Question about StarTech.com VGA to NTSC/PAL PC to TV Video Converter (VGA2NTSC) Video Capture
Ive just bought a TV to PC(VGA TO TV Converter), ive connected everything and i can see my laptop screen on the TV monitor but there is no sound
  • 3 Answers
The VGA+USB To VGA+USB Extender(GBS-125) Can help you to solve your problem.
HD Video&Audio Extender PC to HDTV Extender/Splitter
Details: http://www.gonbes.com/en/Gonbes-GBS-125.html
Technical Support: Mr. Wu
E-mail:sandy@gonbes.com
TEL Phone:0086-755-82053232 FAX:0086-755-82053969
ADD:NO.4W Suotaike Building, Bagua 4 Road,Futian Shenzhen, Guangdong 518029 China
Posted on Jul 31, 2010
  • 123 Answers
I dont think the unit is designed to use sound, it just converts vga to tv, you may have to use a 3.5 to rca phono audio cable to go from the laptop to an audio device, or an imput on your tv
Posted on Nov 07, 2008
Toshiba large screen - connected to my laptop with an Auvio USB to HDMI adapter.
First confirm that you do not have a VGA connection for a PC in the back of your TV. Many PC's connect directly into the TV's with VGA connection provided. If only HDMI then a converter can be a reliable alternative.
A VGA to HDMI converter may be a better solution. This particular device identified in the link has the power from the USB of the laptop to operate, the sound from the audio out of the laptop, and assuming you have a VGA out for a monitor the connection to the converter will give you choice of resolution.
There are many different units available and the one in the ink is just an example.
Hope this helps?
Syba Portable VGA to HDMI Converter with Audio Support
Oct 31, 2016 | Toshiba Computers & Internet
VGA to HDMI converter connection and set up
Use VGA adapter to HDMI works for video
Sound is carried over stereo cable
What you are doing needs 2 cables
Video cable for video
Sound cable for sound
Using TV for monitor VGA to HDMI 32" at 120 refresh is best dot pitch .
over 32" dot pitch is lower may become grainy resolve place monitor away more from you when using over 32" TV 120 refresh is important
Jul 15, 2016 | Computers & Internet
Why wont my compaq computer plug into a tv?
You probably have to "tell" the TV to see the monitor. In other words, there might be a VCR/DVD/VGA(computer) setting/switch on the TV menu. The TV might not find the computer automatically like a monitor does. Good luck.
Jan 08, 2018 | Compaq Computers & Internet
Connecting VGA Screen to HDMI laptop
Press and Hold "Fn" and then press number key with "square / square w/ legs (like monitor)" icons
Jun 18, 2013 | Computers & Internet
Can i connect my acer aspire 4730z to my television so i can watch dvds
Yes of course.
First of all you will need to identify the available input ports on your TV. An RCA port is generally standard nowadays and it consists of a red, a white and yellow coloured reception ports (the colours may differ between tvs, i.e black instead of red). The red and white are for stero sound and the yellow is for video.
Modern TV systems also have a VGA adapter which is small flat port like the ones on a computer screen. This is usually blue.
A third option is an S-Video port, which is round in shape.
To connect your laptop using the RCA port, you will need an S-Video to RCA converter. You connect the S-Video to the port on your latptop, and through the converter to the RCA yellow port on your TV. For sound you will use another cable that connects to the headphone jack on your laptop and then splits to a white and a red cable to connect to your TV.
If you have VGA port on your TV, then connect the VGA port on your laptop to the VGA port on your TV. No converters needed. For sound you will use the same approach as above.
To use the third option you will need to have an s-video out port on your laptop and you will connect it directly to your TV s-video port. For sound, again you will use the approach as the rca solution.
Then, using your remote control, select the AV mode or depending on your TV select the PC or VGA mode.
Finally, to transfer the video from your laptop to your TV press and hold the Fn key on your laptop's keyboard and then the F7 or F9 key. (It has s small TV icon on it).
That's it!
Regards,
nicolasiac
Apr 08, 2010 | Acer Aspire 4730-4947 Notebook
When i connect my laptop to the tv i get sound but no pic.
Computers have two seperate systems - one for video and one for sound.
The only computer (or laptop) connection that carries both video and sound is HDMI. If you do not have a HDMI/DVI connector on the back of your computer, then you will have to use the VGA-composite or s-video connectors to display your PC's output on an external monitor like an LCD TV.
On both my HP and Dell laptops the display settings (Start/Control Panel/Personalize/Display Settings) allow two modes - single or dual monitor mode. Single monitor mode allows me to switch between any one of three possible video outputs - VGA-composite, S-Video or laptop screen, or a split-desktop (display spread over two seperate monitors). Dual monitor mode allows the same display on any two of three possible video outputs.
Switching is performed using the fn keys on the keyboard (fn key plus the F2, F8, etc. function key with the display marking). You guys use single monitor mode until you figure out what your are doing. Select VGA-composite or S-Video.
Non-HDMI sound to your TV monitor or sound system must be obtained from your laptop's Headphone or S/PDIF jacks. Headphone is stereo and S/PDIF is 5.1 surround sound. Headphone is electrical, but S/PDIF may be electrical or optical (laser light). You must set the sound jack that you intend to use as the default on the PC control panel (Start/Control Panel/Sound).
None of these connectors is two-way in the context of an LCD monitor - your PC cannot record a TV picture or sound from the external monitor. To accomplish this you must purchase a video converter box that converts cable TV or video+sound inputs to USB format usable by your laptop. Do this and you can turn your laptop into a Tivo recorder/DVD burner using Beyond TV, Sage TV or a variety of other software packages.
Feb 11, 2010 | Dell Studio 1537 Laptop
Use TV as external monitor from laptop
no tube tv won't mirror monitor. needs vga connection at the back of tv.go to store have a look at lcd or plasma screen.the card is ok.
Jun 26, 2009 | HP Pavilion DV6500Z Notebook
How to connect a eye trek fmd 200 to my laptop
It is not possible to connect your eye-trek directly to your computer.
you need a signal-converter (vga to av).
Have a look on ebay (e.g. this one on german ebay: http://cgi.ebay.de/ws/eBayISAPI.dll?ViewItem&Item=380041599591
description is english).
Only the much more expensive fmd 700 has a built-in converter.
Apr 30, 2008 | Olympus Eye-Trek FMD-200 (Black, Silver)...
KWorld PC to TV Converter
I had the same problem. It turned out the issue was that I had the VGA Y-cable connectors between the PC and the KWorld box reversed. They look like they should be interchangeable, but they are not. A closer look at the cable connectors shows that one is marked "PC", one is marked "Monitor", and the 3rd is marked "SCAN CNVTR". Once I got them plugged into the right places, I got the screen image on the TV.
Jan 01, 2008 | KWorld PCTV CONVERTER KW-PCTV-1600 RT...
StarTech.com VGA to NTSC/PAL PC to TV Video Converter (VGA2NTSC) Video Capture Logo
106 people viewed this question
Top StarTech.com Televison & Video Experts
Are you a StarTech.com Televison and Video Expert? Answer questions, earn points and help others
