Question about HP Color LaserJet 3500 Printer
Fuser Error 50.1 Fuser is hot. What is a fuser?
My hp laser jet 3500 is showing an error message in the dispaly window. It says "50.1 Fuser Error. Fuser is hot. Press both sides of fuser to ensure it is fully seated." What is the fuser and where is it located?
  • 12 more comments
  • winney Nov 05, 2007
    My friend handed me down her Lexmark x5150 printer and I just bought some pare for it, downloaded software from the Lexmark website and now it does not want to print. First of all, the paper wont flow through and I am getting the 50 error on the little screen. help me I do not understand what is happening.
  • Anonymous Jan 07, 2008
    Received the above error; how do I fix it?
  • Anonymous Mar 02, 2008
  • das_gitu Mar 07, 2008
  • Anonymous Mar 16, 2008
    i faced same problem fuser is hot.what is a fuser problem and notify you when a new solution is offered
  • Anonymous Mar 25, 2008
    50.2 fuser error
  • Anonymous Apr 23, 2008
    yes i have as requested same thing appears again 50.1 fuser error
  • msaenz Apr 23, 2008
    yes please help!
  • jreynolds Jun 27, 2008
    How to fix 50.1 Fuser Error?
  • bwekesi Jul 11, 2008
    When I print, printer diplays an error message '50.2. Fuser error
  • ybouttenot Jul 31, 2008
    My error message says 50.1 fuser error, turn device off and ensure fuser is fully seated. What is the fuser?
  • TxTiff Feb 26, 2009
    My HP Color LaserJet 3550 says 50.1 Fuser Error.
    We just replaced the fuser and double and triple checked how it was installed and the error message still shows up.
    We called HP and they were HORRIBLE! and wanted to charge us for them telling us over the phone how to fix it.
    Please help!
  • laws1 Mar 29, 2009
    50.1 Fuser Error
  • wonderbread5 Apr 07, 2009
    hp laserjet 3330 got the error faser 50 message after changing the cartridge.  whats up?  and where is the fuser?
I think the fuser is in your **** part. This problem can be corrected by sitting in a tub of salt water. Make sure the printer is plugged in and is powered on. Is the display lit? If it is place the printer in the tub of water you are sitting in. You sould now be able to realize nobody cares and it no longer matters
Posted on Nov 29, 2010
    Problem Solver:
  • 15 Answers
FUSER does not hold any powder. The toner holds the powder. When the paper gets pulled in toner gets placed on the paper and slides under the fuser. The fuser is always "hot" and bonds the powder "toner" to the paper. There is a few other things that go on but thats the main thing. If you are getting that fuser error that means 95% of the time that you need to change the fuser.
Posted on Nov 15, 2006
  • 64 Answers
50.1
A low fuser temperature error has occurred, possibly due to an inadequate external or internal power supply.
this basicaly means that either the dc controller board is on its way out (expensive) or that there is a drain on the power line.
if you have it plugged into an extension lead try plugging it directly into the wall socket. if this fails also try using a different power lead (very easy to get hold of and are normaly called kettle leads)
Hope this helps
Cops
Pete@wedotoners.com
Posted on Oct 10, 2007
The fuser module actually fuses the toner to the paper, there is no real equivelant part in an inkjet. If you are getting a 'too hot' message, it is because you are printing very frequently, or you are printing large documents. Turn the printer off for at least 30 minutes, then turn it bvack on. This should allow the fuser to cool and clear the error.
Posted on Oct 20, 2006
    Novelist:
    Champion:
  • 256 Answers
When the fuser unit in your printer gets too hot, your system would start showing fuser error and this error is usually displayed as "Service Required Fuser Error". To resolve this issue, you would have to switch off your printer and wait for sometime for the system to recover. After that restart your printer and try again.
Posted on Aug 22, 2011
    Novelist:
  • 114 Answers
The followin article describes with diagrams how to locate and replace a fuser module in an HP Laserjet 3500. http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=125&prodSeriesId=315862&prodTypeId=18972&objectID=c00046239 The fuser is the component that holds the powder that gets printed, or fused, to paper. Think of it as the equivalent to an ink cartridge in an ink-jet printer.
Posted on Oct 16, 2006
Thank you
http://www.miniwb.com
Posted on Mar 25, 2008
How do I change the fuser
Posted on Nov 06, 2008
We exports the parts for the copier and printer,the toner cartridges,minolta toner,toner,canon copier toner,photocopier toner,bulk laser toner,compatible laser toner,printer toner cartridges,cheap toner,fuser error.
fuser film sleeves if you need these parts,just feel free to contact us.
