Question about Cameras
My Sanyo VPC-603 will not stay on-I have changed batteries several times
SOURCE: Help!! Sanyo VPC-E760 Digital Camera driver for Mac OSX
the driver is not separately available for Sanyo VPC-E760
Posted on Aug 06, 2008
fotomohamed
  • 321 Answers
SOURCE: Sanyo VPC-T850 shutting down
use NiMH batt.
Posted on Jun 18, 2009
  • 11967 Answers
SOURCE: sanyo VPC-E1075 turns off after 2 seconds why?
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Oct 28, 2009
Testimonial: "Thank you so much! its now working, think it was maybe dust in the lens as you suggested so blew on it a few times while holding open the zoom lens!"
1joester2
  • 74 Answers
SOURCE: Sanyo VPC-S1080 turns on and
See if the menu has a battery type setting. Some cameras have the ability to use different battery types (alkaline, Ni-Cad, Lithium, ect) and have power management presets to accurately indicate a low battery condition. If you are set to one type an install another, a false reading would result.
Posted on Jan 16, 2010
Testimonial: "Although the recommended fix did not resolve the issue, it was a great help as a learning experience"
SOURCE: When I turn on my new Sanyo VPC S1285 camera it
When I turn my sanyo vpc-s1285 on it stays of the blue Sanyo Screen Can you help me fix this?
Posted on May 30, 2010
I just got a sanyo model vpc-603 and it wont turn on even with new batteries
Are the batteries charged and inserted correctly ? It is always best to use the highest power re-chargeable batteries you can get, rather than the cheap ones from low-priced retail outlets.
Dec 26, 2016 | Sanyo VPC-603 Digital Camera
Does anyone know what usb cord the sanyo VcP-S885 uses
If you mean the Sanyo VPC-S885 digital camera, that is a USB 2.0 A to USB mini-B 5 pin cable. Amazon has several replacement cables; one of which is here: https://www.amazon.com/Antoble-VPC-S885-VPC-S885p-VPC-CA200-Camera/dp/B01EV5KN7E .
I hope this helps.
Sep 15, 2016 | Sanyo Cameras
We have a relatively new Sanyo vpc-s120, and have just tried to change the batteries for the first time. I have tried several sets of both alkaline AND rechargeable (both of which are recommended in the...
When You Turn On Your Camera Push the Menu Button then Push The Little Flower Which Is The Down Arrow in The Square box on the Camera It Should Take You to The Option Menu, Now Press the Video/time Mode Should be On Your Right, Next Press the Flower Button Which is Down 7times Then Press Set Which is The Middle Button In The Square Then Select Which Battery You Want To Use The Rechargeable Batteries Or So Much Better and Last Longer. Hope That Solved Your Problem and Have A Nice Day.
Oct 11, 2010 | Cameras
When I turn on my new Sanyo VPC S1285 camera it stays on the blue "Sanyo" screen
Apr 04, 2010 | Sanyo Cameras
I have a Sanyo that is giving me a system error.
I got the exact same problem... can anyone help?
Aug 08, 2009 | Sanyo VPC-S7 Digital Camera
Aug 06, 2008 | Sanyo Xacti VPC-S60 Digital Camera
Read the Manual- this may be more comprehensive on the software disk in a PDF file
Jun 03, 2007 | Sanyo Xacti DSC-S4 / VPC-S4 Digital Camera
Sanyo camera shuts down and won't power up
I connected my Sanyo VPC - 603 digital camera to an AC/DC adaptor due to battery malfunctions. After about 5 seconds, i heard a spark sound and the camera went off. What might have gone wrong? How can it be repaired?
Apr 10, 2007 | Sanyo Xacti DSC-S4 / VPC-S4 Digital Camera
Cameras Logo
41 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
