Question about Colibri 500 Series 17-Jewel movement double dust cover with chain
Dirty? My watch only runs while I have the knob pulled out and rotate it (as in time adjustment). When I do this the second hand moves-but when I do not do this the watch does not run. Thank you.
0 characters
1 Points
How to adjust hands with anolog time
pull the adjuster knob out and wind it around to move the hands
push back in when the time set is right
Dec 26, 2015 | Casio GA110GB-1A Black G-Shock Digital...
How do i set the date on the diesel dz-1216
two possible methods
1/ pull crown out to first stop rotate clockwise for date and anti clock wise for day.
2/ pull crown out fully to start moving hands rotate hands through twelve O'clock twice for each day to move when at the correct day set the time then pull crown out to first stop to adjust the date, push crown in fully when done.
Mar 03, 2015 | Diesel Strap DZ1216 WW Watch for Men
I cant set the date on my casio MW600 ,I need to no
I think you pull out the knob (on the right) HALFWAY and then rotate clockwise. If you pull out all the way, you can only adjust the time (watch hands).
Nov 03, 2013 | Watches
I've lost the owner's instructions and need directions for setting the alarm.
  • Unscrew the crown (the main knob on the center right side of the watch casing), wait until the second hand is at the 12 o'clock position, and pull the crown knob up so that it clicks once.
  • 2 Press the button below the crown knob repeatedly until the hands of the alarm dial point to the time within the next 12 hours that you want the alarm to ring. Pressing the button once will move the alarm one minute forward. Pressing and holding the button will move the alarm forward quickly.
  • 3 Pull the crown knob one click further out and turn to adjust the main hands to the correct time, to take into account the time you took to set the alarm.
  • 4 Push the crown knob two clicks back into its normal position, and screw it into place until it locks.
  • Aug 20, 2010 | Pulsar PXH225 Watch
    I have a seiko chonograph couturo alarm. 100m
    Many of the Seiko Chronographs have the same setting options (mine is the lightweight "Titanium Sports").
    First off, the alarm dial must show the same time as the actual main dial. If not you must adjust this first.
    Pull the knob at number 4 position on the watch face out, until you feel two distinct notches/clicks (around 0.5mm travel) and the alarm will make a shrill buzzing for about 1 second.
    Now turn the #4 knob to move the small alarm dial at the #6, to be the same as the actual time displayed on the main face, and press the #4 knob fully back in. This sets the alarm and the main time to the same You do not need to do this again, unless you adjust for daylight saving times during summer/winter.
    Now you can set the alarm chime point.
    Pull the #4 knob out again, but just one click. You should hear one ping from the alarm. Now press the button at #8 position. It will move the small alarm hands by 1 minute intervals, and if you keep it held in, the dial spins around quickly. This allows you to adjust the time the alarm will chime.
    When you've got the alarm time and it's chime point set, leave the #4 knob at one click out.
    If you wish to switch the alarm off simply press the #4 knob back in, and the alarm dial will spin around to the same time as the main dial.To re-enable the alarm pull the #4 out one click again. It's quite simple once you get the hang of it.
    Jan 01, 2010 | Seiko Coutura Chronograph Watch
    I need to reset the hands
    Assuming you want to reset the zero posistion of the chronometer (stop watch) hands...
    On my watch I can adjust it by doing the following...
    To reset the microseconds hand / top right
    1) Pull the center knob full out (2 clicks)
    2) Press the bottom push button to adjust the hand
    To reset the seconds hand / middle
    1) Pull the center knob a full out (2 clicks)
    2) Press the top push button to adjust the hand
    To reset the minutes hand / top left
    1) Pull the center knob out half way (1 click)
    2) Next press the bottom push button to adjust the hand.
