Microwave Ovens Logo
Anonymous Posted on Mar 24, 2012
Sharp R-H81 i see arcking from acces covet insde top
Anonymous
Level 3:
  • Microwave Ovens Master 6,771 Answers
  • Posted on Mar 25, 2012
Anonymous
Level 3:
Answers
6771
Questions
0
Helped
1778973
Points
21413
Clean with warm soapy water until spotless, if no! the hood may need to be replaced, especially if there are bare metal exposed, also check the interior for peeled white enamel paint.
I NEED A FREE USERS MANUAL FOR SHARP CONVECTION MICROWAVE MODEL R8570
Manuals Lib has the Operation manual for the Sharp Carousel II R-5870 here: https://www.manualslib.com/manual/987690/Sharp-Carousel-Ii-R-8570.html . If you want to download a copy of the manual, click on the Download button near the top left of the page.
I hope this helps.
2answers
User manual for a model R-209 AK counter top carousel microwave
Free Sharp Microwave Oven User Manuals ' ManualsOnline ...
kitchen.manualsonline.com > ... > Sharp > Kitchen Appliance Sharp
Products 1 - 50 of 359 - Top Automotive Device Types ..... Sharp M I C R O WAV E O V E N OPERATION MANUAL. Pages: 0 ... Sharp Microwave Oven 209H ... SharpOperation Manual Microwave Oven R-308H, R-305H .... Sharp Microwave OvenMODEL R-2197 ... Sharp over the counter microwave oven operation manual ...
SHARP MICROWAVE OVEN Parts ' Model r209ak ' Sears ...
www.searspartsdirect.com/model-number/r209ak/0958/0123245.html
Shop for SHARP MICROWAVE OVEN repair parts for model r209ak at Sears ... Find part in diagram SHARP Countertop Microwave Model # R-209AK.
User manual for 1200 w carousel ser# 57088
Products 1 - 50 of 359 - Sharp Microwave Oven 11452 User Guide. Pages: 0 Saves: 0 ... Sharp Operation Manual Microwave Oven R-308H, R-305H. Pages: 0 ...
Free Sharp Convection Oven User Manuals - Kitchen .
Get a replacement bulb for sharp carousel microwave table top oven .
A quick look at the manual doesn't specify the part #. It just says replace with the same type and not more than 30 watts. http://www.sharpusa.com/downloads/archives/product_manuals/mic_man_r1500_1501.pdf
Here is a link to an online parts place that you can enter with your model #:
Replacement Sharp parts Select from 266 models Microwaves
How to replace bulb for sharp microwave
remove power
take the top off
find the bulb holder
unscrew it
go to the hardware shop and buy one off the shelf
or the 1 pound shop
screw it in and put the top back on
I have a brand new sharp kb6524ps drawer microwave and the top face plate is loose. How can I tighten it?
Is this unit 'brand new'??
Call Sharp Electronics @ 800-BE-SHARP. If you received it this way, it may be shipping damage. Contact the seller.
1helpful
Bulb replacement model BEL/CJS21
You need to take the 5 screws out on the back and side oc the cover - 2 are a special screw head but if you jam a small flathead screwdriver in you can snap off the tiny stud so that you can now use a star driver. (be prepared to damage the screwdriver head). The bulb can be seen in the black plastic assembly surrounded by wires. You can just about unscrew the bulb with 2 little fingers - hey presto squeeze new build in and pug covet back on
1helpful
Sharp carousel 1993 r1420b, how to remove from
One of these installation manuals may be close enough to yours to help you: manual 1 | manual 2 | manual 3
Microwave is arcking
Quite often this is due to grease or food particles stuck to the inside of the oven or stuck on or behind the waveguide cover.
The waveguide cover is usually about the size of a playing card and often held in place by a plastic rivet.
In some models it is the plastic ceiling.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If your waveguide cover is burned, it will need to be replaced.
If you need more specific help, please reply back with your brand and full model number.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
1helpful
Re:tv
Hi Redd, You might have better luck posting this under Sharp TVs: http://www.fixya.com/support/sharp/standard_televisions The black lines at the top of the screen are usually an indication of a problem with the vertical output section. It's often bad electrolytic capacitors, the vertical IC, or both. That's apparently not a US model, so it will be hard to find the values but you could contact Sharp Philippines: SHARP (PHILS.) CORPORATION [Philippines] Km.23 West Service Road, South Superhighway, Alabang, Muntinlupa,Metro Manila, Philippines Tel: 63-2-842-1371 Fax: 63-2-842-0530 Service Center Tel: 63-2-807-4991/4992 Fax: 63-2-807-0388 Home Page: http://www.sharp.ph/ Good luck.
Top Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
