Question about Mitsubishi WS-55807 TV
TV picture curves
The picture on my 55807 curves up and down on the outer edges of the screen the colors also seperate as the picture moves to the outside edge. this happened once before and repair tech said it happens freqeuntlyCan you tell me part name and # and where to find
  • advancedlawn Nov 07, 2008
    I cant find the ICs
  • 4,234 Answers
This is a convergence problem and is usually either bad connections at the convergence ICs or defective ICs. If you can solder, you can fix this yourself. Locate the convergence ICs (large black Ics attached to a heat sink and marked STKxxx). Resolder the pins first. If that fails to resolve the problem replace the ICs.
Keep us posted.
Dan
Posted on Nov 07, 2008
Colors seperating and out ends of screen curved
Tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignment,have colors pictures shadows or 3D pictures look alike.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Oct 27, 2010 | Mitsubishi WS-55809 55" Rear Projection...
The red coler has started to curve about a third of the way down the screen. everything on the the screen is distorted and doubled in red
if your picture looks 3d it is convergence problem.
This is a do it yourself repair if you have some skill.
I will tell you what you need and have start to finish, step by step instructions for this repair along with photos, and source for parts needed(parts cost will be under 30 dollars).
reply here if I can help.
SD TECH
Oct 24, 2010 | Mitsubishi WS-55807 TV
The color is way off on the tv. It also looks curved, like if there are words on the tv they go up at an angle toward the edges of the tv. When you try to align the color on the tv you can get the center...
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 01, 2010 | Philips 60PP9202 60" Rear Projection...
52'' Projection TV SONY
this is a problem with the convergence chip. you can try to adjust the convergence in the menu settings of the t.v.
pin cushioning will correct the curves, convergence fixes color seperation.
write the number down before changing them, in case you make it worse.
Nov 11, 2009 | Sony Televison & Video
Colors have seperated on tv, and curve
You have a convergence problem.
Maybe need change the IC of convergence, or the power supply of these parts.
Bye.
Apr 04, 2009 | Mitsubishi VS-50501 50" Rear Projection...
Color seperation on rca 1998 46" rear projection tv
projection tvs have seperate color bulbs that put out the same picture the lenses just need to be adjusted. they probably shifted during the move.
Dec 04, 2008 | Televison & Video
Toshiba 43A9UE convergence problem
Check the resistors right next to the Convergence ICs often 1 or 2 of them go oen when the ICs fail.
Feb 09, 2008 | Televison & Video
Color is not good around outer edges of picture
When the colors are off around the edges on a regular picture tube TV, it usually means that the degaussing thermistor's solder joints have cracked loose. Another possible cause is that a strong magnet, such as in a stereo speaker, was brought very close to the picture tube and has magnetized the tube. Resoldering the solder joints on the degaussing thermistor and demagnetizing the picture tube should put the color back to normal.
Aug 17, 2007 | Toshiba 32AF45 32" TV
Arched picture at bottom seperating the green and red
Your tv has a convergance failure. the convergance ic's need to be replaced. Upgraded part # STK392-150 or STK392-160. Both ic's should be replaced to prevent future failure of other colors.
May 20, 2007 | Toshiba 43H70 43" Rear Projection...
Mitsubishi WS-55807 TV Logo
108 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
