Brand new HP Laserjet printer CP 2025 appears to be running a little hot, causing excessive paper curl
  • 27 Answers
Hi the chairman..
when do bought that printer..from my experiance the paper curl couse of fuser got problem...
need to bring to hp centre...
Posted on Nov 07, 2008
My printer is showing error 59.0F Hp laserjet cp 2025
see some articles below for similar errors.
It does not appear to be user fixable error unless it is that debris to be cleaned. Printer HP Laser Jet CP4525 59 F0 Printer Error
Apr 28, 2016 | Office Equipment & Supplies
Paper printing hot and curling on kyocera taskalfa 300i.....how do i remedy that problem.
Paper curling is usually caused by one of two things:
1. old damp or moist paper that has too much humidity in it. Easy test for this is to open a brand new ream of paper and try fresh paper.
2. The fuser temperature is too hot for the paper you are printing on. If you can set paper type on your printer, make sure it matches the actual paper, for instance, plain paper, heavy paper.
Feb 19, 2015 | Kyocera Office Equipment & Supplies
HP LaserJet 4000 Duplexer
I realize when I say this that you will be a little skeptical but I will say it anyway . the Paper may be damp - do you notice any curling from your print if only printed on one side? this is the easiest way to test for damp paper- while the paper is damp the Electrical resistance is much higher than when its dry and this is what typically gives a Light copy however once the paper has been though the Very Hot fuser rollers to \'fix\' the first side, the paper has been force ably dried and so the second side is much Stronger in toner. try a new ream of paper and see if that helps
Jan 22, 2014 | HP LaserJet 4000 Printer
What's your problem?HP Color Laserjet Cp2025n Printer -
hi my hp 2025 laser printer is reading low memory error.....
the printer is printing simple text .....but full colour graphics ...am getting memory error.....how can you help.......
Feb 17, 2012 | HP Laserjet Cp2025n Printer
Clening/mismatch printing for hp clj cp-2025 printer
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Jun 14, 2011 | HP Laserjet Cp2025n Printer
HP 3000n Laser Color Printer - Paper is curling up when it comes out of the printer. How do I stop that?
Make sure you've let the printer know what type paper you are using. In the print dialog on your PC, you must choose in the preferences area whether Plain, Photo, Glossy, Cardstock, Envelopes, etc. Such things control the pressure of the rollers in the fuser, as well as it temperature. Too hot will result in curled paper.
Also, make sure you are storing the paper properly prior to printing. It can't be too damp either, or it will curl.
Finally, if all else fails, your fuser may be overheating and need to be replaced. Hope not. If so, look for a rebuillt one online. Much cheaper than new. Good lick!
May 03, 2010 | HP LaserJet 3000n Printer
Ghosting when using HP CP2025N
Bad drum unit poor fusing or paper type try to print paper type cardstock as type, this increases fuser temp and slows printer for better quality.
-Carl, please let me know if this helps.
Jun 25, 2009 | HP Laserjet Cp2025n Printer
Curling
The paper is definitely your problem. I suggest you try all types of paper settings that are available on your machine. I think there is a recycled paper setting.
Feb 22, 2008 | HP LaserJet 1320 Printer
Paperjams
Sounds like the pick up rollers are worn or dirty.
You can try to clean them with alcohol.
When you pull the tray out the rollers
should be towards the front of the printer.
Nov 21, 2007 | HP Color Laserjet 3550 Printer
202 people viewed this question
jasbo
jasbo
