Question about Samsung Ultra SlimFit 20" Digital TV
Sony tv I have an older Sony Trinitron TV that doesn't work unless you first rap your knuckles on it's side a couple of times. It seems as though it's taking longer and longer for it to work properly. As Marvin Gaye would often ask, what's going on? Is this something that can be fixed, or is the tube finally going to that tv repair shop in the sky?
  • cyborgjoe May 18, 2009
    The pins of the CRT socket tend to loosen up over the years. In my case I just took the back off and wiggled the socket. This cured the problem.
I need remod numer sony tv
Posted on Jan 09, 2009
  • 4,234 Answers
Given that you can rap the side and get it to work, suggests a bad solder connection inside the set. If you are comfortable working inside the set (high voltages that are potentially dangerous even with the set unplugged) and can solder, you should be able to fix this yourself. Look for solder connections that appear grainy or have rings and resolder them. That should resolve the problem. If not, please post the exact model number and we'll continue on to the next step.
Dan
Posted on Nov 07, 2008
My tv won't turn on it blinks and doesn't turn on
Check this site to get more details about blinking codes to Sony TVs. Pull up older posts there. Count the number of blinks occur at one time switch ON, before you continue. These pre-set number of blinks are fault indications.
Mar 31, 2013 | Televison & Video
Sony trinitron kv 32fx68e has 14 blinks. So to switch it on you have to try 20 to 30 times. What can be the problem. Thanks
sony trinitron kv 32fx68e has 14 blinks light. that"s mention tv have bad picture tube. replace it . good luck!
Sep 22, 2012 | Sony FD Trinitron KV-32HV600 32" TV
Sony trinitron 36" has 7 red blinks wont turn on
I HAVE A SONY TRINITRON KV-36HS510. IM HAVING A PROBLEM,ITS NOT SHOWING A PIC, AND BLINKING 7 TIMES THEN PAUSE FOR A COUPLE OF SECONDS THEN IT WILL BLINK 7 MORE TIMES,I CAN HEAR AUDIO BUT CANNOT SEE PIC. COULD YOU PLEASE HELP ME OUT ,I'VE TRIED CUTTING THE TV OFF FOR ABOUT 6 HOURS AND CUTTING IT BACK ON,SAME RESULTS, THANKS
Jan 02, 2011 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Is there a power fuse in this tv. sony 32" 1998 trinitron. Had great color, picture & sound. Will not turn on/no power.
There are fuses in most TV's... and in some cases, it's nothing but the fuse. BUT, the fuses are there to protect the circuits... so unless you know that there is nothing wrong with the TV, you shouldn't simply replace the fuse and plug it back in. However, if the TV is an older TV and it's either fix it by replacing the fuse or get rid of the TV... then I'd certainly take out the screws and check the fuses in the TV. But many times the fuse blows to protect it when something else fails... so if you find a blown fuse, look around for other signs.
WORKING ON ELECTRONICS should be done by professionals!! Proceed at your own risk!
Oct 08, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a 32" Sony Trinitron that won't start ( it starts occasionally by fluke) red light blinks 9 times
Plug it out of the outlet wait a couple of minutes plug it back on turn it on from the TV and see if this works
Sep 28, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony trinitron not working
The power supply has failed which are very expense and your better off Getting a new T.V.
May 23, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Screen went BLACK!
My Sony FD Trinitron TV did samething, started flashing, then eventually went completely black with volume. I got on internet searched found a solution, i tried it, it worked. unplug tv, remove all screws, remove back. towards bottom right theres a transmitter with a couple of knobs, we plugged tv in and moved knobs around and it worked. Also was extremally dusty, we used computer duster for a better connection. hope it helps you
Jan 26, 2008 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
Sony KV-32LS60U FD Trinitron 32
Your tv has Leak cap in POWER supply its either primary or secondary power. Need to replace it. Look for a Electronic Tech.
Jan 17, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Samsung Ultra SlimFit 20" Digital TV Logo
59 people viewed this question
Henry  Thomas
Henry Thomas
