Question about Sitecom xDSL/Cable Broadband Router DC-200
Wireless router 300M no acces to the internet
My modem is fron tele2, the router is connected with cable to the modem, but i have no connection with the internet
  • Sitecom Master
  • 6,487 Answers
You need first to configure the router to work with your modem, if you have the setup CD of the router just that one and then follow all the steps on the setup CD after you're done running the setup CD of the router power down modem and router for 1 minute then plug the modem first wait for about 30 seconds and then plug the router back , after that check if internet is already working........
Posted on Nov 07, 2008
No interent connection
Your Linksys wireless router needs to be connected to a DSL or cable modem which needs to configured with the settings that your Internet Service Provider gave you.
To test your Internet connection connect a LAN cable fron your conputer to the DSL/cable modem. If you cannot connect to the Internet using this methos, you need to contact your ISP and the can check the connection to your DSL/cable modem.
Apr 12, 2012 | Linksys Computers & Internet
Desktop wont connect to internet but laptop will
Is your cable modem also a wireless router?
From my search on it, it is not a wireless router.
This means you need to attach a hub or a wireless router to your cable modem so that more than one computer can connect to the internet simultaneously.
Go out and buy a wireless router. Connect the wireless router to your cable modem.
Connect your desktop to the wireless router with an ethernet cable.
Then you should have internet on your desktop.
Let me know if this helps. Give me a good rating and vote for me please.
Mar 24, 2010 | HP Compaq Presario SR2011WM PC Desktop
Ethernet connection of DI-524 does not work
You have to make the Ip changes on the laptop not on the modem.
You said you have internet acces on one computer. Then use that computer to find out the exact IP address used by the modem.
On the laptop use the exact same numbers, (IP, Sub mask, Gateway, Primary DNS)
and chek if it works.
If you want to have both computers on the Internet, simply change the last number on the IP address ONLY.
Please don't forget to rate this answer if it helps
Sep 22, 2009 | D-Link AirPlus DI-524 Wireless Router
Router connection fail
do you have internet with the modem? if you do then router is not configure correctly. If you do nothave internet ask you ISP why you are not online with the modem directly.
Sep 11, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
I have a WRT54G ver.6. Was working fine until I went fron DSL to Broadband(cable) Now system won't connect. ???????
Are you attempting to use the device as a router or a switch?  Because if when you switched to cable you got a new router with it this device may be trying to steal this devices capabilities. Im assuming there are five ports, one to plug the Internet into and another to plug in the devices you wish to connect. Try plugging the Internet Ethernet cable (directly from your cable modem) into one of the four device ports and NOT the singular Internet port.
Nick
Sep 03, 2009 | Linksys Wireless-G Broadband Router
The wireless connection is not connecting
first unpluuge the modem and the router than plug in the internet from the modem to the router where it says internet ,than you install cd in pc restart the pc and plugg the modem and the router back to the outlet in the wall and see if you can read if your router is broad band if not you will not get acces to the internet and if you have the wireless or inbuild internet than you might be able to be online , so make sure if you dont ahve abuild inn use awirelessinternet adapter that goes with the router
Aug 04, 2009 | Belkin Wireless-N Wireless Router with...
Linksys wireless G router not working when connected to dsl modem
hey there, can u acces the gateway of the router
192.168.1.1 than enter ur login & password
than reset the router to fabric setting when done go back in the router and configure it as u like to have it
Jan 04, 2009 | Siemens SpeedStream Modem (4100) (SS4100)
D-link dir-625 still cant acces wirelessly
If your laptop has a wireless capability you should be able to connect to the wireless network of your router, just view the available wireless network select the wireless name of your router and connected to it if it already say connected try to disconnect the ethernet cable from your laptop and access the internet wirelessly..........
Nov 01, 2008 | D-Link DIR-625 (790069292637) Wireless...
Wireless configuration
What you will need: Wireless router and a wireless adapter connected to your PC. This is assuming you have a broadband internet connection. Install the wireless router by taking the ethernet cable out of the back of your computer and placing it in the WAN or internet port in the back of your router. Install the wireless adapter inside your PC. Unplug your modem for a minute or so. Then plug in your modem and your router, then turn on your PC. If you are running XP, it should see a list of wireless access points you can access. Select the one for your router (should be the strongest) and hit connect. This will connect you to the wireless router and the internet. Note this solution assumes the following: You have a high speed internet connection, your ISP's modem is connected to your computer via an ethernet cable, and you are running windows XP.
May 19, 2007 | RCA DCW615R Wireless/Cable Modem
Open Questions:
Sitecom xDSL/Cable Broadband Router DC-200 Logo
520 people viewed this question
Top Sitecom Computers & Internet Experts
David Payne
David Payne
Are you a Sitecom Computer and Internet Expert? Answer questions, earn points and help others
