Question about Asrock P4I45GV P4/845GV/FSB533/A&V&L/Modem/MATX Motherboard (MOTASR20)
Mainboard problem My Mainboard can't power on
  • Pa Aam Nov 13, 2008
    Your solution very excellent. my maindboard already working properly
  • 97 Answers
Check your power supply the voltage and check all your jumper settings on the motherboard
Posted on Nov 09, 2008
Power supply or mainboard?
what is the model # of your TV
Jun 02, 2013 | Televison & Video
Canon ipf750 error 03130031-2618
Hardware error. 03130031-2618
Turn off printer, wait, then turn on again.
03130031-2618 VH voltage error
Check the power supply unit.
Mar 01, 2012 | Canon imagePROGRAF Office Equipment &...
Computer Worked Fine, Shutdown to move it, hooked back up and nothing. No Fans, No Light, No Nothing.
Open the side panel of your computer chassis and ensure that all power connections are making good contact with the mainboard. You will need to go through all internal connections and push them in.
Pay special attention to the 24Pin mainboard power connector and the 4Pin CPU power connector. Also check that the power switch is connected to the header on the mainboard. The header for power switch can be found near the power and HDD LED connections.
Take care!
damnor01
Jul 13, 2011 | Gateway GM5472 PC Desktop
NO power on motherboard
hi check this list in that order
1- swicth on your power supply 2- power cable to the casing to the motherboard 3- your power casing swicth and reset (if the sw go on and off 4- clear cmos jumper 5- onplug your harddrive dvd all pci card ect.. evrerithing. keep only the minimum cpu ram and videocard if you dont have one in your mainboard 6- change termalpaste 7- change ram 8- change cpu
and now if your mainboard dont start your mainboard is dead
good lock
Oct 21, 2009 | MSI 845 PRO Motherboard
Power comes on; monitor blank; no power to usb but power to cdrom drive
Could be mainboard.
Seems like a mainboard issue. If the unit finishes booting I would say possible video card but really seems like mainboard to me.
Oct 10, 2009 | HP Pavilion a1410y (RB042AV) PC Desktop
EMachines T2824. Does nothing but light on mainboard coming on...
This is a motherboard problem. You'll need to replace it. Although, it may be cheaper just to buy a new PC (eMachines are never very expensive, or well-made for that matter)
Sep 22, 2009 | Computers & Internet
The monitor led is green but it gives white flash and still blank
Check the volatage regulator in the mainboard resolder all you found dried unsolder parts inside mainboard. Voltage test the regulator IC if have a voltage flow 2.5 to 5v DC. check ribbon cable connector from mainboard to controller board if properly connected. In the controller board find the small fuse test it for open.
Reminder:
When you voltage test in the power board
in the primary section of power supply
use hot ground. Do not use the hot ground
when you voltage testing the secondary
power supply, mainboard and controller
because it will cause of damage
semiconductor. For safety use cold ground
for secondary, mainboard and controller
board.
Aug 29, 2009 | ViewSonic VA712 17" LCD Monitor
My A21m power button will not turn on laptop. Button just clicks and system will not turn on. Battery and power cord ok.
Check if it is plugged in. If not, you may have a problem either with your mainboard, battery, or power button. Try replacing your battery. If it still doesn't power on, contact lenovo support for a mainboard replacement. The battery should be roughly $100, and the mainboard roughly $200. Since your computer is quite old, the costs of repairing it may exceed the cost of a new computer.
Jun 13, 2009 | IBM ThinkPad A21m 2628 Notebook
Asrock P4I45GV P4/845GV/FSB533/A&V&L/Modem/MATX Motherboard (MOTASR20) Logo
98 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
