Question about Samsung DVD-HR720 DVD Recorder
Dvd file system
I would like to know if it is possible to upload data from DVD recordered by HR720 to PC in order to obtain a DVD file system (VIDEO_TS folder ifo and vob files) or to to get the front DV input to work as DV output in order to upload data to a digital camera. is not really a problem but I can use DVD only on HR720 ...
The first is rather easy. You will have to finish the DVD to get it working. After copying a title, finish the DVD and put in you computer's DVD player. Either the film should start to play or you will be prompted whether you want to show the contents or other options. If either of this happens, you are good to go and you can copy the Video_TS folder which should be visible to your hard drive. Done it several times.
The second solution is something I try to figure out myself but it seems DV in is really IN and not OUT....
Best,
Marty
Posted on Feb 11, 2008
SOURCE:
How do you record a TV show every week without
You should have some kind of series link ICON that you can press so it remembers
Jan 12, 2010 | Samsung DVD-HR720 DVD Recorder
Hitachi dz mv230a DVD CAM - can't copy video to computer (WXP Pro)
Make sure its pluged in to a powersource and try again, you should see the camera in my computer.
There might be fault in the camera.
May 18, 2008 | Hitachi DZ-MV230A DVD Camcorder
Tip
Recommended blank discs to use
Please can someone recommend a "DVD-R" and "DVD-RW" to use with the DVD-HR720 DVD Recorder. Please can you also list where to source the particular discs. Thanks.
on May 25, 2008 | Samsung DVD-HR720 DVD Recorder
I recorded from tv to dvd and cannot play back video
upload it to your computer, and check the file type, and possibly convert it to the correct file type and burn it to a DVD.
Nov 15, 2009 | JVC DR-MV80B DVD Recorder / VCR Combo
After we record a DVD, we cannot playback what was recorded.
It happens on everyones player, samsung thought it wise to put some kind of lock on the media.
Weird. I know.
Jan 12, 2009 | Samsung DVD-HR720 DVD Recorder
Power supply down
my samsung dvd-v1000-vcr do not turn on
Jul 29, 2008 | Samsung DVD-HR720 DVD Recorder
DVDs recorded on HR720 do not play on any other player or PC!
not sure if this will solve your issue. But in order to be able to see the DVD recorded on the HR720 (or typically any other DVD recorder) you need to "lock" it. This is done in the File Manager Menu. The DVD recorder will ask you twice, whether you want to "lock" the disk. Once you have done that it will format the DVD like a normal DVD-Video, meaning it can be played on any regular DVD player. However, once locked you cannot re-open the DVD.
Hope this helps. Otherwise check in the user manual under "recording a DVD" - it is mentioned also there.
Jul 22, 2008 | Samsung DVD-HR720 DVD Recorder
NO VIDEO OUTPUT ONLY SOUND
I tried searching but am unable to find one.
Apr 02, 2008 | Samsung DVD-HR720 DVD Recorder
DVD-HR720 DVD
double check connections match on both ends tv and dvd also check the input on the tv sure you video cable is on the same one you audio cable is on.
Mar 16, 2008 | Samsung DVD-HR720 DVD Recorder
Samsung DVD-HR720 DVD Recorder Logo
160 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
