Question about Philips 27MT3305 27" TV
Shuts Off Immediately
Powers on for only for only 4-5 seconds with picture and sound, then shuts off unless you continuosly change chanels. And after shutting off, the 'power on' light stays on until you hit power off. Then it can be turned on again and does the same thing.
  • Darrell Schiller Oct 16, 2006
    I checked inside today for loose connections and found none. I even pulled the fuse and reinserted it to be sure of no corrosion. I was suspecting a bad relay or something. Remember that the power light stays on. How far into the circuitry would that suggest the problem to be? I am no expert, I just tinker with a lot of success. And I know the high voltage dangers. Can you help me by descibing the shape of the relay if that could be the problem? I was thinking the rectangular shaped component. Thanks for any help you can give me.
  • Darrell Schiller Oct 19, 2006
    I don't know what a scart is. But can you tell from the photo which capacitor(s) might be the one?
    Scholar:
  • 68 Answers
Does the TV shut off if a signal from the scart is selected? Philips sets have an annoying habit of going into standby after a very short time if there is no video for the synchronising circuits to lock onto. I find this a nuisance when I am searching for a signal from satelites when you move the dish. By quickly changing channels you are resetting the shut down circuit. This must be a time-out circuit controlled by a capacitor charging (I suspect) which has gone low in value, probably electrolytic. Replacing the capacitor should solve the problem.
Posted on Oct 17, 2006
Where do you get a capacitor?
Posted on Aug 24, 2008
    Sergeant:
  • 337 Answers
The changing channels part is trowing me off,my first attempt will be to hit the tv on the side to see if it reacts or behaves different,you can try it while you are changing chanels to see if when you stop stays on,what we are looking for is a loose conection witch will be easy for you to take care of,if the set continuos to shutdown it might have a problem in the shutdown circuitry(rare)and being activated without a reason or a component is breaking down and is triggering it.When you change channels the current for the brighness changes constanly and it might not reach the poit of breakdown the triggers the shutdown.Another reason might be the B+ source for the output transistor is too high and being regulated therefore every voltage in the secondary of the output transformer is too high and that will trigger the shutdown circuit. If you are familiar with tv service you have a place to start but if you are not too familiar be safe and call for assistance.Let Us know how it goes.
Posted on Oct 16, 2006
  • 2 more comments
  • Omar Urrutia
    Omar Urrutia Oct 16, 2006
    Correction!!!!.........The B+ source not being regulated....
  • Omar Urrutia
    You rating response is important too.
  • Omar Urrutia
    Omar Urrutia Oct 17, 2006
    To answer your question the relay is of a rectangular shape about 1.5 high x .5 thick and 1.75 wide.
    With the light staying on is still possible the theory of the shutdown circuitry being trigger by a breaking down component.To troubleshoot a problem like this one you will need the service manual so you can check some voltages and check some components with a meter.If the picture quality is good and is not distorted before it shutsdown is even harder to find the problem,any distortion or maybe lines in the picture can guide us in the right direccion.If you dont have the manual and wish to order it you can go to www.servicemanuals.com,If you are familiar with the use of a meter and tv service We can go on until We get right but if you are not familiar you should call for assistance from a servicer.
    If you notice anything different as far as symptoms please let me know.You can post another question and use my name ,I will respond.
  • Omar Urrutia
    Relays are rated 12 dc and usually of a black color.For me to conclude that a relay might be bad I would have to check some voltages.
SOURCE:
No Picture but still has sound
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php It's major symptoms are clicking,electrical sounds,shuts off and on and get the lamp indicator. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs,It's major symptoms are clicking,electrical sounds,shuts off and on and get the lamp indicator, it could be time to replace the lamp.The lamp you need is 915P049010. you can find it here: http://www.discount-merchant.com/Mitsubishi-915P049010-Lamp-Replacement-p/mitsubishi-915p049010-lamp.htmHave a blessed one!
May 03, 2010 | Mitsubishi WD-57731 57" Projection HDTV
EX-510 Powers up, them immediately shuts down
I have the same problem is there a fix? marksugar@aol.com
Jul 12, 2009 | Casio EXILIM Card EX-S770 Digital Camera
Tv powers off after 1sec being on?
does the led flash when you try to press power after it shuts down, or when it shuts down? If so how many times does it flash?
Jul 18, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Phone powers up and immediately shuts down
Normally it is battery problem. First check your batter by charging fully. If your battery is ok but same problem then you need to reflash the phone, I mean reprogram the phone.
May 18, 2008 | Samsung SGH-X700 Cellular Phone
H.V shuts down/
try to check a bad conections in hv transformer and capacitor around them
Feb 01, 2008 | Zenith B27A11Z 27" TV
Philips 27MT3305 27" TV Logo
187 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
