Question about HP LaserJet 4 plus Printer
Smudged Printing My HP Laserjet 4 Plus printer has suddenly started printing all pages with a grey background all over the front and back of the paper, except on the left and right margins. In addition, the printing repeats itself after approximately 9.5 cm in a lighter tone. The ink does not come off on one's hand when one touches the paper. The printer was serviced about three months ago!
  • jeremymarks Nov 07, 2008
    Many thanks for your help. Much appreciated.
  • Anonymous Mar 12, 2014
    printer repeats words on the same paper and additional paper lighter but the same
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 66 Answers
Replace the toner. many remanufactured cartridges will do this due to leaks during/after refill.
Posted on Nov 07, 2008
Hp1020 printing grey backgroud
Hello;
The most common reason that laserjet's get grey background print-outs is that the toner cartridge's drum has gone bad. I have seen it many, many times on new and old cartridges and the only way to fix it is to buy a new toner cartridge. Sorry for the bad news.
Good Luck!
Rich Lilja
Oct 27, 2012 | HP LaserJet 4 plus Printer
HP 2600 is printing with a grey background. I have done several recalibrations and cleaned it but it does not fix the problem.
same as me, I got reduce this effect printing in normal paper as if i where printing transparency paper. The background is lighter now, but still appears.
The other thing I test, printing a blank page it was that with a glosy photo paper with the gloss side to the back i dont get any background. So i suspect it has to do with the tansfer belt ETB rollers.
Nov 02, 2010 | HP Color LaserJet 2600n Printer
Smudged on right side
If cleaning the print cartridge with the built in slide does not work then you can lightly shake it. it may need to be replaced. Also the cleaning of the drum with denatured alcohol will clear that up sometimes.
Nov 30, 2009 | HP LaserJet 4 plus Printer
Dark Background on the paper
replace the drum unit (toner) your drum is weak causing dark background
Nov 21, 2009 | HP LaserJet 4 plus Printer
HP 4L when printing an internet page, print size is for
Under print preferences set the paper size to A4.
Start > Printers and Faxes > (Right-click printer and select properties) > (select printing preferences) > (set paper size)
Aug 25, 2009 | HP LaserJet 4 plus Printer
HP 2600n grey background
Most Original cartridges are starter cartridges that hold only 1/3-3/4 ink. Drum maybe defective, and this usually causes the grey or black in your printing. Cartridges may need replacement along with the drum. Hopefully this helps
Aug 13, 2009 | HP Color LaserJet 2600n Printer
Hp Laserjet 4 Plus printing very light - second post
Your description indicates that the problem is with the printer driver settings.
Go to Start, Control Panel, Printers and check the setings for Economode and ReT. The should both be off or Economode=off and ReT set to Med or Dark.
This should fix the problem. Let me know if this works or not and we can try something else.
May 03, 2009 | HP LaserJet 4m plus Printer
Grey background over entire page.
If toner is getting onto the transfer belt, it can only get there by either being put there intentionally, or leaking.
Failure of Transfer Belt is normally degraded print quality - usually poor density, or a failure of the support behind the belt (usually puncturing the belt), and scoring a drum.
Sep 15, 2008 | HP Color LaserJet 2600n Printer
Dark Background on HP Laserjet 4100
Several Options:
- Increase the Toner Density Level to 5
- Use freshly opened media
- Use a new print cartridge, if near end of life
- Run a cleaning page to clean the fuser
Jun 18, 2008 | HP LaserJet 4100 Printer
HP LaserJet 4 plus Printer Logo
407 people viewed this question
Ben Johnson
