1,000 rpm. (Reading will vary depending on system, check service manual specification)
Generic Specs:
Resistance should be in the range of 0.1-0.5 Ohms. (Reading will vary depending on system, check service manual for specification)
Generic Specs:
Identifying Wires:
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Electrical issue and fault finding chart
Yamaha zeal 250 service manual
Manuals Data Zealous
Dec 02, 2012 | 2000 Yamaha FZX 250 Zeal
I have an 04 thundercat and the charging voltage at the battery is only about 12.2 vdc what voltage should i have coming out of the stator before regulator
Hi, Kenneth the following is a comprehensive charging system test that is guaranteed to the find issue with your system.
5. AC Output Check:
Generic Specs:
Generic Specs:
Identifying Wires:
HOW TO CHECK YOUR CHARGING SYSTEM and CHANGING the STATOR and REGULATOR...
http://www.thundercat.nl/index.php/download/category/2-manuals
YAMAHA YZF600R Owner Manual
Aug 15, 2012 | 2002 Yamaha YZF 600 R thunder cat
Ttr 230 wont start with new battery
Hi, Grant the following is a comprehensive charging system test that is guaranteed to the find issue with your system.
5. AC Output Check:
Generic Specs:
Generic Specs:
Identifying Wires:
My TTR230 won start plz help
What to Do Check When Dirt Bike Won Start
Yamaha ttr230 Service Manual
Yamaha TT R230 Owner Manual
Jun 18, 2012 | 2010 Yamaha TTR230
My yamaha r6 it have regulator recifter connector blow and aires too . Any body know if only need to put new conector plug and new regulator . Or what else can be???
Hi, Lfdespino before testing any electrical component in the Charging System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test because your battery may have 12.5 volts or more but little or zero amperage and must be replaced AGM types more so than lead acid batteries.
1. Battery Test:
5. AC Output Check:
Generic Specs:
Generic Specs:
Stator ground Check:
5. Regulator Test:
Identifying Wires:
Yamaha YZF R6 Service Manual
Yamaha YZF R6 Owner Manual
Jul 24, 2011 | 2009 Yamaha yZFR6
Jonway Whip 125 not charging
Hi, Warryn before testing any electrical component in the Charging System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead-acid batteries.
1. Battery Test:
5. AC Output Check:
Generic Specs:
Generic Specs:
6. Regulator Test:
Identifying Wires:
For more information about your issue and valuable "FREE" downloads for viewing or printing that you will need please click on the blue links below. Good luck and have a wonderful day.
How to test and repair the charging system on scooter
Scooter Charging System Check Is It Working
http://www.family-motorsports.net/GY6-50cc-150cc.pdf
Jonway Scooter Parts
http://absolutelyscooterparts.net/pdf/CGEN_dawg_scooter_manual.pdf
Jul 28, 2017 | Jonway Motorcycles
I need to know how to test my alternator without removing it to see if it's working. 1996 Jeep Cherokee Country.
Use a voltmeter to test battery voltage with the engine running. If the alternator is working correctly, the voltage should read 13.5 to 14.5 volts DC. If reads 12.6 volts or less, the alternator is not charging the battery. Take the car to Autozone or similar business for a free checkout of the alternator. It might be a bad voltage regulator instead of the alternator.
Feb 09, 2010 | Jeep Cherokee Cars & Trucks
Sanyo DS27510 27" TV Logo
1,295 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
