To whom it may concern, I have been using a kodak-i260 scanner for over a year successfully, but today it has been having problems to scan all the fed paper; It will hang while scanning. I would be most grateful if you could help FIX it. Regards, Yuri Guilherme
Davroslives
  • 29 Answers
SOURCE: Scanning slides with the Epson Perfection 1250
To be honest, I have no idea of how you were able to scan larger transparencies in the past. The scanner and its software were never designed to do this and there is no workaround.
Posted on Sep 10, 2007
SOURCE: Scanner not working
I work at a brother authorized repair center, the bad thing is that there is no specified A6 error, in any manual and when you call brother and tell them that you are calling from an Authorized repair center and that you need help with an A6 they*gasp* tell you to call an authorized repair center. Sorry about the rant.
The A6 is a general error relating to the scandeck on most MFC machines(9700/8440/8640) etc...
try changing the main PCB, it can be a little costly, however it generally doesn't take long, that is the general cause of the error. However, sometimes that doesn't work, so to save yourself a little time and money, just go buy another printer.
Posted on Oct 31, 2007
  • 84 Answers
SOURCE: help !! ,Microtek scanmaaker 3840 problem
maybe you have to clean up your scanner.. and ur settings of scanner might have the wrong configuration....
Posted on Feb 27, 2008
sagarjd
  • 95 Answers
SOURCE: How do I scan a 35mm film negative with my HP PhotoSmart C6180?
I regret to inform that hp Photosmart C6180 does not support scanning negatives.
Regards,
Sagarjd
Posted on Nov 21, 2008
  • 684 Answers
SOURCE: scanner won't scan
Right Click on My Computer/Computer if Vista........ Click on Properties then click on Hardware click on Device Manager...... On that list u will see the Printer Name with an exclamation Mark........ Right Click on that click on update Drivers...... Insert the CD to the drive....... Select Browse My Computer for Driver software..... Click on Browse and then Double Click on Computer go to Lexmark X*****.......... Double click on Drivers and then click on scan and then click ok........ Now click next it will say the hardware is ready to use then u can just click on finish and scan..... Thanku
Posted on Jan 25, 2009
IKodak i260 Scanner heating up
the lamp is more than 3 year old , it`s require replace for heat problem
Feb 12, 2014 | Kodak i260 Duplex Color Scanner
Kodak i260 paper jam
cluch motor problem or senser probelem,
tray first front side scan only its pass the paper than
scan next back side if not pass problem from fron or back senser
Aug 03, 2013 | Kodak i260 Duplex Color Scanner
High pitch scream after i260 scans a few pages. Scanning stops
the main board in that scanner is going bad which is why its making the high pitch sound. Time to get another scanner or call Kodak and get a replacement scanner or go back to the store where you got it from and get a new one.
Jan 23, 2010 | Kodak Office Equipment & Supplies
Kodak I260 large black line.
It may be inside see this website for how to fix an Hp which is similar http://www.willshak.com/scanner/
Apr 20, 2009 | Kodak I260 Captiva IA-Express Path-Through...
Check kds.log -this is my massage error when i press scan option at canner kodak i 260
My scanner i260 do not scan properly, it present a distortion in the image, Could you help me?
Thanks a lot
Mar 03, 2009 | Kodak i260 Duplex Color Scanner
I260 insufficient memory error
If you start scanning Documents over 17 inch, then its best to swap out the 64mbyte for a 256mbyte card on the mother board cpu 100/110.
You can tell wants loaded by looking at the Info tab in the Kodak Scan Validation Tool.
Nov 03, 2008 | Kodak I260 Captiva IA-Express Path-Through...
Kodak I260 paper tray not lowering after tray emptied
The Kodak i260 has a fixed Paper Tray and does not automatically move up and down?????
Oct 05, 2008 | Kodak I260 Captiva IA-Express Path-Through...
Kodak i260 Scanner
This is practically impossible. This can happen only when the file is over written! Check your software settings. May be you have selected 'multipage' option. Try scanning one page and two pages (same sheet). If the file size is different, then it means two files are scanned.
Reload your Driver and check your scanning software. I am assuming you are usning winXP/Win 2000.
S. Mohan
Jul 30, 2008 | Kodak I260 Captiva IA-Express Path-Through...
Kodak i260 problem
A line appears if a dust particle on the scanner glass is scanned continuously. Clena the galss with Isopropyl alcohol, dont use any solvent. If the line persists even after this, there could be some sensor problem. If accidentally a paper with a staple pin is inserted, the pin can cause scratch and a line will appear.
S. Mohan
Aug 08, 2007 | Kodak I260 Captiva IA-Express Path-Through...
41 people viewed this question
jasbo
jasbo
