There are 32 flats in our block of retirement flats. 16 facing the main road & 16 at the back' we have one comunal aerial. 15 0f the flats facing the main road are having problems with reception but i myself am not. this has only started in the last week. Can you help
  • 4,234 Answers
Normally in this type of situation, there are distribution amps at the aerial. I would look for a defective amp. The one that is working of the 16 on the main road side is likely to be the one closest to the amp. In other words, it has the shortest cable from the common aerial.
Check the amps and update this if the amps are good and we'll look elsewhere.
Dan
Posted on Nov 07, 2008
Hdtv or converter box
If the TV is already hdtv...no. Try reprogramming tv to find hd stations or if receiving signal from outdoor aerial make sure aerial is digital and facing right direction.
Nov 30, 2013 | Mitsubishi WS-65315 65" Rear Projection...
I have a Panasonic tv model TH 42PZ80B; a Panasinic Blu-Ray dvd model DMP-BD50; a sky box (not as yet HD) and a Sony video SLV-SE 830G. I have a Satellite dish and a normal TV aerial. In the loft I have a...
You need to try and isolate the piece of equipment which is causing the problem.
You've already tried the aerial lead direct to the TV and this is OK.
Disconnect all scart leads and try the RF on its own.
Try the Aerial lead to video, then video to TV.
Try aerial direct to Sky box, then to TV.
Try just connecting the RF out from the Sky box to the TV (no aerial input), can you tune into a good channel 68 picture from the Sky box.
Then Try the VCR to the Sky box (no aerial input), see if you can tune into the VCR and Sky channel.
Hope that helps.......
Jul 10, 2008 | Televison & Video
Not getting all stations with new digital aerial & digi tv ? location goring-on-thames rg8 oep . larg mast plus professional aerial 16.5 db high gain .
May i please know the model and the make of the product in details so that it can help me resolving the issue is a more prompt manner
Apr 16, 2008 | Televison & Video
What is difference FAT16& FAT32
Hi Nalayaik,
Please find the difference between the FAT 16 & FAT 32
FAT 16:
It is the Original file system user in DOS and Windows 3.x., and was originally only designed for user on relatively small partitions
It's been revised so that it's possible to make a FAT16 partitions up to 4GB in Size, but no more than that.
FAT 32:
It's a revised version of FAT16 that can be used to create much larger partitions and has native support for long filenames, and was introduced with Win98.
Both FAT16 and FAT 32 are also backwards and cross-compatible with older versions
Regards,
Aysaam
Feb 27, 2011 | Televison & Video
I have A toshiba 57HX81 tv red ligth blicking.i found (2)5 amp pico fuses at F850 & F851 & (1) pico fuse 2AMP at F852 would replacing these fuses bring the tv back to life.
Too many possibilities to predict if the fuse replacements will make the set function again but I suspect your main power supply has failed so if the fuses blow after replacement, you may have to have the supply repaired or replace it.
You might check, using your model number, at the site below to see if they have a power supply 'pull' available from their stock. They part out retired sets of all kinds.
Jimmy's Parts
Nov 27, 2010 | Toshiba 57HX81 57" Rear Projection...
MY TV with Freeview has lost almost all its channels after the re-tune. I've tried 4 times, always switch off at the mains, tried again this morning. I'm not prepared for my 4-month old TV to become...
I rang the Alba helpline, whose cs lady told me I should have an outside aerial with this product anyway, and advised me to move my indoor aerial to the window-sill. Worked. Happy.
Oct 01, 2009 | Televison & Video
Ive bought an aerial for my tv but its not getting good signal or all the channels. i live in a basement flat so i dont no if this is the problem. what do i do?
What kind of TV do you have, does it have a tuner in it? What type of aerial did you get , does it go on your TV or is it outside? Is the aerial HD or Standard? These are some things I need to know to help you.
Oct 16, 2008 | Televison & Video
In London, Uk. I have poor reception of channel 5. have got recently a one for all powered aerial. how do I set it up? Model sv-9140-00-002
Your reception would be much improved by using a free to air digital set top box - only about £20. If you are in east London especially near docklands channel 5 reception with a conventional aerial gives a lot of problems. sv-9140-00-002 is an interior aerial booster - I doubt whether this will improve things much. Best solution is a good outside aerial - if you live in flats is there no communal aerial available?
Mar 17, 2008 | Televison & Video
Open Questions:
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
