Question about Neovo E-19A 19" LCD Monitor
Screen goes black in half a second....
We have a Neovo E-19A monitor that turns on and has signal for about a half a second, then it goes black, with the LED indicator remaining green. The display has been used with an Apple computer for a year, and then the problem started to occur about a month ago. A local repair station did not want to repair it because they said they could not get parts. I am running an Extron Video Test Generator (VTG300) set to color bars (1280x1024 @60) and the screen does the same thing. Can anyone save the E-19A from the dumpster?
  • 2 more comments
  • barratso Nov 02, 2007
    Exact same thing as above. We have an HP Pavilion a510n computer.
  • jerrydino Nov 21, 2007
    I've bought three of the e-19a's on ebay(all broken). Two of the three of the monitors needed backlight inverter boards, and the other needs both inverter board and LCD replacement. I haven't been able to find suitable replacement backlight boards yet or a method to repair said board.
  • The Starman Nov 24, 2007
    green.
    The display has been used with an an Apple computer for about a year and a half. I have connected this monitor to a laptop and the same behavior occurs so I know that the issue is with the monitor and not the Computer video board. The computer still reacts as if the Monitor is present, and the sound output still works.
  • Anonymous Sep 04, 2008
    Same Issue here. When I cycle the power on the monitor it comes up for a second so I can see that Windows is booting etc but thats all
  • 3 Answers
Call the service dept. in the above post. Tell them the model and serial number of your monitor and order a backlight inverter board(approx. $35 plus shipping). Open up the monitor and plug it in, should fix the problem. This problem could also be caused by one or more backlights(small flourescent tubes) being bad. I just fixed a Neovo F-417 display by replacing one of the backlight assemblys. I also just fixed a Neovo E-17DA monitor by replacing the inverter board.
Posted on Feb 19, 2008
I successfully repaired my Neovo E-19A lcd moniter yesterday and it still works after a 24-hr burn-in.
At the bottom of the inverterboard are two light-brown SMD fuses with "2.0" printed on them (can't miss 'm!). I found one to be open and simply replaced it with a standard glass fuse that I soldered across the SMD with some short wires. To prevent short-circuits I insulated the fuse and wires with tape.
Many other things can be dead such as the transistors or even the transformers... So, obviously I was lucky! :)
Posted on May 29, 2011
I just called ag neovo and got the same solution, with a rma number to send it back for backlight inverver board, that was the only way the monitor could be repaired. hope this helps.
Posted on May 19, 2009
Talked with the folks at support for AG Neovo. Got an RMA to return the monitor even though it was out of warranty. The monitor needed a new inverter board ($35) plus Labor ($40) and $(20) to ship it back. I paid ($20) to ship it to them. Total cost of repair including shipping was ($115). A 1 year warranty on the part. Since the cheapest that I have seen a new monitor is about $450, I thought it an excellent solution.
http://www.neovo-usa.com/
AG Neovo Technology Corporation
2362 Qume Drive, Suite A
San Jose, CA 95131 U.S.A.
Email: rma@neovo-usa.com
Tel: 408-321-8210
Fax: 408-321-8211
Hope this helps someone else.
Posted on Feb 01, 2008
I have found the echivalent board parts.i think that the monitor is broking down because it can't releas the temperature from inside because of that metal plate that covers the components. the replace components are 2SK1388 and irf4905.they are echivalent or better than the stu's.can anybody tell were can i find the schematics for it's alimentation board?
Posted on Aug 14, 2009
I have the same monitor with the same exact problem. The same thing happens no matter if I connect it analog or digital. I know it's not my computer or vidoe card since I tested that with a different monitor.
Posted on Jan 14, 2008
I got this monitor off of craigslist "because it didn't work". The VGA has never worked, but the DVI worked fine for several months. Recently, the screen goes black, the screen shows a 'no...
Check the VGA output pins on your computer. Install a different monitor and see if it works on your computer. Or it could also be the VGA cable (pins) on the monitor is loose.
Dec 16, 2010 | Neovo E-19A 19" LCD Monitor
I HAVE A NEOVO E-19A MONITOR. ON BOOT UP SCREEN GOES BLANK AFTER ABOUT 5 SECS. TURNING OFF THE MONITOR THEN TURNING BACK ON BRINGS THE SCREEN ON FOR APPROX 5 SECS BEFORE GOING BLANK AGAIN. THIS IS REPEATED...
http://www.devicemanuals.com/guide/LCD/AG%20Neovo/AG-Neovo-S-19A-LCD-Display-English-Owner's-Manual-T1RjMU9Uaz.html
dlc.sun.com/pdf/820-0119-10/820-0119-10.pdf
http://www.scribd.com/doc/3082274/AOC-LCD-Monitor-786LS-Service-Manual
Use these training manuals, to troubleshoot and sort your issue out.
Above is a user manual, and a service manual, in the service manual, are the troubleshooting steps to perform to isolate the problem, and hopefully repair.
May 25, 2010 | Neovo AG 17" LCD Monitor
AG Neovo Monitor not working
nothing you can reset from monitor other than color brightness. You can contact with AG Neovo as service.us@agneovo.com to have a RMA number and they will estimate you the repair fee if it is out of warranty.
Jan 06, 2010 | Neovo E-19A 19" LCD Monitor
Power is on, but i don't have any image, screen is black
make sure power is on for the cpu. Also doublecheck that the connections are correct.
Dec 26, 2009 | Neovo E-19A 19" LCD Monitor
I NEED THE SERVICE MANUAL FOR AN AG NEOVO E-19A MONITOR.
Good luck on that one...you can only get that if your a service center.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Dec 11, 2009 | Neovo E-19A 19" LCD Monitor
Neovo e-19a flat panel will not work with gateway e4000.
You may have to turn on the external video from inside the BIOS; not all systems are set up to feed video to the VGA port unless told to do so.
Oct 26, 2008 | Neovo E-19A 19" LCD Monitor
Blackouts
have you checked your ram
Apr 03, 2008 | Neovo E-19A 19" LCD Monitor
Screen is gone in half a second....
could be the lamps or the inverter board
Oct 27, 2006 | Neovo AG 17" LCD Monitor
Neovo E-19A 19" LCD Monitor Logo
1,978 people viewed this question
Top Neovo Computers & Internet Experts
Steve Allison
Steve Allison
Dimitar Todorov
Are you a Neovo Computer and Internet Expert? Answer questions, earn points and help others
