Question about Asrock 775i65G Motherboard
No beep please help me about it it has power but no beep i tried to clr cmos but still no beep
  • davaughe Feb 21, 2009
    i have the same problem, i did however push up the frequebcy to 300 so i dont know if that is a problem, i tried clearing cmos but the system still wont post.
  • 97 Answers
Ok im currently working on a motherboard right now and change your power supply make sure its 400w or higher
Posted on Nov 09, 2008
Have a Dell Optiplex 740 desktop. Power button is lit solid orange. No diagnostic lights on. Fans still blowing. Replaced power supply unit still nothing. HELP!!!!!
before replacing main board,try replacing individual hardwares like ram,processor and if still not working,try resetting the bios by alternating the jumper on the labelled CLR CMOS
good luck
Mar 28, 2013 | Dell OptiPlex 740 PC Desktop
I want to reset BOIS password for Gigabyte GA EP43 motherboard which has no jumper, i try to remove battery but the problem unsolved~
There is a CLR CMOS jumper on that MB next to the SYS FAN 2 connector by the IDE header
open = no clr
jumped= Clear CMOS
From the manual page 32
Use this jumper to clear the CMOS values (e.g. date information and BIOS configurations) and
reset the CMOS values to factory defaults. To clear the CMOS values, place a jumper cap on the
two pins to temporarily short the two pins or use a metal object like a screwdriver to touch the two
pins for a few seconds.
• Always turn off your computer and unplug the power cord from the power outlet before
clearing the CMOS values.
• After clearing the CMOS values and before turning on your computer, be sure to remove
the jumper cap from the jumper. Failure to do so may cause damage to the motherboard.
• After system restart, go to BIOS Setup to load factory defaults (select Load Optimized
Defaults) or manually configure the BIOS settings (refer to Chapter 2, "BIOS Setup," for
BIOS configurations).
Jul 20, 2011 | Gigabyte GA-EP43-UD3L Motherboard
HI I Have similar problem with my Hp m7520cn, I tiried to check all the connections but still nothing happens no beeps, no display but when i remove the Rams it beeps... So Please if theres anyone can help...
try resetting your PC's CMOS, the clear CMOS jumper is usually found near the CMOS battery. note that there shoul be no power or the power cables are unplugged.
Sep 10, 2009 | Computers & Internet
Intel DG31PR Booting Problem.
Try resetting the bios by removing the power cord from the back of the machine and removing the battery for an hour periodically hitting the on/off button to dispel and residual power, then try again.
post back please.
Good luck and thanks for using FixYa!!
Apr 23, 2009 | Intel DG31PR Motherboard
My Toshiba laptop just beeps when powered on
here is the link to beep codes:
Nov 14, 2008 | Toshiba Computers & Internet
Ga gigabyte mainboard trouble
Just because it doesnt beep doesnt mean the vid is not gone
place board on a non metal surface hooked to
cpu with heatsink and fan attached
plug power supply in (will not shock you just dont lick it ok)
if board does not come on take a small flat head screw driver look at where the power wire would slide on cross those two pins should come on. again will not shock you.
still no video try pci (most basic video mobos support) card
still no video could be cpu I have had several of these be bad caouse no video also
try anouther cpu same setup
still no vid mobo shot sorry
Oct 24, 2008 | Gigabyte GA-7N400 Pro2 Motherboard
No display & beeps when power on
hi there,
looks to me you've got a faulty motherboard....but have you tried your memory,processor, and video card on another motherboard??? just to be sure....please try....
Apr 22, 2008 | Intel D845GVSR Motherboard
My motherboard BIOS is not starting
look for the CLRCMOS or CLR or JBAT1 terminals. These are the cmos settings and may need to be cleared, so refer to your motherboard manual for which one you have. Although what has probably happened is that when the PSU blew it may well have shorted the cmos chip which cannot be repaired, or damaged the graphics.
Apr 12, 2007 | Intel SuperMicro SUPER Motherboard - 810...
beeps on motherboard can mean 3 things: 1. memory out (or corupted) 2. vga card out (or corupted) 3. mother board is corupted try to take out the memory and the vga card and place them back on you can go and read you motherboard manual and look exactly what 3 beeps means..
Mar 17, 2007 | EliteGroup P4VMM2 Motherboard
Dell E510 Memory
One thing worth trying is taking out the cmos battery (only do this if you are confident you know what you are doing on a motherboard). leave the battery out for at least a couple of minutes and then reinstall the battery (ideally with a new one). restart and you may find you have cured the problem and that your old memory was fine. If this doesn't appear to help (definitely replace the battery even if you think it is fairly new)and jump the CLR CMOS pins. (ask again if you need help on this). second to try is see if you can update the bios drivers from the dell site onto a disk on another machine - use as a boot disk and see what you get. after that i would suspect the power pack, there is no real way to test this without connecting it to another motherboard and seeing if it is fine. alternative would be to just replace it with an equivalent unit, they are not too costly. After this i would suspect major motherboard or bios damage, which may be fixable but is usually cheaper to replace the whole board if you have inserted the wrong type(frequency/size/combination) of memory sets into the board it can often cause this sort of trouble, and often a CMOS clr and reset can solve the problem Please let me know if you need talking through the process - (it is not too complicated, but you can cause damage if you do not know what you are doing) Hope this helps :)
Mar 08, 2007 | Dell Dimension E510 PC Desktop
Asrock 775i65G Motherboard Logo
93 people viewed this question
Top Asrock Computers & Internet Experts
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
