Question about Regina RG3100 Vacuum
HELP!!!!! why is my vacuum blowing out at microfilter instead of sucking at hose??
  • 2,976 Answers
Re: HELP!!!!!
The hose is probably clogged. It is supposed to blow out at the filter. It filters the exhaust air so you don't get dust back into the air.
Posted on Feb 22, 2009
0 characters
3 Points
My very old 6 us gallon wet-dry shop vac now blows instead of sucks.
connect the hose on the other end where it say vacuum not blow.
Sep 19, 2016 | Shop Vac Vacuums
When i hook up hose attachment it blows air instead of suck?
Put the hose on the side to blow out and on the front to suck in.
Sep 07, 2014 | Kirby Vacuums
Seems to **** up the dirt/dust and simply blow it out instead of capturing it inside
Most of these have an suction hose and a blow port. One blows air, one sucks air. Make sure the suction hose is on the correct port. Also, a dirty air filter will cause the same effects. The filter must be good to prevent the dirt and dust being blow around.
Nov 08, 2010 | Craftsman 17026 Wet/Dry Vacuum
Blowing out instead of sucking in.
There should be a blow side and a vacuum side.You have the hose on the wrong side. If there are not two different holes, then there is a switch somewhere.
Sep 30, 2010 | Shop Vac 584-05-00 Canister Wet/Dry Vacuum
Bissell proheat blowing out air instead of sucking in air
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
Feb 16, 2009 | Bissell 1699 ProHeat Clear View Upright...
No suction.
Mine is doing the same thing, the hose picks up things fine but the rollers turn and instead of picking up it is blowing air out????
Nov 29, 2008 | Eureka WhirlWind 4381 Upright Vacuum
SteamVac Supreme Vacuum Problem:
Does this have the slot in front of the dirty water tank for the hose? If it does and the hose isn't installed, there is a block that you put in when the hose isn't being used. If not there, then it will blow air and won't suck up.
Nov 11, 2007 | Hoover F5832-910 SteamVac Supreme Vacuum
Vacuum Cleaner sucking dirt out of the cannister instead of into it.
You didn't give you model number, but check by the brush roll to see if the inlet there is clogged, hose still has a clog, filters are bad and need replacing. Does the brush roll turn, belts stretch after short usuage and will not drive the brush roll under load, may need to replace the belt.
Oct 29, 2007 | Eureka Whirlwind 4496 Bagless Upright...
Rainbow E Series Vacuum
the motor is actually spinning backwards? try to confirm this.
Jun 01, 2007 | Rainbow E series Canister Wet/Dry Vacuum
Regina RG3100 Vacuum Logo
177 people viewed this question
Top Regina Vacuums Experts
Roger Potts
Are you a Regina Vacuum Expert? Answer questions, earn points and help others
