Question about Dual Electronics N99i Cellular Phone
Warning bad connection charger
After starting charging the battery every few minutes 3 bips are heard an window opens saying"warning bad connection-charger".After reconnecting above after few minutes is repeated.Is this problem with the charger,charger cable or phone socket for charger?
  • 5 more comments
  • kyklopas Nov 07, 2008
    The phone I have is N99i
    Can I charge the battery via USB of the computer?
  • Jaime Magnetico Nov 13, 2008
    My problem is worst for this type of phone. The charger is not anymore charging the phone. It seems that no contact in the usb port of the phone. I am posting the problem on how to solve such. thanks.
    Jim Magnetico
    Philippines
  • Anonymous Nov 24, 2008
    I also encountered the same problem with this N99i phone. "Warning! bad contact - baterry" always pops up on the screen after 3 minutes when charging. This phone sucks!
  • MaxX_CIA Dec 03, 2008
    I have the same problem with a ZT v998 Warning! - bad contact - Charger!
    Not charging the phone more than 2 lines from 3
  • boden Dec 04, 2008
    warning bad connection charger problem, and notify you when a new solution is offered.
  • jt_madhavan Feb 01, 2009
    LG KP220 is my handset, using original charger. the same charger works fine with other set. The battery also new one. help me.
  • 3 Answers
Charger is broken...get a new charger or charge it on pc via usb cable provided....hope it helps you guys....
Posted on Dec 21, 2008
Bad connection charge
Posted on Oct 09, 2010
My phone is not holding a charge. I charge it overnight and this morning it was only at 32% charged. The day before the charge ran out very fast. How can I fix this problem?
It sounds like you need to replace the battery in your phone. NiCad batteries will build a memory, so you should not use the phone for, say 3 hours and place it back on the charger. You should use the phone and let it run down until you get a warning on the phone of low battery. That is when you should put the phone on the charger. It is okay to leave the phone on the charger for extended hours and it will not do anything to the battery, but in your case it looks like you have a bad battery.
Aug 23, 2016 | Cell Phones
Won't charge when screen is open
Time for a new battery. The battery has electronics that talk to the motherboard and when the battery gets really bad it tells the motherboard not to start at all.
Mar 02, 2014 | Acer Aspire Computers & Internet
Warning bad contact charger yxtel model x88
i connect phone for charging, A few minutes it gives awarning of "BAD CONTACT OF...i changed anthor charger battery so tel me waht problam
Oct 22, 2011 | Cell Phones
I have a compaq presario cq61 and have been having problems with the charger for quite a while but money is an issue so cannot get a new one just yet, the laptop has 2 lights to aknowledge that the...
YOUR PACK IS NO GOOD
IT MUST RUN WITH NO BATTERY
PACK CONNECTED
SINCE IT DONT THEN THE CHARGE IS WEAK TOO.
YOU KNOW PACKS CAN BE
GOOD
BAD
OR WEAK, OR EVEN ON FIRE, (loL)
Mar 01, 2017 | HP Compaq Presario CQ61420us Notebook
I have a blackjack and it was working perfectly fine about fifteen minutes ago, i had it on the charger and it wouldnt charge, then it randomly started to charge then stopped and turned off by its self. I...
Try this:
1. Remove battery
2. Plug the charger or the USB Cable if you have it.
3. Place battery back in.
4. Let it charge (if it charges) all the way til you see green light.
5. Turn it on.
I hope that works.
Jan 05, 2011 | Samsung Blackjack SGH-I607 Smartphone
China mobile,warning,bad contact charger when connected to the charger.
i have foreme f8 phone when i m charging it then it will say after some time bad content charger solve it
May 27, 2010 | Cell Phones
My ds won't charge for more then a few minutes!!
the battery is bad and it won't charge all the way. Try another battery and it should charge all the way. If it does then you know the battery is bad. If the battery is bad then you know the main board is bad.
Aug 22, 2009 | Nintendo DS Lite Console
Charging only few minutes then have warning Bad charger contact
The charger seems to be Ok from your description. It seems that your connection in the phone is loose. Have it checked.
Jul 31, 2009 | Dual Electronics N99i Cellular Phone
GE Simon 3 low battery warning: Newer battery has 6.54V?
Read the battery voltage with the system on but with the ac power disconnected. I always suspect the battery from experience. Battery needs to be replaced every few years normally(but can vary).
Jun 23, 2009 | GE Security Simon 3 Wireless Home Security...
Schumacker battery charger problem?
You are charging. The meter corresponds to the level of charge in the battery. Try setting to 10 A for 4 hours, battery should be half-way up. To determine if battery id dead.. leave battery off charger once it is fully charged...test with a voltmeter after 10 min.....battery should still be above 12v...after1 hour it should still be above 12v...if not battery is spent.
Mar 11, 2009 | Schumacher & Fast Charge Starter Charger
Dual Electronics N99i Cellular Phone Logo
1,441 people viewed this question
Top Dual Cell Phones Experts
William Alequin
Computer Repairing
Computer Repairing
Shehu Pro
Shehu Pro
Are you a Dual Cell Phone Expert? Answer questions, earn points and help others
