Question about HP Compaq Presario V2000 Notebook
How to re-install Bios
I am Bhargav, i want informaton about "how to re-install BIOS"
Bhargav S.N.
  • 94 Answers
Hello bhargav....
To make BIOS to default.... you have to do a jumper setting.... on motherboard
or based on the model number of the motherboard... download updated bios.. and copy it into the Floppy/CD... and try installing it... going to bios and choosing update bios option..
Posted on Nov 08, 2008
I have four sata ports inside my emachine desktop and my bios says not installed
If the SATA ports are showing not installed on the BIOS then it can be due to either older BIOS version or the Ports are not detected. I recommend to update the BIOS from the emachines website, please follow the link below:
Select the computer model and download the BIOS
It should take care of the issue.
Thanks and regards,
Dec 20, 2011 | E-Machines eMachines Desktop PC
A problem detected and windows has been shut down to prevent damage to your comp. I this is first time that u have seen this stop error screen restart pc. If this screen appears again follow these...
This happens when your operating has a problem with it's hardware, e.g or ram etc. Also some windows major files like DLL are gone missing by chance. Try to restart the Pc and press f8 until you get the options to start in safe mode, If safe mode dosn't works and gives the same informaton, try to make a backup of your filesby using the external hard drive, whereby you will need any other computer to make this backup, from your own hard drive. After doing this, you can format the hard drive and load operating system on it, if you know how to do this. You haven't mentioned the operating system you have in your pc, if you have vista or win 7. by pressing f8 key will aslo give you options,, run computer to last known configuration etc. Hope this works, or you can also go online help with service tech.
Sep 01, 2011 | Computers & Internet
I changed my hard drive and now it wants a built in hdd1 password and l dont have a clue
To create an HDD password you have to enter your BIOS
At startup press tab button to enter your BIOS ,ther you will BIOS setting
password enable.
enter your password and enable it.
Aug 23, 2011 | Toshiba Computers & Internet
Hii there... I have dell gx280 desktop pc & I want to install windows on it but i don't know where is option in bios setup to make SATA drive enable because I am getting blue screen usually...
Don't think I've seen an option to disable it in any BIOS. I'm assuming you're trying to install it and it's not finding the drive? When it's loading, it'll say press F6 to load third party drivers. That's what you're after, most likely. Suppose it could be causing BSOD as well. Drivers are good for that.
Jul 25, 2011 | Computers & Internet
I am having problem with my fresh installation of OS. During an installation, a blue screen appears, displaying a technical Information.It says there, my BIOS is something to be updated. My motherboard is...
You can visit the link below to find the appropriate bios drivers.
You will need to select "motherboard" then the appropriate motherboard model number on the left.
Click Here
May 05, 2011 | Microsoft Windows XP Professional
Hp Compaq Presario C700 bios update and numlock function is not work
Hi, did you download a beta version of the bios? If so you will have to try and install the last bios.
Which version of bios do you have?
Did you download the correct one for your serial number?
I think the current one is F.34
Did you make a backup of your old bios?
What was the reason for the bios update? I think this only improves bios security when a password is used.
If you haven't backedup your old bios, sometime there is and old bios file on one of the setup discs that came with the laptop.
I will try and help more-
Regards - Anthony
Feb 06, 2010 | Compaq Presario C700T Notebook
Floppy disc driver
You need to find system informaton and drives in the bios. You have to tell the computer what kind of drive you have. When you are at the right place you will see a drop down menu choosing your drive type. Newer computers do not support floppies and have memory card readers instead. If this is the case you will have to get a USB floppy drive.
Jan 11, 2009 | Panasonic JU 257 (JU257A827P) Internal...
I cannot enable the on board sound card(sound Max)
check the driver status of your sound , in the device manager, if its not installed , then install the drivers or if your sound is not detecting then
go to the BIOS and load optimized bios default settings then check
Nov 20, 2008 | ASUS P4P800 SE (890552603657) Motherboard
Installing 750GB SATA on Asus A8N-E Mobo
Hello there.
I would not update the BIOS unless you are experiencing any problems. Try installing the new hardware first and then if you do experience problems, think about upgrading the BIOS. The latest version is 1013 FYI.
The new hardware should be supported without a BIOS update, as long as you have Service Pack 2 in Windows XP or above then all your 750GB will be shown. As for the memory you should see it list the new size in the POST screen before Windows even loads, or inside Windows.
If you do have problems, then please post back and we can help.
Hope this helps.
Jul 19, 2008 | ASUS A8N-E Motherboard
Checksum error
Hi Faster Fester. You don't need to install the new BIOS.
You get the checksum error just because you're CMOS battery have run out. Just try to replace the CMOS Battery and you're problem will be solved.
Feb 09, 2008 | Computers & Internet
HP Compaq Presario V2000 Notebook Logo
223 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
