Question about LG Televison & Video
I am trying to connect my new Australian bought lg rc389h to a uk sony tv. However there is no video input jack on the back of the tv. Sound is fine. I've tried a scart cable but that hasn't worked.
  • ozvoddens Nov 07, 2008
    Thanks, panel on the front !
    President:
  • 1,952 Answers
DVD players, the device to play Digital Versatile Discs or DVDs are produced under the DVD Video standard and requires to be connected to an output device, which could be a television set or amplifiers and speakers. Portable ones, however, come with an LCD screen attached. The functions of a DVD player are as follows:
  • Read a DVD in ISO - UDF format.
  • Data decryption with CSS (Cascading Style Sheets) and Macrovision (for electronic copy prevention).
  • Decoding MPEG-2 video streams at 10 Mbit/s (peak) or 8 Mbit/s (continuous) rate.
  • Decoding audio from MPEG, PCM or AC-3 format.
  • Playing audio and Video CDs.
  • Enhancing sound and video qualities with Dolby Digital and Digital Theatre Systems.
Posted on Nov 07, 2008
  • 113 Answers
Check if u can locate at the front panel near the ir sensor or near the power button  . it will be closed with the push and open cover. if u still cant find u can use with a/v converter pin
    Scholar:
  • 44 Answers
Download the complete user guide manual here for your problem..
User manual LG RC389H
http://safemanuals.com/user-guide-instructions-owner-manual/LG/RC389H-_E
  • 928 Answers
WHat is the model number of your TV. Also have you checked the front? sometimes there are hidden panels where you can find the input jack. Please provide the exact model number of your TV so that we can give more accurate information
  • 83 Answers
HDMI port for connecting to a HD Ready television. It also has a DV input port, which enables you to connect a DV-compatible camcorder for transferring your home videos to DVD.
  • rush2robby
    rush2robby Nov 07, 2008
    U should use RF Cable (Came with CD-Player)..
    1- Connect RF- Cable TO CD Player RF Jack.
    2- Than Connect Other end of RF Cable to TV Cable Jack (Jack connect with dic Cable)
    3-Play any vedio on cd player and Start Scan ou tv chennals
    Thats Done
No audio after recording from sat. Reciever
Double-check your input cables from the receiver to the LG 389. Do you have the sat. receiver AV out connected to the front AV In on the LG DRT389? Make sure that you haven't mixed up the L and R audio connections on either side. (I've done something similar with RCA cables myself.) Next, try a different set of cables.
If that doesn't work, there may be a problem with the audio jacks on either your receiver or the 389. To check, plug the AV cables from the Sat. Receiver directly into the TV. If you have sound and video, then the input jacks on the recorder may be damaged.
Try using another input. (It looks like some models have the SCART input; you may need to set the input source in the menu under AV2 Decoder.)
The fact that you have audio output on USB and DVD's means that cables/connections between the LG289 and the TV are fine.
I hope this helps. Please add a comment with the details of which AV port you are using on the LG389 for additional assistance.
Aug 31, 2012 | LG DR389 MULTISYSTEM DVD RECORDER FOR...
How do I get the sound through my LG M197WD Flat screen monitor when using it with my PC? Sound is fine when using it as a TV!
What video cable are you using between the TV and the computer? If you are using a VGA, DVI or DVI-HDMI cable, you need to connect a 3.5 mm audio patch cord between the computer's audio out and the PC audio in on the TV. The audio out on the computer will be the speaker (green) port on the back of a desktop or the headphone jack. (Make sure that this jack works by connecting a different set of computer headphones or speakers to the computer.) The audio in jack on the TV is above the RGB input; it's just to the left of the digital audio out.
Check that the correct audio output is selected. From the Hardware and Sound Control Panel, look at Manage Audio Devices and the Playback option. If your computer has an HDMI port, that may have become the default audio output device. Change this setting. (Not all TVs can accept HDMI signals from a computer but a number of video cards are encoding this as the default during install.) Try a new audio patch cable between the TV and the computer.
If another set of speakers doesn't work, you need to check the drivers for your computer. In the Device Manager (click Start > Control Panel > Hardware and Sound > Device Manager), scroll down to the section for Sound controllers and expand it. Then check for updates for the audio driver. If necessary, uninstall the driver (by right clicking on the audio driver). Then shut down the computer and restart it.
The manual for the M197WD is available from LG here: http://www.lg.com/uk/it-products/monitors/LG-tv-monitor-M197WD.jsp . Click on the support tab and the link is on the right side of the page.
My directions are for Windows 7; it's slightly different for other versions of Windows.
I hope this helps. Please post a comment with the video connection that you are using if you need additional assistance.
Apr 22, 2012 | LG Televison & Video
What do i need to play back recorded video onto my t.v from my sony handycam dcr-trv260...i have s cord, usb cord, yellow rca jack??? so what else do i need!!!...nothing i have tried has worked???please...
