Power up problem
My computer does not power up....
The fan turns on, and the hard disk starts up (sounds like it) but nothing come up....
Once in while it will start up... have to try and try.
The main difference is that the computer will go quite and there is a beep. Then it turn on. This getting quite and the beep s missing....
Could any suggest a solution? Or identy the problem?
Marc
  • KENKENISHI Nov 08, 2008
    I have checked my RAM if that is what you mean by Memory modules and they were fitted but just in case i took them out and changed their location and refitted them. I turned on the computer and with amazement there is the beep! But Now it does not stop. Is a long beep continued by a long beep and on and on and the computer does not turn on.......... Any solution?
  • KENKENISHI Nov 09, 2008
    Dear cgalvez
    I cleaned it and refitted them and my computer starts up! Thank you very much!
    Problem Solver:
  • 12 Answers
Can you check if the memory modules are loose / dirty ?
Posted on Nov 07, 2008
  • Carlos Galvez Nov 09, 2008
    that means contacts may be dirty... you may need to grab a MONGOL pencil or any pencil that has an eraser on it and "erase" all the gold contacts on the edge that go to the motherboard... until they are shinny... just like if you were erasing.. both sides, that clean the contacts.. go ahead, do it and set them back in the motherboard...
I have a computer that would do nothing when turned on, including giving no beep codes. Everything seems to be getting power - the CD drive, CPU fan, and hard drive all start spinning. I disconnected...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
hope this helps
Dec 05, 2010 | Acer Computers & Internet
My computer makes a highish pitched whirring noise every time it has to do something slightly difficult, typically a video or interactive things. What is it and can I fix it?
Yes, open the side cover and determine where the noise is coming from - Harddrive, fans, DVD/CD player, etc.. If it's the harddrive, start backing up your important data asap before it goes out completely. If it's a fan, power down the computer and clean the fan. If it's t DVD/CD drive, replace the drive.
Nov 08, 2010 | HP Pavilion a1240n (EG136AA) PC Desktop
Computer shuts down
Please visit the below link to solve your problem.Due to some problems I was unable to send you the whole solution so please visit the site.
http://www.ehow.com/how_113600_troubleshoot-computer-wont.html
Thanks And sorry for the inconvenience.
Please rate me for this solution if it works for you.
  • Step 2 If you're starting from a button on the keyboard, make sure the keyboard is connected to the computer.
  • Read more: How to Troubleshoot a Computer That Won't Start | eHow.com http://www.ehow.com/how_113600_troubleshoot-computer-wont.html#ixzz0szt64gb5
  • Step 4 If you can hear the computer's fan or hard-disk drive, or if you can see indicator lights on the main unit but the monitor stays dark, make sure that the monitor is connected to a working power source, that it's turned on and that it's securely connected to the computer via the video cable.
  • Step 5 If the monitor and computer have power but the computer displays a "Non-system disk or disk error" message, check to make sure you didn't leave a disk in the A: drive. If you did, eject it and restart the computer.
  • Read more: How to Troubleshoot a Computer That Won't Start | eHow.com http://www.ehow.com/how_113600_troubleshoot-computer-wont.html#ixzz0szsjH6o9
    Jul 06, 2010 | Dell Inspiron 530 Desktop Computer
    I tried to move my hard disk and cd/rom drive to a dell tower but did not work and now when i put them back in my compaq evo i am only getting 3 beeping sounds when i boot up then it turns its self off ...
    Hearing more than ONE beep is "bad" news.
    Check that the wires from the fan on top of the CPU are connected to the power-supply pins on the motherboard, so that the fan spins when power is supplied.
    Check that the RAM is correctly seated in its slots.
    Check that the video-card is correctly seated in its slot.
    Disconnect the power-connectors from the disk-drive and from the CD-ROM drive, and then start your computer. If it still beeps, without these devices attached, then these devices are *NOT* the source of the problem.
    If all else fails, take the computer to a qualified technician.
    Jun 12, 2010 | Compaq Evo D500 PC Desktop
    When I start up my emachines D3315 the fan revs up then nothing no video nothing else happens.
    it sound like you may have a motherboard problem you maybe looking at getting a new motherboard if the fan starts but nothing else happens.
    its not a power problem this will be dealing more with the motherboard its self. try removing the hard drive if the screen says no hard disk found then your board is most likely ok. try rebooting and hitting f8 to insure that the computer is not stuck in a hibornation state. this is not likely but possible. do you see lights in the front of the computer? this will let you know that your getting enough power flowing thru the unit. if all this fails your motherboard has gone bad on you
    Nov 12, 2009 | eMachines D3315 PC Desktop
    Fujitsu lifebook n5010 notebook won't reboot i let the battery run out while working. next day, turned on three loud beeps, then three loud beeps then fan runs but no display on the screen. power off,...
    Okay, sounds bad.
    However, take out the battery from the laptop and remove mains lead. Go and make tea! Then, drink it. Once you have complete this task.
    Plug in the AC lead ONLY into the laptop and then try to power it on.
    You should see lights on the Hard Disk LED or hear a beep. If you see them but nothing on the screen at all when booting then the capacitor pack has probably gone on the screen. This is not an expensive part, but you do need to know what you are doing to replace it. Think it time to give it to the workshop or ask IT bod to look at it for you.
    Oct 26, 2017 | Fujitsu Siemens Lifebook N5010 Notebook
    When i press the power button the fan starts up but nothing else happen. sometimes it turns on and when it does, i can use it normally for days.
    seems like you have hard disk issue.
    I would suggest that the next time you computer power up fully you backu up everything that is important to you.
    you will need to take your computer to service so they will check your hard disk.
    Sep 19, 2009 | IBM ThinkPad X31 Notebook
    Cannot get new Motherboard to boot up in Normal Mode
    what u may have done is wwhen u were installing the new board, gave a static shock to the system...that will cause only the fans to come on and nothing more...this is a bad problem bc u cannot fix it...if u figure out something else is wrong, and it gets fixed, let me know
    Jun 20, 2009 | Gateway Computers & Internet
    Laptop turns off as soon as it starts
    I wouldnt say a problem with the HDD. My laptop I find this behaviour when my power key gets stuck.
    Aug 20, 2008 | Acer TravelMate 3012WTMi Notebook
    Computers & Internet Logo
    110 people viewed this question
    David Payne
    David Payne
