Got a 51" LG HD LCD TV its got a cracked screen showing no picture but it turns on still it fell of my wall can it be fixed and if yes how much ruffly will it cost me to get fixed.
The LCD panel can not be fixed, only replaced. Without the model number, I can not give you a cost, but expect the cost to exceed 1/2 of the original purchase price. Post hte model number and I'll get you the part number and cost.
Try changing 'perspective' or screen ratio.
This may work, but could also stretch the picture too wide,
On my non-LG TV this is called 'aspect ratio' under the 'picture' menu.
SORRY, if the panel (it is called a display panel) is damaged this is the end of this set- fatal from a cost point of view as the part if available will cost more than the set did when brand new.
The display panel in all these sets is fragile as you have discovered--even a minor hit can destroy the panel.
The set needs a new LCD if it looks cracked and swirly, the colors all run together in the area of the crack don't they! If it is cracked it can't be fixed. you can replace the lcd but I am not sure if a warranty will cover a cracked screen or not. You will need to contact LG and be very nice to them and see if they will honer the warranty on this.
is the screen cracked? if the screen is cracked, then probably that is the reason why is not showing the picture. if the screen is not cracked or has not been accidentaly damaged then we can try to troubleshoot
Yes, thats correct. If lcd tv screen got hit by some thing then lcd panel got cracked and does show distorted lines or cracks instead of picture and lcd panel have to be replaced that would cost you 70% to 80% of new tv price. New TV is better option.
Maybe. Unplug the unit and disassembly it. Look for damaged parts or cracked circuit boards. You may also find the buttons you push to turn it on and activate the menu ect. may be damaged. In most cases the board can be repaired but because that would be time consuming and the repair man charges 60 bucks an hour it is usully not cost effective. You might get lucky and find a wire that fell off in the fall. Good luck.
