Question about Zebra TLP 3842 Thermal Label Printer
Configure labels I dont know how to configure the labls I have they are 3 in a row and it just print 1 of them
    Problem Solver:
  • 17 Answers
You must set the software to 3 accross
Posted on Mar 21, 2009
How do you format lables to print properly on the richo e7000?
Printing labels is a pain! It is much easier to print using an A4 sheet with (say) 7 rows of 4 labels on.
I suggest you use the Ricoh support site
http://www.ricoh-support.com/Enduser/support/
May 07, 2014 | Office Equipment & Supplies
Zm400 media darkness settings get reset after printings lable from SAP
The printer driver settings override the printer settings unless you tell the driver to use the printer settings. You can tell by setting the printer setting and saving it permanently. Print a configuration label. Send a label to the printer. Print another configuration label. Compare the config labels and If it changed, then the driver changed it. Set the driver as above and it will not change when you print.
Jan 18, 2013 | Zebra ZM400 Direct Thermal-Thermal...
I have a BROTHER MFC-8480DN all in one printer which I just purchased. My avery lables do not work right as the first 2 rows are okay and then the text does not fit right on the following labels. I use it...
Lables are slick some time the feed rollers will slide on them. Try to find lables that are course with no shine on them . The rubber that the tires are made of is of poor quality. Just dont have the grip . Hope this helps
Aug 12, 2010 | Brother Office Equipment & Supplies
Feeding-problems
you need to calibrate. hold the feed button down intill it flashes 4 times in a row and the quickly let go. it will feed some labels to calibrate and should stop at the tear off. you also have to set label size in the driver to keep from losing calibration.
May 14, 2010 | Zebra TLP 3844-Z Thermal Label Printer
Zebra lp 2844 after printing 1 label , light change to red.
me have same problemo
i tried to update the frimware but still have problem
i think problem about lables? did u try bigger lables?
May 14, 2009 | Office Equipment & Supplies
My zoom x6 modem doesn't block pings (ICMP). How do I configure?
Blocking ICMP pings on a Zoom requires a few steps:
1) Go to Advanced Setup and select Advanced Firewall Filter.
2) Enable Advanced Firewall Filter.
3) Click on Security Policy Configuration.
4) Click on Policy Rules for "Add Firewall External-Internal Filter Rules."
5) Click on Add Policy Rule.
6) In the row labeled "Protocol," select "neq" and enter ICMP where it says "(Protocol Number or Name)."
7) In the row labeled "Select the direction to filter packets," select BOTH.
8) In the row labeled "Filter Action," select DENY.
9) Click on Save Changes and repeat 1) through 5).
10) In the row labeled "Protocol," select "eq" and "TCP." Below, select BOTH for direction, and ALLOW for filter action.
11) Save changes and repeat 1) through 5).
12) In the row labeled "Protocol," select "eq" and "UDP." Below, select BOTH for direction, and ALLOW for filter action.
13) Save changes.
14) Go back to Basic Setup and save changes to Flash.
That's it. Good luck!
Jan 26, 2009 | Zoom X6 (5590) DSL Modem (55900003)
Printing mixup
Your problem is a computer configuration issue, not a printer problem.
Without knowing any details of your system configuration, it is impossible to offer and further advice.
Steve W
LazerTek, LLC
Jul 02, 2008 | Zebra 140XiIII Plus Thermal Label Printer
Labels printing in reverse order
It's not the printers, has to be the software.
Contact your vendor for support.
Steve
Mar 04, 2008 | Zebra Stripe S600 Thermal Label Printer
Z4MPlus barcode printer
I have had this problem, but only when I used a label of a size that isn't within specification. Technically, this printer isn't specified for a label that is under 1 inch in height. I have a label that is only 0.2" in height and it will get sucked down inside the machine. I have asked the people who work on the manufacturing floor to advance the label two rows after a print job so that this doesn't happen. Then I ask them to cut the label off leaving the two rows sticking out. So, the next print job will start with the label stock sticking at least 1/2 " out of the printer.
I believe that also my printer doesn't tear the labels cleanly, so there is sometimes something that can catch right at the tear bar. You can probably fix that problem if it exists for you by adjusting the tear bar, or having a machinists slightly sharpen it. I hope this helps.
Dec 27, 2007 | Zebra Z4Mplus Label Printer
Excel functions
Here's one way to do it. Your formulas would look like this:
B1:
=IF(OR(J1=1, J2=1, J3=1, J4=1, J5=1),1,0)
B2:
=IF(OR(J1=2, J2=2, J3=2, J4=2, J5=2),2,0)
B3:
=IF(OR(J1=3, J2=3, J3=3, J4=3, J5=3),3,0)
etc.
If you don't want the zeroes to display, format the cells with a custom number format--type: 0;-0;;@
Nov 14, 2007 | Computers & Internet
Zebra TLP 3842 Thermal Label Printer Logo
228 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
lancer284
Level 1 Expert
kenneth njonjo
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
