Question about Kenmore 63942 Dryer
Dyer not drying - Kenmore 63942 Dryer
  • Anonymous Jan 08, 2009
    my dyer will not get hot
    Genius:
  • 1,239 Answers
The door of the dryer is sealed with one or more gaskets to keep the hot air in the dryer from escaping and prevent the cool air in the laundry area from being sucked into the dryer. A deteriorated or damaged gasket greatly lowers the efficiency of the dryer. To check the gasket, hold a sheet of tissue paper near the rim of the door while the machine is running. If the door leaks, the paper will flutter. If the gasket or seal leaks, looks worn or warped, has chunks of material missing, or feels hard and nonresilient, it should be replaced with a new gasket of the same type.
Posted on Nov 07, 2008
Kenmore electric dryer 90 series part# 3405768 kit # 27918 problems. The dyer heats up, the bulb at the door lights, but the dyer doesn't hum neither does it rotate to dry clothes! I'm unable to locate the...
This is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. Check these fuses for continuity and replace the one that does not have continuityseth765.jpgseth765_0.jpg
Feb 24, 2011 | Dryers
Spins , does not dry
Make sure that your vent from your dyer is not being block by lent.
Nov 28, 2009 | Whirlpool Dryers
Dryer takes hours to dry clothes.
Sounds like a heating element has gone bad. You have to tear apart more of the dryer to get to it.
Oct 17, 2009 | Whirlpool GEW9250 Electric Dryer
My dyer heats and tumbles, but doesn't dry
I'd check first for clogged vent hose or clogged lint filter or clogged vent flap on wall (outside).
If that's not a problem, it may be a faulty thermostat. Heating element is probably okay if it heats some of the time.
More info, let me know.
Charlie
Oct 01, 2009 | Kenmore Dryers
Dyer LSG7804ABE Gas Stackable very little heat
self help is right .first i would try a load with out the ducting.if you have good air flow and still didn't dry[because now youv'e elimanated the house venting as a possiable.replace your coils
Jan 02, 2009 | Maytag LSE7806A Top Load Stacked...
My Whirlpool Duet Dryer is not heating up. Unit is only Two year
If it is a gas dryer. Sounds like thermal fuse. It costs about $12.95. Most appliance part stores carry it all the time. Very easy to replace. Also can be ignition switch (also cheap). If you know someone who is mechancally inclined, after removing fuse,they can run an electrical jumper cord to the two open ends. If the dryer begins drying, then it is definitely the fuse.
Go to Whirpool site and get part number and diagram to fix. Maytag repair can help at a costly figure after they order part since Whirpool bought Maytag.
Dec 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Dyer cutting off
sounds like a bad motor, motor is overheating and shutting down
Nov 07, 2008 | Roper REX4634KQ Electric Dryer
Kenmore dyer
I have a kenmore gas dyer, it will start to dry then go out and just run. you can shunt it dwn resit the timer the time it needs start it and it will lite for a cycle then go out, short burn, then out. is it a senor???? JW
Jun 09, 2008 | Kenmore 62802 Electric Dryer
Kenmore 63942 Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