    Once all hands are reset, push the center knob back in fully...done
    Mar 16, 2009 | Swatch Irony watch
    Rolex 1992 daytona watch
    There should be 3 knobs on the right side of your watch. Unscrew the middle knob with the crown on it until it pops out. After it springs out, it will be in winding mode. You want to gently pull it out past this point, it will click into place and you will be able to set the time by turning the knob. After time is set just push the middle knob back in and turn clockwise unitl it is tight.
    I hope this has been helpful,
    dansfinetime ebaa
    Nov 01, 2008 | Rolex Daytona 116520 Wrist Watch
    I have a seiko flight watch, unknown of the model, second hand doesn't reset
    I guess the blue faced SEIKO is a Flightmaster (Model: 7T92- OCFO)and it is a great watch. This is a common problem with most chronographs and this happens due to misalignment with usage.
    All you need to do is pull out the locking crown all the way out (2nd Step) as if setting time. and then press and hold the top / left button and at first the milli seconds hand resets. after which you have to press the borrom / right button to move the seconds hand in to place. and then reset the time and lock the crown. You can repeat this for Milli Seconds, Seconds, Minutes & hours hands.
    Hope this helps,
    Krishna Chaitanya GT.
    Apr 27, 2008 | Seiko 0512039FA Wrist Watch
    Aquaswiss trax watch
    For clarity:
    There are three adjustment knobs on the right side of the watch. Two are smaller than the main time adjustment knob. For clarification I will label:
    Top knob: #1
    Middle knob: #2
    Bottom knob: #3
    To adjust the stopwatch feature:
    1. Turn #2 counter-clockwise until it pops out to its adjusting position.
    2. Pull #2 towards the right until you feel the first click. (There are two click positions).
    3. Simultaneously hold both #1 and #3 down until you see the 1/16 hand and the 30 minute hand rotate automatically to a fixed position.
    Now you are ready to calibrate the stopwatch feature.
    4. Click mulitiple times on #3 and you will see the 30 min. had move clock wise incrementally with every click. Keep clicking on #3 until the 30 min. hand reaches its apex (to its 12:00 position).
    5. Now click multiple times on #1 and you will see the 1/16th hand move in very small increments clockwise. You may be bold and try to hold down #1 and let it swing as close as possible to the 12:00 position and then multiple click #1 to get it precisely to its apex.
    You are almost done.
    6. Now simultaneously hold #1 and #3 until you see both the 1/16th second hand and the 30 minute hands auto-rotate clockwise to their respective 12:00 positions.
    Fantastic! However, now you have to return the watch back to its original locked position. This is where it could get a little tricky.
    7. Make sure the time is correct. Using #2 fully extended to its 2nd click position you may adjust the time.
    8. Using #2 extended to its 1st click position you may adjust the date. (Here's the trick, do not set the date for today's date. Rather, set it for the day before or in some cases, 2 days before. I will explain in a moment).
    9. Now, depress #2 fully back towards the main body of the watch as best as possible and while holding down #2 turn it clockwise until it locks into position.
    During this operation you may notice that the date will go forward until the watch locks into position, ergo, I had to make sure the date was for the day before...and it some cases, 2 days before.
    Your watch is ready to use.
    The stopwatch feature for this analog watch works very similarly to that of an actual stopwatch.
    Press and hold #1 once to stop the 1/16 hand. Press and hold #3 to have both the 1/16th second hand and the 30 minute hands return to their 12:00 positions. Now you are ready to race!
    Press #1 to start the stopwatch. Press #1 to stop the stopwatch. Press #3 to return the hands back to their respective positions. You may even press #3 after you press #1 to get a second reading but I will let you figure that out for yourself.
    Hope this was helpful!
    Dec 20, 2007 | Tag Heuer Kirium (CL1212.BA0705)...
    Colibri 500 Series 17-Jewel movement double dust cover with chain Logo
    13 people viewed this question
    Top Colibri Watches Experts
    Arturs Kalnins
    Arturs Kalnins
    Are you a Colibri Watch Expert? Answer questions, earn points and help others
