Question about HP Designjet T1100ps Printer
47.01 error I have HP Designjet T1100 and when I turn it on, it shows me an error code 47.01. Then it tells me to turn printer off. It works as a network plotter, and I suppose it could be some problem due to network. How could I solve this problem?
  • 1 more comment
  • purusoth123 Jan 06, 2009
  • karzankarzan Mar 01, 2009
    error 47:01
  • Anonymous Mar 13, 2009
    i have a HP T610. when i start it printer gives 47.01 error code
    plz give me solution ASAP.
  • 33 Answers
System Error: 47:YZ
Problem
Description:
Star wheels motor error..
Corrective Action: Try the following:
�� Switch the Power OFF from the back of the Printer and disconnect the
Power cord. Reconnect the power cord and power On the Printer.
�� Check that the Starwheel Assembly cable is not damaged and is correctly
connected to Main PCA.
�� Open the Window and check for any visible obstacles restricting the
movement of the Starwheel Assembly, then clear the obstruction.
�� Perform the Scan Axis Starwheel diagnostic test to troubleshoot the
problem further → Page 4-7.
�� Replace the Starwheel Motor → Page 8-177.
�� If the System Error continues, replace the Main PCA
Posted on Nov 07, 2008
BaronVonNuke
  • 1915 Answers
SOURCE: Error 47:01 for hp desighjet t1100 plotter
This error relates to the starwheel assembly and motor. Open the printer and make sure that there are no paper jams or anything blocking the star wheels (the little pointy wheels that guide the paper.
If nothing is visisble then service diagnostics are required. Not sure of your technical skill level, so post back if you are comfortable disassembling the unit, if not, contact HP to find a local Designjet technician.
Posted on May 21, 2011
  • 96 Answers
SOURCE: error 47:01 for hp desighjet t1100 plotter
System Error: 47:YZ
Problem
Description:
�� Replace the Starwheel Motor → Page 8-167.
Okay, this is direct from the repair manual. if this is a new printer you have one year warranty service on this printer. hope this helps!
Posted on Oct 01, 2009
seeker5211
  • 1089 Answers
SOURCE: error 47:01 in hp plotter t1100
Star Wheel Motor has a problem.
01 code says "reseat/reconnect/clean and manually adjust" the motor.
The Star Wheel Motor is on the left side of the printer.
If you arn't trained on it, get someone who is, to service it.
Posted on Jan 24, 2011
vinay229229
  • 1121 Answers
Indicating "Star Wheel Motor" error, Perform the Scan Axis Starwheel diagnostic test,Entering in Service menu: hold the Up arrow key and the OK key down andswitch the printer ON using the front power switch. Wait until the LED of thepower switch stops flashing (usually after 5 seconds) before releasing ALL Diagnostics menu,go to scan axis, enter,go to star wheel lifter,press OK.. complete the mode..if fails remove star wheel are clean all gears refix again, do the diagnostic again..if you have manual that better to process the things.. Best of luck
Posted on Sep 28, 2011
vinay229229
  • 1121 Answers
SOURCE: plotter hp designjet t 1100
Suggestible for tech guys: Star wheel motor faulty,( to remove star wheel unit open left cover,formatter,power module,spitton)Normally most of the cases motor wont go gear unit pensions breakage observed mostly, replace star wheel motor unit or if you are tech guy you can make alteration see the snap shot how pinion got breakage..Find out metal pinion suitable for the same and fix it properly. 11_19_2011_4_07_20_am.jpg11_19_2011_4_07_49_am.jpg11_19_2011_4_08_22_am.jpgIf its look like difficulty, replace star wheel unit..
Posted on Nov 19, 2011
Hp designjet t1100 blank hard drive installation
Unfortunately I had a similar issue with an HP A0 printer. The Hp 'Engineer' could not fix it. The hard drive had failed and there is a complete new hard drive with software loaded available but only through Hp.
Feb 27, 2014 | HP Designjet T1100ps Printer
02.1.10 error plotter t610 and solution
The error code 02.1:10 means the plotter has a communications problem between the main logic board and the carriage PCA. The possible parts at fault are: The Carriage PCA, Trailing Cable, or the Main Logic Board, all available here: Designjet T610 Parts
You can watch this video to see how to remove the covers Designjet T610 Belt Replacement How To Video
The service manual is here: Designjet T1100-T610 service_manual
Sep 18, 2013 | HP Designjet T610 InkJet Printer
Error code 02.1.10
02.1:10 service station error- failure to reach home position .
you need a service tech to replace the service station within the plotter
Aug 14, 2013 | HP Designjet T1100ps Printer
Replace hp designjet t1100ps hard disk
Designjet T1100ps -Q6687A.
08:11 error. The formatter is okay but the hard disk is bad. How can I load the system software in a blank hard disk or try to clone
Apr 28, 2012 | HP Designjet T1100ps Printer
How to resolve eror code 47.01 hp designjet T1100
this error code is Starwheel Motor failure.
Feb 25, 2011 | HP Designjet T1100ps Printer
Hi ! can you tel me how to resolve eror code 47.1 for hp designjet t1100
I have this error with my Designjet T1110. I followed the instructions in the service manual 2-14 for troubleshooting.
questions:
- instructions say :"Check that the Starwheel Assembly cable is not damaged and is correctly
connected to Main PCA." but I could not locate any cable from the starwheel assembly to the main PCA. I could see only cable from the starwheel motor assembly to the main PCA.
Feb 25, 2011 | HP Designjet T1100 Photo Printer
08:11 error in hp designjet t1100
I had this code recently, and solved it cleaning the contacts pins in the formatter whit 2000 sand paper (could be pencil rubber) and reseating it.
Oct 01, 2010 | HP Designjet T1100ps Printer
HP Designjet T1100 error code 08:11
The error code indicates a communications problem between the display and the electronics. Reseat the connectors on the display and the connection to the electronics. If that does not solve the problem, replace parts in this order until the problem is solved: display and display cable, electroncis module, logic board.
Apr 19, 2010 | HP Designjet T1100ps Printer
HP Designjet T1100ps Printer Logo
5,137 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
