Question about Zebra LP 2844-Z Thermal Label Printer
Zebra LP2844 thermal printer
The print on my labels has begun to fade how can i improve this
  • 123 Answers
Open the unit and on the front top you will see a thermal print head, (looks like a shiney bar) using an alcohol based solution clean the head, you prints should be much clearer now.
xbm
Posted on Nov 07, 2008
How do you load the ink spool on a new Zebra LP2844? we cannot find where it goes? Elaine
Hello Elaine,
The LP2844 does not use any Ink or Toner. The labels are heat sensitive thermal paper and when the print heat gets hot they show an image.
Aug 31, 2011 | Zebra LP 2844 Thermal Printer
What is the difference between the Zebra LP 2844 Thermal Printer and the Zebra LP2844Z?
lp2844 use programming languages EPL2, Line Mode, lp2844 use ZPL II, ZPL (Zebra languages), both are Direct Thermal (don't use ribbon), not Thermal-Tranfer (use ribbon).
Nov 17, 2010 | Zebra LP 2844 Thermal Label Printer
MY ZEBRA LP 2844-Z IS PRINTING BLANK, WHAT COULD BE THE PROBLEM?
Since the LP2844 is a direct thermal printer, the first thing to check is to make sure you have direct thermal labels - regular label stock won't work. Just quickly scrape your thumbnail across the label, the friction will cause a black line if the label is direct thermal.
Aug 11, 2010 | Zebra LP 2844-Z Thermal Label Printer
When printing a label on the lp2844 the label look faded
This is very little info, but I will try.
First, have you cleaned the printhead, if not procede as follows: -
Open the printer and with a soft cloth dampened with Isopropyl Alcohol or any clening alcohol gently rub the printhead to remove any built up dirt. If you look closely at the printhead elements, you may be able to see and feel with the pad of your finger any build up, continue to clean until it has gone.DO NOT UNDER ANY CIRCUMSTANCES USE A HARD OR SHARP OBJECT TO CLEAN THE PRINHEAD AS THIS WILL DESTROY IT.
Try the print again to see if it has improved.
If not then adjsut the print head heat/contrast settings from either the printer driver or the software you are using to make the labels.
Feb 11, 2010 | Zebra LP 2844 Thermal Printer
I have a Zebra LP2844 Thermal Printer from UPS. I
Welcome to the club. Been fighting this for almost a year. There is now a driver for vista available from Zebra to fix. I can now print 1 label from quick books. to print a second i have to restart computer and quick books. still searching for the answer.
Dec 08, 2009 | Zebra LP 2844 Thermal Printer
We are in need of thermal printers and Zebra LP
The LP2844 can only print on Direct Thermal labels.
DT labels have the ink within the label and the labels react to heat. If these labels are to be exposed to direct sunlight they will eventually turn black.
Hint:
If you scrape the label with fingernail you can usually see the black ink on label
The physical size of the labels is this max width 1 inch (MInimum) to 4 inches (Max). Maximum length of label depends on the amount of memory in printer but maximum size for standard LP2844 is 11 inches. With full memory can be 22 inches long.
The labels must be on a 1 inch core.
These printer can handle all label types.
1: die cut Labels - Use gap sensing.*
2: Labels with Black mark on back - Use Black mark*
3: Continuous roll - select continuous *
* Select in printer driver media setting
Use the latest ZDesigner Driver V1.5.10
Download from Zebra Website.
Printer Preferences - Advanced Setup - Media Type.
Dec 02, 2009 | Zebra Eltron TLP 2844 Thermal Label...
Zebra lp2844 printing incorrectly with paypal multi order
Same here... Can't be the printer - has to be something with either the paypal software or the driver since my 'SAMPLE' prints solid as well. Did you ever find a solution?
Oct 15, 2009 | Zebra LP 2844 Thermal Printer
Zebra LP2844 print is wrapping horizontally
Update the printer firmware, download latest printer driver from zebra website.
Oct 01, 2009 | Zebra LP 2844 Thermal Printer
Zebra LP2844-Z - no longer prints a barcode on a specimen label
Added ''3 of 9' font to C:/Windows/Fonts.
Opened Word document, selected 3 of 9 as Font and typed a word.
Went back to printer and it printer the accession number and barcode.
Mar 27, 2009 | Zebra LP 2844-Z Thermal Label Printer
Zebra LP 2844 printer will not print anything but the test page
possibly not a real LP2844 but an LP2543, a printer mass produced for and used by UPS. refurbishers change the label and sell as LP2844 because they are almost identical.
if it has an AC-AC adapter, it is an LP2543. LP2844 uses a AC-DC adapter, and all LP2844's have USB ports.
Mar 24, 2009 | Zebra LP 2844 Thermal Printer
Open Questions:
See all Zebra LP 2844-Z Thermal Label Printer Questions
Zebra LP 2844-Z Thermal Label Printer Logo
916 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
