Question about GE WSXH208A Front Load Washer
Washing machine wont do the final spin
Washing machine is a hoover 1100
  • simon_marr Dec 22, 2008
    i have same problem. any clues? have tried hidden setting 13 but only half spins?
  • dbbbfour Dec 23, 2008
    GE front end washer, 2 yrs old- gets to spin cycle and does nothing. the clock continues to click down and you can hear humming sound. I have already cleaned the filter. Any solutions?
  • 3,741 Answers
If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on Aug 20, 2009
Removing front panel hoover 1100
see the video. God bless you
Sep 22, 2012 | Washing Machines
Hoover performa 1100 ac110 not emptying
After syphoning water out of drum, remove and clean filter located at bottom front left of washer, if there is a screw in the filter cover, unscrew this first.
Remove filter by unscrewing anti-clockwise.
Feb 06, 2010 | Hoover Washing Machines
We have a Hoover select 1500 washing machine. It still washes and rinses ok, but doesn't then move onto the spin cycle. But I can manually set the dial to spin and restart it. It then spins fine. I assume...
Could be but also could be rinse water valve not operating due to faulty solonoid. it does a final rinse / softner before spinning if valve faulty then no spin advance....
Nov 11, 2009 | Washing Machines
Hoover AM1100 Washing machine, wont final spin.
The noise, is it a grinding noisy like worn bearings?
put the washer on drain only - is the pump working ok, take the filter out to see if it is turning ok, does that make a strange noise?
If the pump is fine, its back to that noise, it could be be a faulty tacho on the motor ( regulates the spin speed) or motor bearings - has the motor spindle a lot of play on it?
Let me know how you get on and good look!
Nov 09, 2009 | Washing Machines
Washing machine wont go into full spin
was advised could be bushes so replased them works a treat thanks
Feb 07, 2009 | Hoover Washing Machines
My front-loading Hoover washer/drier (Softwave 1100, Model A8754). Will carry out the wash cycle but not go into spin cycle and thus door will not open. Checked for blockages and none found. Can you help...
Door will not open if it has water in it.
Lay hose down to get rid of water, then you can open door.
Try the spin with no water in, if it spins, then you have a draining problem
Nov 22, 2008 | Hoover Washing Machines
Wont spin
Well yes it could be.... and on a hoover usually is..
but could also be that machine is not draining properley and there fore the pressure switch which affects the final spin is not allowing the machine to spin thinking that there is still water in the machine....
hope this helps any questions dont hesitate to ask...cheers
Jan 09, 2008 | Washing Machines
Hoover 2305 washine machine wont spin
hi, i have a hoover 500 mb, occasionally it will not [ click into ] the wash cycle, then gets confused and does not spin dry properly
Jun 24, 2007 | Hoover HTC243 Top Load Washer
GE WSXH208A Front Load Washer Logo
318 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
