CD DECKS FADER BROKE FOR NUMARK - Audio Players & Recorders
  • 4,234 Answers
This is a common replacement part available from Numark as well as some generic electronics suppliers. Any local shop that deals with audio equipment should be able to repair this for you. Expect a parts cost between $10-$20.
Dan
Posted on Nov 07, 2008
How do is fix my Numark m6 bleeding cross fader
/it's most likely a defective fader, but before replacing it, get a can of Deoxit5 or fader cleaner and spray inside the fader, then move it the full length os travel about 20 times to see it that clears it up.
Jul 09, 2016 | Numark Music
Numark ttx/ttx1 pitch fader wonky
Try spraying the slider with Servisol Video 40.
Mar 15, 2013 | Numark TTX1 Turntable
What lube can i use to clean numark nuvj crossfader. i'm gettin a leak while using the fader.
Usually a "leak" from one side to the other is an indication of a cracked resistance element. The fader would have to be replaced.
I lube the faders on my mixers using CRC226 availablle in the electrical dept at Home Depot. Use sparingly.
Aug 12, 2010 | Numark Nuvj DJ Video Mixer
Fader start
Hi Gary Milchar,
Have you set the player to start from fader http://www.numark.com/stuff/contentmgr/files/0/fc90d6fb8cfaeec3e6dbbe22202aabfb/file/cdn22s_refmanual.pdf? (page 12)  If so check that you have continuity across the mini jack with one end plugged into the mixer.
Happy hunting.
Jan 24, 2009 | Numark CDN95 2-Disc CD Player
Idj2 stutter start button
I have this same problem. I haven't found a solution anywhere, but a great workaround is using the Fader Start function - basically the moment the fader is slid into the main mix, the deck which you enable will start to play the tune. Hit the mode button, then select control, and turn on Fader start. It's actually really cool and allows you to do some ballsy mixes :) The deck will pause (or cue depending on the setting) once you bring it back.
Jan 10, 2009 | Numark iDJ2 - DJ iPOD Mixer Docking...
How to get fader off no music
The fader ? Maybe you mean the mute. The fader is to turn on the back or front speakers. may be that the mute button broke . or the fader button . Not the actual contact but the plastic button you press. It has happened before. Disconnect it . Let it sit for a while the restart it. This should bring everything back to default. But don't count on it too much. you may have to have it repaired.
Dec 11, 2008 | Sony RCD-W500C 5-Disc CD Recorder
Play and pause button does not work
More than likely the button switches are damaged and need to be replaced. The CDMix1 is a very bad unit, chock full of issues. We wont even bother working on these anymore. This includes the CDMix 2 and CDMIX 3.
You might have to contact Numark directly for repair assistance on this one - www.numark.com
- OPTiC.
Digital Analog Therapy
www.djprolab.com
Nov 02, 2008 | Numark TTX1 Turntable
CDMix 2 Fader Start does not work
Both decks must be on single play
regards
Jun 15, 2008 | Nu Mark Numark Cd-Mix-2 Dual CD...
Pitch/Tempo control/fader problem
You can buy a contact cleaner spray and spray inside the fader while moving the fader from -10 to +10. If the problem is dust or dirt this will fix it. If the problem presists, then go ahead and get a fader replacement.It's easy to replace ;-) Regards. DiMiS Greece.
Aug 06, 2007 | Pioneer CDJ-500II CD Player
41 people viewed this question
 Grubhead
Grubhead
