Question about Electrolux Vacuums
I have an Electrolux LITE upright carpet cleaner - about 15 years old. Suddenly last night when using it, from the normal motor (whooshing) sound, the motor suddenly went very slow and with a slight grinding sound. The brushes are now just turning round very slowly and areobviously not picking up anything. Has the motor gone or is this repairable, or should I just get a new cleaner? I have tried to open the machine from the bottom to see if anything is obviously wrong, but it looks complicated and I'm concerned that I may not be able to get everything back together again! My machine has not had extensive use over the years. Any thoughts please? Many thanks, Derek McDonnell
5 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: dust blowing out of my vaccuum cleaner
Usually when dust is blowing out it is caused by a clog, either the hose, or the dirt inlet down by the brush roll is clogged. Check them and clean them out and you should be ok.
Posted on Jan 09, 2008
reddevil6
  • 1673 Answers
SOURCE: electrolux upright vac
Belts can look ok, but after a short period stretch so they won't turn the brush roll under load, if you have never changed it, and if it is a flat belt, I would try a new one.
Posted on Feb 17, 2008
  • 5 Answers
SOURCE: Bissell upright vac, brush on bottom does not rotate
The front brush motor will not engage until the power is turned on and the handle is in the down position. In the upright position the brush motor wont engage. Typical faults will be the belt is broken and needs replacing or the fornt brush motor needs replacing.
Posted on Dec 14, 2008
SOURCE: Hoover Steam Vac Spin Scrub Carpet Cleaner won't suck
had my steamvac spinscrub for 3 days now. it will not **** up why?
Posted on Mar 27, 2010
Where does the belt go on the Electrolux el8807
EL8807 no belt, separate motor for brush, use reset button. Call customer service, see my other post with the number.
Sep 30, 2014 | Electrolux EL8807A Precision BrushRoll...
How does the carpet cleaner work
Resolve carpet cleaner is a cleaner specifically designed to work on carpets. Resolve comes as a steam concentrate, a powder, a foam spray, or liquid spray. Before using the carpet cleaner you should vacuum the carpet. Resolve carpet cleaner works by being applied to the carpet then worked in with a soft bristled brush. Depending on the cleaner, it will be sprinkled or sprayed onto the carpet. Use the brush to work the cleaner down into carpet fibers. There is a waiting period for the cleaner to work, then you vacuum the cleaner out of the carpet.
Apr 25, 2014 | Electrolux Sanitaire SC688A Upright...
Electrolux VACUMM CLEANER LITE II
get new bag filter , empty dirt out to garbage bag , clean hose .
Dec 26, 2013 | Vacuums
My Bissell proheat carpet cleaner (this is my second one because the first one stopped working as well) won't dispense water, cleaner, or suck anything up. The motor turns on but that's about it. It is...
I'm not a big fan of Bissell products to begin with, but I can tell you from many, many years of experience that, far and away, the most common cause of problems with any of the carpet shampooer, steam cleaners, etc., is that they are stored with unused materials in the tanks and hoses. They are seldom cleaned, rinsed, or receive any type of cleaning before being put in the closet to be pulled out sometime in the future, with the very next attempt at application of the shampoo, or cleaner or whatever is still in the tank, not happening, because the hoses are plugged with a gelatin like substance. This is, in reality, what happens to many of the shampoos on the market, when they are left unattended for long periods of time. You haven't mentioned your cleaning, maintenance procedures concerning the unit, so I have no way of knowing just what may be causing your product, however, I think if I were you, and not using something more than twice a year, I think I'd look into renting a cleaning unit, rather than owning one.
Oct 22, 2013 | Bissell 1699 ProHeat Clear View Upright...
Electrolux Epic Series 6500 SR. The machine is 15 yr. old & is working beautifully. However, when operating it emits a terrible stink, like cat *****. I've changed bags & filters but no ch
You need to have the vacuum cleaned out. If you are good with tools, just remove the motor and fans assembly, take the fans off and wash them. Brush ALL dirt out of the housing and reassemble. Your Electrolux dealer can do this but it isn't cheap. I used to be the service manager for my area. Since it isn't under warranty, you can have ANY reliable vacuum cleaner shop give a good cleanout. NEVER put anything into the cleaner to make it smell good. Electrolux cleaners get their power by having a straight through suction. The air goes through the motor. Adding smelly things can crystallize onto the motor and burn it out.
Jan 17, 2013 | Electrolux Epic 6500 Vacuum
I have a 5 year old Dyson DC07 animal vacuum cleaner. I'm having problems with the vacuum strength when cleaning the carpet but not when using an acessory to clean the stairway carpet. Any possible
Hi Ronald,
I'm sorry to hear you're having difficulties with your DC07. If your machine picks up well through the hose, but not through the cleaner head, it's likely that you have a blockage in the cleaner head.
The easiest way to locate and remove any obstructions is to follow the steps shown in our online support guide:
http://www.dyson.com/support/help.asp?article=4&product=DC07-ANIMAL_US
It's also a good idea to give the filter a wash - in normal use, this should be done at least once every 3-6 months, as shown in the video below. Use cold water without detergent, and allow at least 12 hours for it to dry completely before replacing it.
This should resolve your issue, but if you have any further questions, please get in touch with us directly on 0800 298 0298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Dyson Online Customer Support
Nov 28, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Our electrolux vacuum cleaner suddenly stopped sucking air from the hose. The hardwood floor and carpet operation is OK. There is no restriction in the hose. I believe that there is a problem with the...
Not making sense here...If you have suction with hardwood and carpet, when is it NOT working? Is the motor running? There may be a "relief" bypass valve that's involved. With hose removed, do you have vacuum airflow?
Oct 26, 2017 | Electrolux Vacuums
Electrolux Epic series 3500 model Upright Vacuum cleaner motor(replace old one)?
I don't know what your question is, but replacing a motor for Electrolux, now Aerus, should be done by an authorized Aerus Electrolux service tech. The uprights are especially tricky to take apart and reassemble correctly. The address and phone number of the Aerus store/service center nearest you can be found at the site below.
http://www.aerushome.com/storelocator/
Mar 13, 2011 | Electrolux Vacuums
Electrolux aptitude upright
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=113651&thid=541998
Posted by inoubliable on Apr 24, 2008
My Electrolux is about 3 years old. Never had any problems with it until recently, it is LOUD. It doesn't seem to make a 'normal' running noise unless it butts up against a wall, furniture, etc. trying to vacuum is like being on a jet runway. Is something clogged? Does it just have issues from not being used for about a year? (Last house had no carpet).
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
It sounds to me that you have a broken fan, in every vacuum I have seen with the loud noise such as you described, it has been a broken fan or fan blade and is in need of replacement. You can try to do it yourself but I suggest going to your local vacuum cleaner dealer for service with the problem. Remember, a suggested belt change if the belt is flat would be 4 to 6 months and If you have a geared belt the belt change would be one year or better depending on wear factor. So, if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com Customer Service
Electrolux Home Care Products – North America
PO Box 3900 Peoria, IL 61612
1-800-896-9756
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 24, 2008 | Electrolux EL5010A Bagged Upright Vacuum
Vacuums Logo
32 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
