Question about Hitachi 57S715 57" Rear Projection HDTV
Picture quality Do I have to have a HD satellite receiver to get a crisp, clear picture for watching TV? This is my first HD TV and do not know much about it. All I know is that the picture is not as crisp and clear as it was in the store. Thanks
    President:
  • 3,130 Answers
The output from your sat reciver is not HD unless it says right on it that it is . The signal your getting now is a digital signal from the dish to the reciver, but from the reciver to the TV set, it is analog. To answer short and sweet, Yes, you will need an HD reciver for the satallite to get the most out of your HD TV set. Good Luck Ps and please dont forget to rate this.
Posted on Oct 16, 2006
Picture is not as crisp as plasma should be.
The only thing you can do really is check your television settings to make sure its set up correctly and the satellite settings. Also if your watching analog channels through your set there gonna look fuzzy and distorted with blotches sometimes and also remember the bigger your tv the further back your supposed to sit if you stand right infront of it you'll see everything the way its not meant to be seen. after you try all that make sure your using either component or hdmi cables for the best picture.
Jul 07, 2007 | Daewoo DP42SM 42 in. HD-Ready Plasma...
TV picture not clear
First we need to know a little more details about the kind of TV you have, the kind of service (Cable, Satellite or off Air).
Comparing showroom to your home is also something we need to know. Was the showroom using Cable or Satellite. Satellite will always have a better picture quality wise.
If you are using composite input for the signal path between TV and source this would not produce a High Dif picture Composite = Yellow for video, red and white for audio. If you are using Component source that will produce a HD signal cable is RED/BLUE and Green with different audio.
The best quality is using an HDMI cable, this is all in one cable and the sources is the best. One last thing, if you are using the RF *cable as source it will not give you a quality signal.
Apr 22, 2014 | Intellian i9P US HD System with 85cm Dish...
HD channel picture is clear, but regular digital picture scramble
o.k. check all your connections
if you have a newer house check to see if you have a main hub in a closet somewhere and check all connections. Check your hd receiver and you may be able to chage the DPI the receiver receives in.
I have this problem on some of my non HD channels, also. So much for going digital. I get fuzz and pixel problems "from time to time", but, if it is really bad and consistent your should call your service provider.
Things to ask also ? are you using cable or satellite.
If satellite T.V. there are other reasons you could be experiencing problems.
hope this helps!
Mar 26, 2010 | Toshiba 57HDX82 57" Rear Projection HDTV
I have an LG all in one home theatre system, LCD TV and Direct TV satellite box. It is all hooked up and working fine except I only hear the sound through the speakers when playing a dvd or radio. The...
OK. For all you regular Joe's like me here's the fix--plain and simple! I have Dish Networks HD receiver, an LG Home Theater System (LHB953) and an LG HD Television - although I suspect this applies for most LG TV-to-LG Audio Systems used in combination with a HD TV). My problem lied within the LG to LG setting known as SIMPLINK which tries to "auto-configure" everything between LG to LG devices.
Do this to make your HD TV (using Dish/DirecTV) play it's HD video display from the satellite provider but play the audio over the LG surround sound speakers:
1. Plug a HDMI cable from your satelite receiver's set-top-box to your HD TV. This will carry your HD "video" ONLY. Click "Input" on the TV remote until the HD video signal shows your desired TV channel from your satellite provider.
2. Plug an HD Optical cable (the one with the red laser) from your LG HTS (Home Theater System) to your satellite box. This will carry your HD "audio" ONLY.
3. This is the magic everyone seems to be overlooking. On the LG TV remote, go into the menu options and disable SIMPLINK by setting SIMPLINK=OFF. This feature allows the video and audio signals to be split over 2 different ports: HD video goes over the HDMI cable and the audio to go over the HD Optical cable.
Hope this helps!
Scott C.
Feb 01, 2010 | LG LHB953 Theater System
I have a Sharp Aquos LC-30HV4U which is supposedly HD ready. I am a Dish Network satellite subscriber. I do not know what to do to make this HD ready set receive HD signals.
Your reciver is already set for the hd. Alls satellite programing and cable already come in hd format. You can also get any info here.
http://www.dtv.gov/
Good luck and please rate FixYa!
Apr 07, 2009 | Televison & Video
Looks blurry, wanting a clear & crisp picture.
In the picture settings, you can choose between hdtv and standard t.v.. That should work for you because not all channels broadcast in the hdtv signal.
Jul 16, 2017 | Televison & Video
Using Hitachi's 53SDX89BA High-def settings w/ HD-DVD
look at these see if this helps
http://www.hdtvoice.com/voice/showthread.php?t=16973
http://www.hdtvoice.com/voice/showthread.php?t=8721
Most HDTVs cannot properly stretch incoming HD signals, however, if the programme is true HD, you should not much of the image off-screen - most new HDTVs have about 2% overscan and the tickers should be on screen when watched in the appropriate stretch mode.
See:
http://www.hdtvoice.com/voice/showthread.php?t=1044 and
http://www.hdtvoice.com/voice/showthread.php?t=1052
Dec 29, 2007 | Hitachi 50UX57B 50" Rear Projection...
Picture not HD quality while watching HD channels
Make sure you are using an HDMI video cable for optimal picture quality. Also, you must be using an HD reciever.
Jun 12, 2007 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Hitachi 57S715 57" Rear Projection HDTV Logo
124 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
