Question about Sony KP-46WT510 46" Rear Projection HDTV
Sony tv tv sound problem
    Genius:
  • 1,239 Answers
Change speaker
Posted on Nov 07, 2008
How t0 make sound work on older sony surround sound sanyo tv icannt get sound through surround that a older sony
Make and model of each device is needed to assist you. The Sanyo TV will need audio out that is support by an audio in on the Sony.
You then need to know how to enable sound to move from the TV to the Sony. This could be a physical switch or an option in the TV's menu.
Finally you nee to change input on the Sony to the TV. This is likely an input button that matches the name on the input connector you used.
Jul 11, 2017 | Sony Audio Players & Recorders
Sound comes and goes constantly on a sony tv model KP60XBR800
About 27,600,000 results (1.16 seconds) Search Results
    Sony TV sound issues - Forums - CNET
    www.cnet.com > Forums > Sony
    CNETJun 11, 2015 - I have a Sony Bravia KDL52V5100 LCD TV & after only having since May 2009, I am now having sound ... I'm going to purchase a new HDMI cable to see if that might solve the sound cutting out problem. ... Has anybody come across problems like these 2? .... Sony is and always has been one of the best TV's on the market. Netflix app on Samsung Smart TV audio dropping out
    Jun 11, 2015
    sony bravia automatically turning off and on
    Jul 7, 2012
    Clicking noise after powering off sony kdl-40v3000 lcd hdtv ...
    Oct 25, 2007
    More results from www.cnet.com
    A loud humming or buzzing noise is coming from ... - SONY
Jan 05, 2016 | Sony Televison & Video
I have a Sony sound bar Model CT380. It has HDMI ARC and optical digital connections. The TV does not have these connections. What can I do to work around this?
How to connect a TV Sound Bar system to a television. - SONY
https://us.en.kb.sony.com/.../how-to-connect-a-tv-sound-bar-system-to-a...
Jump to If your TV has an HDMI terminal (without ARC) and an ... - Then connect theTV's Optical digital ... If your TV does not have HDMI input ...
2.1 ch Soundbar with Bluetooth ' HT-CT380 ' Sony US
www.sony.com/electronics/sound-bars/ht-ct380
Sony Corporation
Rating: 4.1 - ‎9 reviews - ‎$249.99
Discover the 2.1 ch Soundbar with Bluetooth from Sony & explore all the Sound Barsfeatures. ... filter higher frequencies to distribute audio smoothly around the room. ...against the sound bar to make an instant Bluetooth connection. No NFC? ... the HT-CT380 to allow data to pass through the sound bar straight to your TV ...
Dec 28, 2015 | Sony Audio Players & Recorders
Sony Trinitron, no sound for TV but sound with DVD.
it could be the signal strength for your cable isn't strong enough. alot of people are encoutering similar problems ever since the digital switch over
Mar 27, 2010 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony KP53v85 T.V (52
the problemthat i am having with my sony projection tv kp53v85 is that the sound keeps cutten off and on
Dec 29, 2009 | Sony KP-53V85 53" Rear Projection...
No sound from TV thru sony bravia hdx576wf; DVD & CD audio ok.
Could be a sync calibration issue. Try to divert the TV sound to another input source on the Hometheatre system if possible, if it is a go then maybe the TV audio needs to be recalibrated. Make sure TV audio setup menu option has not changed also.
Feb 08, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
Sony Model DAV ? SB 500W Home Theatre System
Please check at rear of TV for Digital Optical IN port as home theater should have optical out port at rear. If you got any optical in port in TV, just connect optical wire between TV and home theater.
2nd option is check Line Out pins at rear of home theater system, if found, hook red-white RCA cable there and put it to same input in TV where you hooked Video (composite or component) cable.
Let me know the results to help you more.
Jan 07, 2009 | Sony DAV-SB500W System
Panasonic 50? Plazma TV TH 50PZ 800A + Sony Model DAV ? SB 500W
that is possible
the home theater has so many in puts on your dvd and out puts.
there is a way
1 you can buy a vedio/audio converted to rf signals, this will mean both signals entering tv using rf.
2 get your vedio out from dvd and audio out, feed that to a converter, vedio in and audio in okey
How do you get DVD player SOUND to play through the TV speakers
plug the stereo headphone jack to your dvd headphone output then connect it to your tv audio/video in and press the tv/video switch in your tv remote control.
Sony surround sound hookup
In short, the answer is: Hook up all three to each other. I have a Samsung DLP HDTV, and I was trying to hook up a Sony DAV-HDX500 home-theater system and a Comcast HD set-top box, but I found that the Sony user guide is helpful only for setting up the speakers. Most of what it had to say about HDMI and getting the TV sound or cable sound to go through the speaker system was wrong (or, at least, it didn't work for me). So, here's what I did. I connected Component video cables (Y/Pb/Pr out) from the Cable box to the TV (Y/Pb/Pr in), audio cables from the Cable box (audio out) to the Sony system ("SAT/Cable" audio in), and an HDMI cable from the Sony system (HDMI out) to the TV (HDMI in). This allows me to 1) watch DVDs with surround sound through the TV's HDMI source (when the "DVD" format is selected on the Sony system), 2) watch cable with surround sound through the TV's Component source (when the "SAT/Cable" format is selected on the Sony system), and 3) watch cable WITHOUT the surround sound, as I did before I ever had the Sony system. One item of note: When watching a non-HD channel with the surrond sound on, the audio is slightly out of synch with the video; thankfully, there's no such problem on HD channels. Anyway, I hope this helps. It drove me crazy for two days straight!
Dec 31, 2007 | Sony DAV-HDX500 System
Sony KP-46WT510 46" Rear Projection HDTV Logo
22 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