You can connect this camera to a suitable TV with either the S-Video lead or the RCA lead, but only if the TV is equipped with the appropriate inputs. The S-Video lead looks like a tiny DIN plug, and the RCA jacks are three separate plugs coloured red, white and yellow (yellow is composite video, red and white are left and right stereo sound). If you use S-Video you will also need to make a separate connection for sound (using the red and white RCA connectors). Sometimes the TV sound input is a mini stereo jack, and you will need a Y connector to adapt the two RCA connectors to the mini jack, or maybe the camera's sound output is also by mini jack, in which case you may need the reverse Y connector. Most TVs have some way of accepting a video signal, but you may already be using it for a DVD player or the like.
If your TV lacks these connections, you may be able to use an adapter. In the UK, most recent TVs have a SCART (Peritel) socket, which takes a big plug with 21 connections on it. You can get an adapter to fit that socket that will allow you to plug in the RCA connectors and maybe the S-video too. I don't know what country you are in, or what adapters are available in your country if it isn't the UK.
Once you have made the connections, you must select the appropriate input on your TV. The other possible hiccup is setting the camera to the right video standard, NTSC or PAL., to match that used by your TV.
The USB cord will not connect your camera to the TV.
Jan 11, 2011 | Sony Handycam DCR-TRV260 Digital Camcorder
Hi, I have just shipped a SHARP LC-37AD1E tv over from the UK (where it worked fine!) It is one of the early models that has a separate media box. It has tuned in fine to the Australian channels BUT there...
No. The audio and video signal must be decoded first before you can connect it to the home theater system. Your Australian channels might be different from the UK's. Try a decoder box made for Australian stations.
Dec 04, 2010 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
I can't get tv to send sound to sound system
Having browsed the user manual I wonder if you plugged in the Sony BDV T57 Home Theatre System while the Polaroid FLM-2632 tv was powered down via the optical cable .
Then powered up the Sony BDV T57 Home Theatre System first and then powered up the Polaroid FLM-2632 tv
Maybe the Polaroid FLM-2632 TV has to detect that the Sony BDV T57 Home Theatre System is connected and powered up when the Polaroid FLM-2632 powers up. To activate its digital audio out ????
The note part about only being available only under HDTV (cable/air) mode. Might be the cause of your hassle also ?
DIRECTLY FROM THE USER MANUAL
source from
http://tv.manualsonline.com/manuals/mfg/polaroid/polaroid_flm_flm2632.html
? Connecting to Audio Receiver:
Use an audio cable to connect the audio receiver's audio LINE IN jacks to LCD TV's
AUDIO OUT jacks. ? Connecting to Digital 5.1 Sound System:
METHOD A:
Use an optical cable to connect the audio amplifier's OPTICAL IN jacks to LCD TV's
OPTICAL OUT jacks.
METHOD B:
Use a coaxial cable to connect the audio amplifier's COAXIAL IN jacks to LCD TV's
COAXIAL OUT jacks.
Note: Above mentioned function is only available under HDTV (cable/air) mode.
? Connect all AC power sources, before turning on the power switch of the LCD TV or
other connected equipment.
? Press the button on the remote to turn on the LCD TV."
May 25, 2017 | Polaroid FLM-2632 Television
I have picture but no sound LG flatron TV and Pioneer DVD player.
connect audio output (RCA Jack white n red color) from the video, to the audio input of your TV. Make sure you use same AV channel for the video and audio.
i.e AV1 or AV2 or AV3
Apr 10, 2010 | LG Flatron MW-30LZ10 30" LCD Monitor
Trying to hook my Wii up using the AV audio Jacks
Connect the Wii to your television. Then connect the variable audio output from the TV to the audio in on the monitor section of the receiver. Then use the TV/SAT input selection on the receiver and dolby prologic 2 as your sound mode.
Dec 23, 2009 | Sony STR-DE575 Receiver
I have video but no sound from the TV
hi there send it back to nintendo the sooner the better here is there phone number for them to collect it and repair
> Nintendo UK
Quadrant
55-57 High Street
Windsor
SL4 1LP
Tel: +44 (0)870 6060247 (Calls charged at National Rate)
Fax: +44 (0)2392 383 444
Registered at
Companies House, Cardiff, (31st January 2001)
Company No. FC022968
Branch No. BR005889
Managing Director
Satoru Shibata
if you need any othere phone number or address ill be happy to post it up for you cheers
Thanks From Me and FixYa
Feb 02, 2009 | Nintendo Wii Console
Can't get Video onto Television..Can get Audio.
Thanks for getting back five months later. I ended up buying a new Monster cable that worked just fine for like $40.
Dec 31, 2007 | Sony Handycam DCR-TRV460 Digital Camcorder
Televison & Video Logo
48 people viewed this question
Computer Repairing
Computer Repairing
