Question about Toshiba Satellite P15-S470 (PSP10U-0GGPGR) PC Notebook (PSP10U0GGPGRPSP10U0GGPGR) PC Desktop
Resetting a bios password
I wanna know were i can go to get free bios password rest software
  • redlife1905 Feb 05, 2009
    ı have a problem with acer travelmate 600 ter, ı want to know how to reset the bios password?
    Problem Solver:
  • 30 Answers
YOU NEED NOT TO USE SOFTWARE TO RESET BIOS PASSWORD. ALL YOU HAVE TO DO IS SIMPLY OPEN YOUR SYSTEM UNIT. UNPLUG ALL CABLES ON IT. GROUND YOURSELF BY TOUCHING @ LEAST 10-15 SECONDS TO THE SYSYTEM UNITS COVER ( SO-CALLED CPU BY SOME) ON YOUR MOTHERBOARD, LOCATE THE CMOS BATTERY, REMOVE IT.
Option #1: Mechanically Removing the Password Most motherboards manufactured over the last decade or more use a battery to sustain the dynamic Bios/CMOS settings for the motherboards PROM chip. These dynamic settings are those manually set by either the computers manufacturer or you, the user. There are two ways to erase these dynamic settings, by either resetting a jumper on the motherboard itself (referred to as a "clear CMOS" jumper), or by physically remove the power from the computer (disconnecting the power plug) and then removing a battery (used to maintain power to the PROM chip that contains the Bios/CMOS information) from the motherboard.
The procedures for clearing a Bios/CMOS without jumpers is essentially the same as those given above when they are present, it just takes a little more effort.
  • Shut down the computer and disconnect the power plug.
  • Locate, if possible, the instruction booklet for your motherboard. If you cannot locate the booklet, then user the motherboard references on this site to locate the manufacturer and see if a manual is available there. You may also want to closely examine the motherboard itself.
  • Now identify where the battery is located on the motherboard. It will be approximately 1/2 inch in diameter.
  • Normally these batteries are held into place with one or more small clips over the face of the battery. Carefully lift the battery out of its socket and set it aside. Note: Some batteries are actually soldered to the motherboard, so take that into consideration and be careful.
  • Leave the battery our of the computer for about 20 to 30 minutes and then return it to its socket.
  • Now plug the power cord back in and restart the computer.
  • When the computer begins it's startup (boot) process, tap the DEL, F10 or F1 key, (whichever is appropriate for your computer) to get into the Bios/CMOS setup. If you need more detailed information as to how to get to the Bios/CMOS setup, follow this link. Bios Basics
  • Once into the Bios/CMOS setup, look for a section or area to set the Bios/CMOS to its default settings. This will return the motherboard to either its basic or optimum settings depending upon the motherboard manufacturers settings. You will then need to verify certain settings, such a CPU and memory as well as hard drive type and size recognition. If you need more information regarding these settings, follow either of these links: For an AMI Bios or for an Award Bios.
  • After making any final adjustments, save your settings and restart the computer. The Bios password should be gone and the Bios set to its optimum settings.
Posted on Nov 07, 2008
Reset bios password
Hi, its very easy to reset password for bios.
You have two methods to rest on two different conditions.
First if you want to re-set in normal mode and a second thing if you have forgotten the password.
First of all enter into Bios Setup then Security and Reset your password.
Second if you have forgotten your password and you need to reset without power on your computer take these steps;
1. Uncover your computer
2. See a jumper near to hard connector. This jumper sets on two legs total of three and one leg free.
3. Changer jumper side ... It sets on free leg and then one leg will free.
4. Now, starts on your computer, it will give you a message. Now follow the message and accept changes for Bios and press enter.
5. Once again switch off your computer.
6. Reset jumper on the same place and cover your computer again.
7. Start your computer enter into Bios without any password. Now you can set your password from security tab again.
Wish you Good Luck
Nov 30, 2013 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Ijust wanna boot my laptop and to remove BIOS sytem password
I would first try resetting using software, here are two software apps to reset or retrieve BIOS passwords.
!BIOS - is a PC BIOS toolkit offering password removal/decrypt and BIOS settings modification/backup/restore...
You can download it here:
http://www.syschat.com/download120.html
CmosPwd - Cmos password recovery tools
http://www.syschat.com/download121.html&act=down
You will need to create a bootable Dos, or Linux or NT cd in order to run them.
Good Luck!
Jun 27, 2012 | Dell Computers & Internet
Toshiba Laptop Satellite M30-742 Power On Password Reset????
BIOS passwords can be reset in two ways:
1. using software 2. using hardware.
Jun 27, 2012 | Toshiba Satellite Computers & Internet
Evo N610c bios password
BIOS passwords can be reset in two ways,
I would first try resetting using software, here are two software's to reset or retrieve BIOS passwords.
Please let us know if it works.
May 29, 2011 | Compaq Evo N610C Notebook
NEED TO CLEAR BIOS PASSWORD
Hi
May 12, 2011 | Sony Vaio PCG-7F1L PCG-8A1R PCG-8C3L...
I dont have the cd. i bought it at a tag sale. and i just put it together and its asking me for a password. i dont know it. so i wanna restore it to factory settings so that it erases...
If you are locked out of the BIOS then you can try and find default passwords for the BIOS online which may work, otherwise you will have to open up the case and remove the CMOS battery to reset the BIOS password. If it is a password in Windows, you will either have to buy a copy of Windows and use that disc, or download software which will allow you to 'crack' the password. Be aware however that using this software on a computer which you do not have the right to is illegal. I hope this helps and have a nice day!
May 03, 2011 | IBM Netvista 6793 (RB6793XX5) PC Desktop
Hp probook 4310s bios password reset pls
To reset the BIOS password read the information from this link.
In case of your laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper and I wouldn't recommend doing it especially if it's under warranty.
Feb 23, 2011 | HP ProBook 4310s Notebook
Forgot my bios password on my Dell Inspirion B130.
Ways you can search from Google can be many. So which one will be the best in your opinion? But I think if with an admin password using it to login will be the best way. And with a reset disk to reset it can be the best reset tool. The two are free. For paid one reset software, Anmosoft Windows Password Reset can be the best one for me. Windows Password Reset Software
Oct 03, 2009 | Dell Inspiron B130 Notebook
Forgot my password
I would first try resetting using software, here are two software's to reset or retieive BIOS passwords.
CmosPwd - Cmos password recovery tools 4.8
Feb 22, 2009 | HP Pavilion ze2000 Notebook
Computers & Internet Logo
477 people viewed this question
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
