Question about RCA HD52W56 52" Rear Projection HDTV
Patgirl I have a 52' projection hdtv the cable connector is broken. the part is inside the tv that the cable hook into for the picture and sound broke off. What is the name of this part ? Where can I purchase this piece? and how do I fix it?
  • 4,234 Answers
The part is called and "F" connector. It can be purchased but it also muist be soldered in place. This is not a trivial task. The F connector is part of the tuner. For a set of this size, it may be easier to replace the tuner rather than fool around with a repair attempt. Depending upon how it was broken, the PC board inside the tuner may be broken as well requiring tuner replacement anyway.
Dan
Posted on Nov 07, 2008
Yea i have a 52 in rear projection hdtv and i went to move it and the cable piece itself broke off and now the tv power light blinks three times and jus shuts off how can i fix that
the cable connector being broke more than likely has damaged the tuner. sometimes the tuner can be rebuilt depending on the damage. since the set is shutting down there may be more damage. if the set stayed on you might be able to bypass it using vcr. the worst case the small signal board might need replaced that cost aroun 300
Oct 19, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
No HDMI audio at all.
Could be lots of things, from bad cable, to your laptop no outputting sound, to your tv not functioning properly. A work-around might be to use the VGA output (and sound output) from your laptop until you can resolve it better.
Jul 06, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Hd hook up for rca 52"dlp
If you have Direct TV HD the best way is to use a HDMI to DVI cable. If you only have the component (red/green/blue)connectors on the Direct TV Box that would be the best way. You will not have audio using the DVI cable, so you will have to run Red/White cable to the Audio Input.
Dec 16, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
No sound, no picture
when the connector breaks off on these the tumer can become grounded. this can lead to a shutdown situation. In the shop we have been known to repair the tuner. if we can. otherwise we would replace the tuner. we would need to inpect the board with the tuner on it make sure the board hasnt become damaged. replaceing this board requries specal eu\quipment.
Nov 02, 2008 | RCA HD52W56 52" Rear Projection HDTV
Broken Cabel Connector RCA 52 HDTV
depend on how badly damage it might be.. as a tech i replace these all the time.. if you can solder it might be possible.
Aug 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
No sound
Is the DVD player connected to the TV via component cables? If so you should have 5 connectors total that will bring picture and audio information to the TV.
Jun 22, 2008 | RCA D52W19 52" Rear Projection Television
Broken cable connection inside board
No need to buy a PC board. Have professional tech solder leads back and tighten connector
Apr 19, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Cable connector broken
You can buy replacement antenna jacks for this. What you have to do is remove the tuner and it's shields, then unsolder the little tab off the board of the tuner which is what remains when they break off. Then you can resolder the new jack in place and the center pin back to the board of the tuner.
Mar 28, 2008 | RCA HD52W59 HDTV Projection Television
RCA HD52W56 52" Rear Projection HDTV Logo
56 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