Posted on Mar 17, 2008
3 Suggested Answers
SOURCE:
  • 25 Answers
SOURCE: Fuser Error 50.1 Fuser is hot. What is a fuser?
MAKE SURE THE PRINTER IS OFF AND INPLUGED BEFORE YOU START! The fuser is located in the back of the printer. You should see two blue pads where your index finger and thumb (on both hands) should pinch together then pull the fuser out. Re-seat the fuser back into its original position and wait 20 minutes before turnging Unit back on. If you do not wait 20 mins then the 50 error will appear again even if the problem is fix. Once you wait 20 minutes and it still gives you a 50 error you must replace the fuser. I have a great place to purchase fuser so let me know if you nee contact info!
Posted on Jul 16, 2009
Maanita
  • 1142 Answers
error 50 means your fuser assembly has gone bad or its not getting power to be functional. you need to replace the fuser unit.
Posted on Aug 17, 2008
My printer hp laser pro 400 show message 50.3 fuser error
hello ,,
50.x Fuser Error
Description
The product has experienced an error with the fuser.
Recommended action
Turn the product power off, wait at least 30 seconds, and then turn the product power on and wait for it to initialize.
Turn off the product, wait at least 25 minutes, and then turn on the product.
If you are using a surge protector, remove it. Plug the product directly into the wall socket. Turn the product power on.
If the message persists, contact HP support.
Oct 21, 2013 | HP LaserJet Pro 400 M401DN Laser Printer
Each time I try to print envelopes on the HP Color Laser Jet CP3505x printer, I am gettig a Fuser 50.2 error message
It's unfortunate Janice but your fuser cannot get hot enough to print on an envelope and the only thing you can do is buy another fuser... sounds like the fuser is still able to heat up enough for regular prints on regular paper so you may want to keep it around for a spare but companies usually sell cheaper when you have a core to return to them... Click Here for Fuser
Oct 03, 2011 | HP COLOR LASERJET CP 3505 N PRINTER
50.1 fuser error not fixed by instruction on machine; HP color laserject 3500
17 posts - 8 authors - Last post: 23 MarWe are getting a 50.1 fuser error with our Colour Laserjet 3500 printer ... fuser from HP in the UK, but was told that they are not currently available ... hi I have the same problem error 50.1 with two machine 3500/3550 ...
www.fixyourownprinter.com/forums/laser/31146
Dec 04, 2009 | HP Color LaserJet 3500 Printer
Our HP Color Laser Jet Printer keeps saying 50.2
Hi ellenf971:
Here is your problem.
50.X FUSER ERROR
50.2 error - Fuser Failure (Abnormal Warmup).
Perform the following steps:
1. The connector between the fuser and the
printer is not connected properly. Reseat
the fuser. Check the connector J5013
between the fuser and the printer. Replace
it if damaged.
2. Break in the main thermistor. Turn the
printer off and remove the fuser. Measure
the resistance between the fuser
connectors J5013LA-2 (MAINTH) and
J5013LA-1 (GND). If it is not within the rage
of 330k ohms to 50k ohms (at ambient
temperature), replace the fuser.
3. Break in the fuser heater. Measure the
resistance between the fuser connectors
J5013L-2 (FSRH) and J5013L-1 (FSRN)
with the fuser removed. If it is not within the
rage of 12 ohms to 52 ohms (at ambient
temperature), replace the fuser film unit.
4. Faulty DC controller. PCB Replace the
DC controller PCB
you will have to get an HP certified technician to replace the fuser assembly.
Hope this helps
Jul 17, 2009 | HP Office Equipment & Supplies
Fuser 50.1 error on HP 3500 printer
From HP Website:
50.X FUSER ERROR Description A fuser error has occurred. Action
  1. Turn the printer off.
  2. Verify the fuser is properly installed and fully seated.
  3. Turn on the printer.
  4. If the message persists, contact HP Support.
Mar 23, 2009 | HP Color LaserJet 3500 Printer
HELP! 3 year old HP color Laserjet 3500 Installed first fuser kit...error message 50.2 fuser is hot message. Worked through directions; same message appears repeatedly.
The connecter between Fuser and printer is not connected properly. Reset the fuser.
To remove the fuer fuser and measur resistance between the fuser connectors J50132A-2(mainth)and J50132A-1 (gnd) if it is not within the range of 330k ohms TO 50k ohms at (abient temp) Replace the fuser.
Oct 08, 2008 | HP Computers & Internet
Aug 17, 2008 | HP Color LaserJet 2600n Printer
HP Color LaserJet 3500 Printer Logo
35,371 people viewed this question
Clive
Clive
Thomas F. Schneider
