Question about Cameras
I have a sony dsc-t77. it was working fine now all of a suddne after only having it for 2 weeks the zoom doesnt work. when i slide the bar left or right nothing happens . the zoom bar appears on screen but doesnt zoom.
5 Suggested Answers
pinkmajik
SOURCE: Sony DSC-P3 Zoom stopped working
i had that same problem. check your image size, the camera cant zoom if the image size is set to 3.1M or 2.8M(3:2)
how to change image size:
turn on camera and leave it in camera mode (picture taking mode)
press the delete/image button
change image size until camera zooms again
VGA gives the biggest zoom range
i hope this helps
it worked on my camera
Posted on Oct 16, 2008
SOURCE: i turn off the flash
That solution does not work on the T77.
I have the same problem and this is how I solved it.
Press the Menu button on the bottom left corner of the screen.
Go to the second page (2/3) select the "REC MODE" (it is the firrst choice)
Select your mode as normal and not burst and then exit the menu.
Now you should be able to activate the flash from the screen..
Hope it works for you as it did for me.
Posted on Jan 28, 2009
SOURCE: No Time/Date stamp on Sony DSC-T77
UGGHH I have the same problem with this camera.. I called Sony and found out that although there is a datestamp when you view the photo's on your camera they do not print off on the photo The very thick accented guy said that a lot of people did not like the function of datestamping SO THEY REMOVED IT I couldn't believe it but he told me that the only way to get the date on there is to add the date myself on EACH phott using the CD that came with my camera Soo now that my husband and I are back from Vegas I have 400 photos to datestamp?? wtf SOO not worth the $300 I paid for this camera.. what a rip!
Posted on May 23, 2009
SOURCE: blank white screen sony DSC t77
To Power Reset the Camera, please remove the Battery from the Camera, press and hold the Power button for 30 seconds and then reinsert the Battery.
Another option: I took the battery out and I pressed Menu and Shutter button for 30 seconds and it worked! The screen is back!
Posted on Jun 11, 2009
SOURCE: Sony DSC T77 How to Setup Black and white mode
Hi Allonsoma,
What the manual doesn't tell you is that you need to change the REC mode first to be able to fint the buttons in MENU.
Fist go into the REC mode (the one above menu when taking a photo). Change this to PGM and click OK. Now go into MENU, on the 3/4 page second button down should be a box with a + in the corner. This is the colour mode option. You can now change to vivid, sepia or black and white.
Hope this helps.
Posted on Oct 10, 2009
I have sony cybershot T77 ... i have couple of dried water spots on the lens (from inside). What needs to be done? All other functions are working fine.
If it's really inside the lens only Sony can clean that up. An ordinary cam repairman cant open up the lens. Only Sony has the tools for it.
Jun 26, 2011 | Sony Cybershot DSC-T77 Digital Camera
My Sony DSC-T77 fell in the water 2 days ago. What will i do? Is there a possibility that it would still work? Pls help. Thanks
DO NOT TRY TO TURN IT ON! Remove the card and battery....try to dry out those compartments. Bury the camera in a bowl of uncooked rice for one week. Insert the battery and, with fingers crossed, try to turn it on. Even if it works, you may still have a problem with a haze over the lens elements when the water dried. You didn't say if the water was fresh or salt. If it was saltwater, the salt will continue to corrode the internal circuits of the camera.
May 30, 2011 | Sony Cyber-shot DSC-S980 Digital Camera
Sony cybershot dsc-t77 fell in fresh water
Hello :
Please read this solution here . Please give the solution a try . It has worked with alot of mini devices just like your Camera .
good luck .
please don't forget to rate !
Apr 07, 2010 | Sony Cybershot DSC-T77 Digital Camera
Won't take pictures when zoom
Most common problem in al the digital camera's. Slide motor start malfunction and the massage appears"Turn off the power and on again". In this situation you have to replace slide motor or lens block assembly, And your camera work fine again.
Thanks for using fixya.
Jun 27, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Where can I download a user manual for the sony Cybershot dsc t77?
Try this web site and see if it's what you're looking for... http://www.retrevo.com/support/Sony-DSC-T77-Digital-Cameras-manual/id/22085bh435/t/2/
Jun 08, 2009 | Sony Cybershot DSC-T77 Digital Camera
I have sont t77 sony camera and would like to change setting into black and white
1. Switch the camera to PGM mode (3rd on the left side of the screen) 2.Go to the menu (on the bottom left) 3. Scroll to page 3 of 4. 4.Second option down is colour mode - just pick B&W from there
May 12, 2009 | Sony Cyber-shot DSC-T77 Digital Camera
Memory card for sony dsc-t77
i used a "Sony Memory Stick® PRO DuoMark 2" it also comes with the adapter so you can plug it in the computer. hope this helps!
Dec 29, 2008 | Sony Cyber-shot DSC-T77 Digital Camera
I turn off the flash on my sony dsc - t77 , how to turn it on? i could not find the function!
Dec 27, 2008 | Sony Cyber-shot DSC-T77 Digital Camera
Nov 22, 2008 | Sony Cyber-shot DSC-T77 Digital Camera
Cameras Logo
32 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
